Old 03-22-2025, 12:41 PM   #1
2025 27' Globetrotter
Gaithersburg , Maryland
Airsafe Hitch question
I've got a hitch question. I've got a '24 F250 diesel, and a GT27FTB on order. My truck has the 2 1/2 inch receiver, and I'm trying to decide between Air Safe hitches. From a weight point of view, a Class V hitch (Tongue weight of 1000-1400lbs/Trailer weight of 10-14k) should do fine, but the Air Safe recommendation is a Class VII hitch (Tongue weight 2-2.5klbs/Trailer weight 20-25klbs) for a 2 1/2 receiver, because the side mounted shocks help with the airbag rebound. The Class VII seems to be on the overkill side to me, but I'm prepared to be wrong. Does anyone have any comments on this?
At this point, I'm not planning on using a weight distributing hitch, but I plan on re-evaluating that with some experience.
daveb377 is offline   Reply With Quote
Old 03-22-2025, 01:14 PM   #2
HOLLAND , NY
Watch recent 'Thirteen Adventures' Youtube on the subject
Forester2 is offline   Reply With Quote
Old 03-22-2025, 01:34 PM   #3
2021 25' International
Plymouth , Michigan
I have Class VI version (Airsafe recommended at the time) Airsafe for my F350 2.5” receiver and 25’ FBT..I thought at the time that was overkill but it works fine. Heavy hitch. I have had it 3 years now. To me a VII would be even further overkill. Class VI does come with shocks and make for good grab handles when slipping hitch into receiver. I tow on the ball only but I did buy Airsafe hardware in case I wanted to add a WDH later..it’s not been the case. My actual tongue weight is ~ 1k#.
ID:	451698   Click image for larger version
2021 International 25FBQ converted to FBT
2022 F-350 7.3 SRW CC LB
2018 F-350 6.7 SRW CC SB
SVTRIDE is offline   Reply With Quote
Old 03-22-2025, 03:09 PM   #4
Must be a big secret on how much this hitch weighs, guessing what 130-160lbs??
Trl Wires is offline   Reply With Quote
Old 03-22-2025, 04:37 PM   #5
SallyForth's Avatar
2023 23' International
2023 27' International
2025 30' Classic
Nokomis , Florida
Brad Driver, of the YouTube channel Thirteen Adventures, recently evaluated this hitch with their Airstream International 27FB Twin towed by their F-350.
He discusses the various classes of this hitch, and explains why he chose the class he did. Also, he demonstrates the hitch in action.
USMC (retired) Sergeant Major Brad Driver is great source of Airstream related information. He is a former certified Airstream Tech. His rig is very similar to your setup.
https://youtu.be/IEVhH0IlydM?si=d7sVu1PWBGOnxeFu
“No matter where you go, there you are.” — B. Banzai
SallyForth is offline   Reply With Quote
Old 03-22-2025, 06:08 PM   #6
Thanks. I did watch the video with great interest. I will point out that he didn't choose the specific hitch, it was the one sent to him by AirSafe, so not really a comparison between multiple Airsafe models. Nevertheless, very interesting.
Old 03-22-2025, 06:09 PM   #7
It certainly is a chunky monkey. Part of my concern it installing it/removing it, as I like my back and knees the way they are.
Old 03-30-2025, 09:21 AM   #8
2019 30' Classic
Hillsboro , Texas
I rode for years with a Hensley and changed to an Airsafe VI. I never had any separation issues but was doing it as a preventative measure. Used the BlueOx ‘Airstream’ version. Great setup, never an issue with the ride. But I did have one problem, the DW didn’t like it because she couldn’t do the latches on the sway bars. So we are back to the Hensley because she liked that better.
If anyone wants a lightly used Class VI Airsafe and BlueOx, only used about 5,000 miles. I haven’t listed it for sale (I am inherently lazy about things like that) but I am ready to sell it and will take $1,000 for both.
2019 Classic and 2005 Land Yacht 396 XL and 2 cats
Certified RV Tech, LP certified in TX, generator certified and Alde certified.
LilPeanut is offline   Reply With Quote
Old 03-30-2025, 09:34 AM   #9
2019 33' Classic
Kansas City , Missouri
Works well
I have used an airsafe for several years on our GMC truck 3500 and 33 f Classic. I have the 2” shaft which was all I could get during Covid. I have the Airsafe mated to an equalizer WDH. Our system rides well. I think the amount of air pressure you have in it matters more than the class hitch. Get the extended shaft on the drawbar if you want to mount Rock Tamer mudflaps.
