11-22-2020, 08:00 AM
2021 16' Caravel
Stuart
Anderson & air bags
I have a decided to install a Anderson system for my 16' Caravel (2021). Seems like the best unit for my light weight Caravel (4,300 Max GVW & 500+ hitch weight)
Towing with a 2020 Jeep Gladiator Overland. (Max GVW 5,800 lbs) Actual weight on Cat Scales 4,800 lbs, no drivers, cargo but with full tank of fuel. So only a 1,000 lbs for people, cargo, actual hitch weight and tung weight. Anderson's weight is 60 lbs instead of 100+ lbs for other systems.
QUESTION: I also have Firestone Air Bags inside the real coil springs. Helps with the stability of the Gladiator Overland with rather weak/soft rear coil springs.
Other hitches suggest in the install of the hitch, when having air bags, is to just set a 5-10 lbs while installing and setting up the system. Than after that is done raise the pressure on the air bags to around 20-30 lbs. Enough to still have them steady the load, but not enough to transfer any weight to the front wheels.
Thanks to any who might have an opinion on Air Bags and the Anderson.
