08-02-2018, 08:34 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
When a 3500 is not enough
My neighbor says his 06 3500HD Duramax overheats towing the grades so being a trucker he rigged his vintage Kenworth to tow his wife horse trailer, it has no air conditioning so now they overheat. LOL
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
08-02-2018, 09:23 PM
2007 22' International CCD
Corona
Oooh. Where’s the like button. Talk about massive overkill!!!
08-02-2018, 10:39 PM
2018 30' Classic
Ivins
, Utah
Hmm it looks like the front fenders are a little high... perhaps some weight distribution is in order. What do you suggest - Equalizer or ProPride?
(ducks and runs for the door) [emoji4]
08-02-2018, 11:16 PM
Sag Harbor
, New York
Seriously though, that truck's suspension was never designed for such a point load falling so far behind the rear axles! Looks like it is, what?, about 4' to 6' behind the mid-point between the two rear axles? What is the hitch weight of that 5th wheel setup, when loaded with horses?
Not overkill at all . . . but surely bad aiming!
08-03-2018, 01:06 AM
Salem
, Oregon
Hi, so replacing a 12 year old radiator, thermostat, or maybe a fan clutch isn't worth fixing the problem, so use the Kenworth. What happens when the Kenworth starts to have problems? Boeing 747???????
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-03-2018, 01:31 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
I saw several 5th wheels pulled by semi rigs when I was in Texas. All of them had the tag axle removed and the frame shortened. I was told that the semi could be tagged as a private tow vehicle rather than a commercial tractor once the second axle was removed.
Seriously, horses are heavy and so are their trailers (2 to 3 inch thick plywood floor). 3500 is probably overloaded with a big horse trailer. But a Kenworth? Are the horses Clydesdales?
08-03-2018, 04:17 AM
Sag Harbor
, New York
Originally Posted by AlinCal
. . . so being a trucker he rigged his vintage Kenworth to tow his wife horse trailer . . .
Er, how many horse wives does he have?
08-03-2018, 07:41 AM
1991 25' Excella
Santa Ynez
Not actually hitched yet, just in vicinity.
06 has less than 10K mi. on it and is modified with larger exhaust and upgraded intake and turbo to try to fix the problem with no satisfaction.
Trust me if it could be fixed it would be.
They are Mules to be more accurate, but usually only one goes at a time.
Are you just working on your post count here?
Will Rogers
Alan
08-03-2018, 07:44 AM
1991 25' Excella
Santa Ynez
If you look at the lowered rail you can see the kingpin is over the axles and as seen not yet hitched.
Will Rogers
Alan
08-03-2018, 07:55 AM
Sag Harbor
, New York
Thanks, sorry, I did not notice that!
08-03-2018, 08:26 AM
Chelsea
, Maine
I had an ‘05 Duramax, and of course I frequented the applicable forums for it.
Some D’Max trucks in that era had overheating problems, some did not. Mine did not. There were super duper aftermarket radiators available to help fix those that did.
I’m a little skeptical about the oversized intake, turbo, and exhaust fixing the overheating. Certainly you will be moving more air through the engine, but also making more power, and therefore heat, that the cooling system still won’t be able to handle.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
08-03-2018, 12:22 PM
2013 31' Classic
billings
, Montana
........you are right on....maybe it also is chipped....I would like to drive it once...just back off on the grades...like driving a 280 cumalong...or 262...
08-03-2018, 02:50 PM
Argyle
We have owned a 2002 GMC, DuraMax, 1 ton, dually, bought new. We have pulled heavy equipment; a three horse trailer w/ living quarters, - loaded with 3 horses, etc. over all terrains without a heating issue. I would have done something like this in jest, but I would have that 2006 DuraMax iback in the dealership from where it was bought. This should not be happening.
08-03-2018, 03:30 PM
1991 25' Excella
Santa Ynez
Thanks for all the great replies, did not think this would have taken this tack and I'll let him know what you all think he should do.
I think he likes towing with the Kenworth though and it's just an excuse to do so.
If a hammer is good for the job a sledge hammer should work better.
Will Rogers
Alan
08-04-2018, 08:36 AM
Argyle
That was my point. This would be an attention getter!!!
08-09-2018, 08:39 PM
2007 27' International CCD FB
San Diego
Is slowmover your neighbor?
08-09-2018, 08:55 PM
1991 25' Excella
Santa Ynez
Thankfully NO.
Will Rogers
Alan
08-10-2018, 08:03 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
I think that we can all agree that since he doesn't have a Hensley he is being irresponsible and putting others lives at risk!
08-11-2018, 06:40 AM
2008 30' Classic S/O
Hampton Beach
, New Hampshire
Not the only one...
Apparently the need for a bigger "hammer" is not limited to the "left" coast as we can see the "right" coast is doing the same thing.
This rig was at the Hampton Beach SP for a few days of fun in the sun and salt air.
Not very clear on the photo but the drivers door was titled "Rat Trap".
Tom - Slide-Out Society Registry Member #025
AlumaSlider Get-Together, 28-30 Sep 2018, Stone Mountain SP, NC
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
08-11-2018, 07:04 AM
Lakes Region
, New Hampshire
And like people who tow a 23'er with a ¾ or 1 ton, he probably tells everyone it doesn't even feel like anything is back there. Go big or go home
"Anyone, who actually fought for it, would know that the freedom we fought for, was so no one could tell us what we have to do." -me