Mwilliams is offline   Reply With Quote
Old 03-31-2025, 07:55 AM   #10
SHE SHED
trikdacy's Avatar
2019 30' Classic
Brooklyn , New York
I have a Class VI AirSafe hitch with a 30' Classic being towed by an F-350 dually diesel.I have a 3" receiver, and Ford supplied sleeves to reduce the receiver to 2" in 1/2" increments. I read on the the AirSafe site a few years back that when you use a weight distribution head you lose 25% of the hitch's ability. Whether this is true, I am not sure, but I thought it was safer to follow the recommendation on the web site. I think a Class VII would be overkill. I have back injuries so I purchase a portable transmission jack to remove and reinstall this hitch, because it's heavy. The jack allows me to roll this hitch around while I periodically inspect the receiver and hitch.
The Jack is available on Amazon:
https://www.amazon.com/dp/B01BWZLIQ6...n_title_1&th=1
ID:	451924   Click image for larger version
Name:	Screenshot 2025-03-31 at 9.53.48 AM.png
trikdacy is offline   Reply With Quote
Old 03-31-2025, 06:35 PM   #11
2023 33' Classic
Chandler , Arizona
ID:	451950I have the 24 F350 SRW I purchased the class VI Airsafe hitch, works amazing, would never consider anything else to tow our Classic 33. Ive mounted 840ah of LifePo4 batteries in the front compartment which adds a couple hundred more LBS up front, the class VI handles with no issues.
Saullman is offline   Reply With Quote
Old 03-31-2025, 07:07 PM   #12
Originally Posted by Saullman View Post
Attachment 451950I have the 24 F350 SRW I purchased the class VI Airsafe hitch, works amazing, would never consider anything else to tow our Classic 33. Ive mounted 840ah of LifePo4 batteries in the front compartment which adds a couple hundred more LBS up front, the class VI handles with no issues.
That's a lot of battery! How long does that give you when boondocking?
Dave
Old 03-31-2025, 07:10 PM   #13
That seems like a prudent purchase. I don't have back issues, and I'd like to keep it that way
Old 04-01-2025, 12:06 AM   #14
2023 33' Classic
Chandler , Arizona
Dave, Most of our journey's are for a weeks time. Being that its a 2023 Classic it has a 12v fridge/freezer, also the
Aldi Heating system can utilize propane of 115vac to operate. We have the ability to utilize one of the AC's if necessary and can go approx 6 hours with the AC on as long as there's sun. That's really the limiting factor. A couple cloudy days and your screwed, that's when I'll have to plug into the Bluetti AC500 with a couple of batteries to replenish the classic batteries. Here's a pic of the setup.
Old 04-01-2025, 12:10 AM   #15
2023 33' Classic
Chandler , Arizona
it also helps to have 1K watts on the roof.
Old 04-01-2025, 08:27 AM   #16
2022 33' Classic
Chesapeake , Virginia
Love your truck! I have a 2022 diesel, SRW. You did a great job on the installation, very neat. I have to ask - how about sway? No WD, or anti-sway? I like our Propride, but it is sometimes a pain to hitch up.
Sorry if you have already posted these answers elsewhere.
Bill
BGClassic is offline   Reply With Quote
Old 04-01-2025, 09:45 AM   #17
2006 31' Classic
Union City , Tennessee
Where are you located, interested in Airsafe and hitch, you can text me @ 731-446-9386, thank you
rhalford is offline   Reply With Quote
Old 04-01-2025, 10:08 AM   #18
Freedom
KCurtis's Avatar
2023 30' Classic
Dallas , TX
I decided to go with the Shocker Hitch due to the weight difference. My back isn't getting any younger. LOL
2023 30 Foot Classic
2022 Ram 3500 Dually
KCurtis is offline   Reply With Quote
Old 04-01-2025, 02:33 PM   #19
2022 33' Classic
You're not running any WD or anti-sway, correct?
Old 04-01-2025, 11:35 PM   #20
Quadder
2024 25' Globetrotter
Kelowna , British Columbia
[QUOTE=trikdacy;2775240]I have a Class VI AirSafe hitch with a 30' Classic being towed by an F-350 dually diesel.............. I purchased a portable transmission jack to remove and reinstall this hitch, because it's heavy. The jack allows me to roll this hitch around while I periodically inspect the receiver and hitch.
/QUOTE]
I did the same thing. The transmission jack works great. I love this hitch, and will never get another WDH again.
Just sayin'.
2024.5 GT25FBT
2024 F350 Plat 6.7R
Quadder is offline   Reply With Quote
Airsafe Hitch on '17 Ram 2500 4X4 K-9Airstream Towing, Tow Vehicles & Hitches 14 09-05-2017 08:09 AM
Question for AirSafe Hitch Owners Adiredneck Hitches, Couplers & Balls 28 08-11-2015 07:52 AM
AirSafe Hitch and Rock Tamers rperrym Hitches, Couplers & Balls 19 08-29-2014 03:51 PM
Safety chains with AirSafe Hitch rperrym Hitches, Couplers & Balls 2 05-07-2013 11:20 AM
Airsafe Hitch 68 Overlander Hitches, Couplers & Balls 69 01-30-2008 07:07 AM
