Old 11-03-2020, 08:04 AM   #1
2017 20' Flying Cloud
Williamson County , Texas
When braking how much trailer weight transfers to TV ?
I am happy with the braking performance of our combination (GMC Canyon and 20' FC). Looking at the 2021 Canyon/Colorado, it appears GM has gone from a 4 piston front caliper to a 2 piston floating caliper common to Acadia and Cadillac AT* passenger cars. Not sure of performance difference but I prefer the 4 piston fixed just by design.
Got me thinking about trailer braking and TV brakes. Wondering that under heavy braking and trailer brakes right at point of locking, what percentage of trailer weight (or mass/force) is transferred forward to the TV? Obviously some significant amount is, or the braking distance would be the same as the TV without a trailer. Not talking about light braking where braking is ideally shared close to equally.
Looking at braking standards, SAE has "recommended practice" standards J134/J135.
Apparently only states that actually have performance requirements set a pretty low bar (I believe WV should be "ft/sec^2" not "ft/sec" in which case about 0.4G).
West Virginia: A motor vehicle or combination of motor-drawn vehicles must be capable of stopping at the following rates as if on a dry, smooth, level free road: (1) vehicles or combinations of vehicles with brakes on all wheels must be able to decelerate at a speed of 14 feet per second; and (2) vehicles or combinations of vehicles not having brakes on all wheels must be able to decelerate at a speed 10.7 feet per second.
Wyoming: Every combination of vehicles must have a service braking system that will stop the combination of vehicles within 40 feet from an initial speed of 20 mph on a level, dry, smooth, hard surface.
2018 GMC Canyon V6 Mallet Supercharger
SYC2Vette is offline   Reply With Quote
Old 11-03-2020, 09:48 AM   #2
GM Eboost concept
So this would be great....
Old 11-03-2020, 10:07 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I sure don't have an answer about weight transfer and that video demonstrated a concept but no details about what it is that decreased stopping distance as demo'd.
But if you are serious about putting the brakes on your AS Dexter 4 piston brakes are a bolt on IF your axles are Nev-R-Lube.
I did a test fitment on another trailer in my driveway while R&R brakes and backing plates on a Nev-R-Lube equipped drum brake axle.
Of course lines, hoses and actuator required too.
If you'd like to see a pic send me PM with email. My 2007 has the Dexter 4 piston brakes.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 11-03-2020, 05:56 PM   #4
2007 27' International CCD FB
San Diego , California
Hard to quantify but it would be substantial. Particularly onto the rear axle of the tow vehicle.
Saving grace is that the tow vehicle itself also transfers substantial weight to its front axle within itself. Keeping some reasonable balance on the tow vehicles axles.
This video may help visualize some of the dynamics going on. You can roughly understand the weight transfer by how much the vehicle squats at the front and rear axles.
pteck is offline   Reply With Quote
Old 11-04-2020, 10:12 AM   #5
Saving grace is that the tow vehicle itself also transfers substantial weight to its front axle within itself. Keeping some reasonable balance on the tow vehicles axles........
Well that is a good point, and with WD perhaps keeps more weight on the trailer axle too. A bit complicated certainly, and obviously the CG height of the trailer affects the transfer too.
Old 11-04-2020, 11:49 AM   #6
2018 25' International
Slidell , Louisiana
The minimum percentage is fairly easy to reason through. Dexter biases the brakes to just stop about 95% of the weight rating of the axle without locking. In addition there is no reason to presume the trailer axles have a higher coefficient of friction than the tow vehicle. So at a minimum, all the tongue weight inertia is transferred to the tow vehicle. Next, the tow vehicle has antilock features so any torque added to the rear vehicle axle by the rotational inertia around the trailer brakes will be used to allow additional braking force. The calculation is complicated but we can say it is a minimum of 5-10% in a full emergency stop. So the minimum weight can be estimated at 15-30% depending on tongue and trailer weight.
If the trailer wheels do lock, then much more weight is transferred to the tow vehicle.
If there is sufficient interest, I can get the slide rule out but I would prefer not.
Brian
Old 11-04-2020, 12:29 PM   #7
GCinSC2's Avatar
Mine is a Pickett still have the belt holster and owners 1960 manual.
S/OS #001
Old 11-04-2020, 12:37 PM   #8
Slightly later vintage but have these in my desk drawer.....
Old 11-04-2020, 01:08 PM   #9
Slidell , Louisiana
lol I don't think I can remember how to use one!
Brian
Old 11-04-2020, 02:04 PM   #10
waninae39's Avatar
2017 22' Sport
NCR , Ontario
With a break controller , we use it to manually put the AS brakes on when going down hill.
that reduces the TV load as well as reducing the As pushing the TV.
it does not have to be on 100%, just modulate it to regulate your speed.
