Old 03-01-2023, 08:42 AM   #1
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
B & W Continuum Hitch
A few weeks ago I attended the National Farm Machinery show in Louisville, KY. This is a really big show for machinery of course but also every gadget and tool that can be used with machinery. Sensory overload - but fun!
One of the manufacturers there was B & W hitch. They make some of the best gooseneck and fifth wheel hitches in the industry - all domestically made products.
They had a new weight distributing hitch that looks very different from many others.
I'm not in the market for a hitch but I thought I would throw this out there for a fun forum discussion. Installation looks to be a breeze.
https://www.bwtrailerhitches.com/pro...ribution-hitch
WDHK4500 (pn 4510-210) 01 18 2023.pdf
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 03-01-2023, 09:00 AM   #2
dznf0g's Avatar
Oswego , Illinois
Attachment 428721
Attachment 428720
Interesting, and doesnt consume a huge amount of tongue real estate. I assume sway dampening is through friction in the head below the ball? What did they say about how that is accomplished? Do I see a couple grease zerks there??
-Rich-
Old 03-01-2023, 09:07 AM   #3
2019 25' Flying Cloud
Houston , Texas
That looks clever. The weight distribution by hydraulics makes sense. Not really sure where the friction sway control is coming from in that setup.
DCPAS is offline   Reply With Quote
Old 03-01-2023, 10:27 AM   #4
crispyboy's Avatar
1994 30' Excella
I read down through the installation documentation and I am unimpressed with the FAQ about sway. I can't identify what part of the hitch assists with dampening sway other than having a properly loaded trailer. That of course goes a long way to keep sway in-check. I thought that the trailer ball might be like the Andersen hitch ball but it doesn't look like it in the pictures. Here is a snip from the installation manual.
Name:	Screenshot 2023-03-01 122300.png
WBCCI # 3072
Old 03-01-2023, 10:49 AM   #5
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
It would be interesting to learn what the weight is to compare to other WD hitches, which tend to be fairly heavy. I cannot seem to find this. It would be a positive attribute to have a lower hitch weight.
Steamy1 is offline   Reply With Quote
Old 03-01-2023, 12:24 PM   #6
pjshier's Avatar
2017 27' International
Wasilla , Alaska
sway disclaimer, but claims no worse than others
addresses sway late in the video. Interesting set up...
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 03-01-2023, 12:31 PM   #7
Houston , Texas
Very confusing. It seems like they are talking of the slight sway damping effect inherent in a weight distributing hitch and not a separate or integrated friction device. This is from their FAQ: "We learned that all brands provide some level of sway control, but that it takes very little force to overcome them. Some brands don’t load until the angle of the trailer is 2-4 degrees or more."
Old 03-01-2023, 01:50 PM   #8
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
Looks pretty low to the ground! I would be dragging that coming out of the driveway.
With all the issues surrounding sway and the prevention of sway. They seem to be relying on the other factors that can be controlled like properly loading of the trailer to achieve the desired tongue weight; keeping speed down and avoiding the crappy road conditions.
If I was a complete trailering novice, I would hope that someone steers me to getting a PPP hitch or similar. This will certainly help me be safer but ultimately I can still find a way to do some damage if I drive too fast and the conditions are not the best.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 03-01-2023, 03:25 PM   #9
"Cloudsplitter"
Someone here will by one and we'll have another never ending opinion thread to choose from.
Our opinion, friction has never been the the most reliable form of control.
It may be they have discovered a new form.
It certainly is an interesting design.
POI...35+ years of bucklenusting I have repaired quite a few leaking hydraulic pressure lines.
Old 04-20-2023, 09:28 PM   #10
Flagstaff , Arizona
Continuum shipping weight is 114 lbs.
