Old 03-21-2025, 12:50 PM   #1
2022 22' Bambi
BALTIMORE , MD
Will BMW x3 tow airstream
I have a 22 ft bambi, will a x3 tow it?
delmaggie is offline   Reply With Quote
Old 03-21-2025, 01:02 PM   #2
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
It will pull (tow) it, but will it control it on the highway, stop it on the highway, and withstand sway, safely! What do your factory specs say about tongue weight and combined vehicle weight?
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 03-21-2025, 01:50 PM   #3
JEB
2021 23' Globetrotter
Northern , Illinois
I wouldn’t recommend it. You will be very tight on payload. If I recall correctly, the X3’s payload is a little bit above 900 lbs, the tongue weight of the Bambi is about 525 dry, and that’s probably understated once loaded. That leaves you at most 400 pounds to play with to carry everything you need to carry in or on the car (passengers, camping gear, tools, WD hitch). Plus, it’s a pretty short wheelbase. You’ll feel the trailer back there.
JEB is offline   Reply With Quote
Old 03-21-2025, 03:08 PM   #4
jcl
Vancouver , British Columbia
What year and model of X3?
We had an E83 X3, 3.0si, 6 spd manual, 265 hp. It had more power, better braking, and essentially the same dimensions as our previous E53 X5. The wheelbase isn't as important as the very short rear overhang IMO. The X5 had tow ratings up to 7700 lbs (we had a 6000 lb hitch installed on ours). The OE hitch we had on our X3 was rated for 3500 lbs. It towed that, or a little more, very well. Excellent towing platform. If we had wanted to tow 5000 lbs we would contact Andy at CanAm RV and ask about whether the OE receiver would benefit from being reinforced. I recall that CanAm referenced towing a 25 with our model of X3, but I don't recall what hitch receiver changes they recommended, if any.
Our X3 had more payload than a friend's RAM1500. He was towing an AS27 at the time.
Later model X3s are either the F25, or G01. I haven't towed with either of those. CanAm would be a good source of info on those.
jcl is online now   Reply With Quote
Old 03-21-2025, 03:16 PM   #5
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
yes
i towed our sport 22FB with an Audi Q5 3L
now we tow out FC 25FB with same Q5
call or go to CANAMRV to get you vehicle inspected and the hitch assembly properly installed
https://www.canamrv.ca
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
BMW X5 Tow Vehicle wlanford Tow Vehicles 28 08-24-2014 09:16 PM
BMW Tow Vehicle Question rdinflatrock Hitches, Couplers & Balls 7 08-04-2013 09:21 AM
BMW X5 2011 TV, trying to decide which size AS I can safely tow kayt Tow Vehicles 4 10-01-2011 08:25 PM
No VW tow vehicle here...BMW to the task PeeWee Off Topic Forum 17 05-16-2008 02:37 PM
BMW 740 Tow Vehicle JD1 Tow Vehicles 9 02-10-2003 07:28 AM