Thus we don't really worry about braking force on downhill as we make the As do its own breaking
just use common sense on the roads i.e. downhill, rain, ice fog windy etc.
waninae39 is offline   Reply With Quote
Old 11-04-2020, 05:15 PM   #11
2019 27' Tommy Bahama
Midland , MI
And I still use them. Love the HP reverse Polish Notation system. And of course a slide rule. I have my K&E from the good old days. Loved that thing and I earned a living with it for years.
BobnGayl is offline   Reply With Quote
Old 11-04-2020, 05:34 PM   #12
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
most of the weight would be pushing against TV if there's no trailer brakes. With working trailer brakes on, slim or none weight pushing the TV. it seems that way with my 19'
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 11-04-2020, 07:39 PM   #13
2007 22' International CCD
Ditto. My favorite gag at work was to loan the HP RPN calculator to someone and watch the fun. Still have my original K&E Deci-lon, itís scabbard and a copy of the book.
Old 11-05-2020, 06:53 AM   #14
MaineStreamer's Avatar
2007 20' Safari
Old Orchard Beach , Maine
Isn’t the weight that transfers to the tow vehicle the “tongue weight”?
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
2019-2021 President, Northeast Mountaineers Airstream Club
MaineStreamer is offline   Reply With Quote
Old 11-05-2020, 07:11 AM   #15
1976 Argosy 26
Henderson , Kentucky
Images: 22
Just thinking, but if trailer brakes are working and applied harder than tv brakes, but not locking, does this not pull backwards from tv? You can stop tv with trailer brakes. If so how add to tongue weight? Just seems contrary to Newton. Be Safe.
Be Safe. Mitch
Ky76Argosy is offline   Reply With Quote
Old 11-05-2020, 08:10 AM   #16
What got me on this track was a recent instance where I had to "panic brake" so to speak with the trailer in tow. Stopped in time, and the trailer tires did not lock but were chirping so on the verge of lockup, and TV was at the point of activating antilock. The stopping distance was very obviously longer than our TV by itself even loaded for camping.
So perhaps with a dual axle there would be less transfer than with our single axle, but either way there is force applied to the TV (down at the hitch ball and forward). Same effect with our K2500 and a loaded 2 axle dump trailer BTW although never had to "panic brake" with that.
Be nice to have CarSim to model various combinations.
And yes, under lighter braking you can definitely have the opposite effect with trailer pulling back on TV depending on brake adjustment
Old 11-05-2020, 08:45 AM   #17
waninae39's Avatar
2017 22' Sport
NCR , Ontario
when going down a high, i use the brake controller to use its breaks. if i give to much force, i can feel the AS slowing the TV down. yes it has more force and the TV speed does slow down.
So yes, the As can slow down the TV, even going down a hill. I only have 2 wheels. 4 would be even stronger
Old 11-05-2020, 02:52 PM   #18
Slidell , Louisiana
As you say, for casual braking, either the vehicle or the trailer can handle anywhere from 0-100% of the job required to slow the combination up to the point the braking force exceeds tire grip force. It all changes when all the brakes are applied simultaneously at maximum force especially when the vehicle includes adaptive brake controls as all modern vehicles do. There will be increased braking force applied particularly to the tow vehicle rear axle to take advantage of the additional grip afforded by tongue weight and torque created by the trailer brakes.
As I previously described in a max hard stop situation the tow vehicle will end up providing minimum of 15-30% of the trailer stopping force depending on trailer loading, tires,
and road conditions. More if the brake controller or trailer brakes are not configured correctly.
Brian
Old 11-08-2020, 11:51 AM   #19
1990 29' Excella
baltimore , Maryland
Slide rule and HP 11c..
Pavlovian gurgle ...
groundhogy is offline   Reply With Quote
Old 11-09-2020, 08:37 AM   #20
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Not to hijack this thread, but I have both of those too. Still use my HP 12C.
Randy
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
SilverCabin is offline   Reply With Quote
What AS & MB warranty actually transfers when buying new John1048 Sprinter and B-van Forum 0 12-08-2018 09:26 AM
New Dexter axles lack trailer braking power krohnjs Brakes & Brake Controllers 18 09-17-2013 10:02 AM
Factory Warranty Transfers on Sale? ResoRon Dollars & Cents 7 12-16-2012 12:04 PM
Guide to Better Trailer Braking... Mexray Brakes & Brake Controllers 12 01-23-2012 11:33 PM
Instinctive Sway Control - and trailer braking. AIRBORNE SUB Brakes & Brake Controllers 3 03-12-2006 06:24 PM