2022 25' GlobeTrotter FB <->2023 Ford F-150 PowerBoost 7.2kW ProPower
Electric Globetrotter
goldenchase is offline   Reply With Quote
Old 04-21-2023, 05:34 PM   #11
hikingcamera's Avatar
2022 23' Flying Cloud
Seattle , Washington
Haven't watched the video yet, but BigTruckBigRV reviewed it, apparently. Scratch that, he just unboxes it. Apparently there is another video where he talks to the B&W folks, but that probably is not much different from the other video shared. I'll be curious when he does review it. I'm also curious if it will fit as close as the propane tanks are to the tongue jack on most Airstreams.
hikingcamera is offline   Reply With Quote
Old 04-21-2023, 06:03 PM   #12
Flagstaff , Arizona
Mine arrives tomorrow. According to UPS the two boxes coming weigh 114.2 lbs. I have checked my measurements and since I don't have propane bottles and the propane supports are removed, it appears the hydraulic cylinder will be in the optimal place for this installation. If it arrives on time it should be on the trailer by Sunday.
First short review here.
Old 04-22-2023, 03:58 AM   #13
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I will keep my Reese duel cam , it has been proven
Old 04-22-2023, 05:18 AM   #14
2023 25' Flying Cloud
Franklin , Tennessee
When disconnected, that yoke seems to rest on a mount placed above the tongue jack foot. There doesn’t seem to be any room for that if you retract your tongue jack completely when traveling. I also don’t see room for that cross bar between the tongue jack and the propane tanks. Interesting design though. It does look pretty low to the ground.
2023 25RB Twin Flying Cloud
2022 F-250 XLT Supercrew 4x4, 6.2L Boss
BRN# 3612
TNOutback is offline   Reply With Quote
Old 04-22-2023, 03:38 PM   #15
Flagstaff , Arizona
Continuum arrived. The workmanship is outstanding.
Old 04-23-2023, 03:54 PM   #16
Flagstaff , Arizona
Continuum installed in 2 hours this morning. Very, very easy installation. First test drive was outstanding. No noise at all making tight turns. Motion over uneven payment dampens in one cycle, versus two or three with Blue Ox TrackPro. Because weight distribution force is directly proportional to hydraulic pressure you can dial in front fender height to any number. With the bar system on the Blue Ox WDH I found the 1,000 lb bar was too much and the 800 lb bar was too little. Dialing in hydraulic pressure lets me set the front fender height exactly to the position it was before the trailer was on the hitch.
The Continuum hitch is about 3" shorter pin to ball than the Blue OX WDH.
For those with propane bottles it will take a little "grinder surgery" to remove a section of the propane bottle supports to allow the cross beam to be flat across the hitch. No big deal but just not enough room on my 25' GT FB. I had previously removed all the propane stuff with the electric conversion. I have more install images if anyone is interested.
Before
Two hours later.
Old 04-23-2023, 04:50 PM   #17
2004 22' International CCD
Beaumont , California
Quoted from their site under the first question inFAQ:
“…While traditional WD hitches are either ‘loaded’ or ‘unloaded’, the Continuum uses a pump to allow you to fine tune the amount of weight you are moving to better control your towing experience.”
Basically, they infer that other brands are not adjustable.
“Loaded or unloaded”
Hmmm
Ndcctrucks is offline   Reply With Quote
Old 04-23-2023, 05:02 PM   #18
Flagstaff , Arizona
Hmmm
Not sure what they are inferring but I think the key is that this hitch can be "finely" adjusted to your hitch weight versus changing bars or moving chains. You just give some pumps on the handle then dial in the pressure that gets your front fender to the right height given the load on the hitch.
Old 04-23-2023, 05:14 PM   #19
dznf0g's Avatar
Oswego , Illinois
Ok, propride and Hensley have been "finely adjustable" forever. So are the others when the strap is used.
Chains? Not so much.
-Rich-
Old 04-23-2023, 05:22 PM   #20
Flagstaff , Arizona
And bars too. Only grossly adjustable. Bars and chains seem very medieval.
1973 &amp; 1976 Windows Parts &amp; 80's Door-Negotiable tbashin Airstream Classifieds 0 01-01-2018 08:22 PM
Carefree Roadside &amp; Rear Window Awning Arms &amp; Rollers For 1976 31' Airstream Sovereign mrnos44 Airstream Classifieds 0 08-23-2016 07:08 PM
Goucho couch,original am/fm 8 track &amp; lots of wood &amp; aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 04:25 PM
