Old 06-15-2017, 06:08 AM   #1
knunut's Avatar
Chgo. N.W. Burb's , Illinois
Used 150 ECO.Easy way to tell if HD tow Pkg.
If your looking at used F150 ECO's is there an easy /sure way to tell if it has HD tow pkg? Is it the Large Tow mirror's? Code on Vin ?
Thank's in Advance.
knunut is offline   Reply With Quote
Old 06-15-2017, 06:24 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The large mirrors are not included in the Max Tow package in the 2017 & 2018 models and available separately (not sure about earlier years) so they are not indicative that the Max Tow package is on a particular vehicle. If you can't check the sticker, you could visualize the additional transmission cooler as that is one visible feature of the Max Tow package. Also, with the VIN, a cooperative dealer should be able to verify the presence of the package. If you are having a professional mechanic check out the truck, they should be able to see the transmission cooler during their inspection.
Bob Martel
WBCCI# 5766
Old 06-15-2017, 07:38 AM   #3
N/A , N/A
Provide the VIN to a Ford dealer and they should be able to give you the full specs. There are online VIN decoders too, but I'd trust the dealer more.
rostam is offline   Reply With Quote
Old 06-15-2017, 07:42 AM   #4
Suamico , Wisconsin
I've used this link in the past to get window stickers. The info comes directly from Ford.
http://schickerfordstlouis.com/Look-Up-Window-Sticker/
koldewaj is offline   Reply With Quote
Old 06-15-2017, 11:22 AM   #5
2005 28' Safari
Saint Joseph , Michigan
look at the dash, can be done with on-line ads, there will be a trailer brake slide on the right hand side of the driver's dash, a small blank hole without...
TruckerFritz is offline   Reply With Quote
Old 06-15-2017, 01:48 PM   #6
2017 30' Flying Cloud
Spotsylvania , Virginia
Well you can order an F-150 with a brake control and not the Max Tow Package so that won't work.
Max Tow has an additional oil and trans cooler, which is very hard if not impossible to see.
The easy way is what was suggested, take the Vin # to you Ford dealer and they can tell you exactly whats on the truck.
Happy Motoring ;-)
KWN306 is offline   Reply With Quote
Old 06-15-2017, 08:52 PM   #7
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
In 2013 Max Tow required 3.73 axles so if you're really stuck you could jack it up and count drive shaft and wheel revs. But, as stated, the best advice is to ask Ford. I assume any dealer would help.
I had a 1987 E150 that I bought new. Twenty-six years later I contacted Ford Customer Service about a payload question and they sent me full specs and the original build sheet!
BillfromWI is offline   Reply With Quote
Old 06-17-2017, 07:46 PM   #8
Albuquerque , New Mexico
Call the Ford customer service number with the VIN and they will tell you what the original equipment was:
Ford and Mercury United States
1-800-392-3673
1-800-232-5952 (TDD for the Hearing Impaired)
Monday-Friday, 8:00 a.m.- 8:00 p.m. Eastern Time
Saturday, 9:00 a.m.- 5:30 p.m. Eastern Time
Airhead59 is offline   Reply With Quote
Old 06-17-2017, 09:15 PM   #9
2017 25' Flying Cloud
Gold Country , California
These are all good suggestions. We found ours by accident. We were at carmax looking at one parked next to it. I noticed the mirrrors, then checked the door tag with payload (1780). They didn't know what they had.
Ours was a fleet vehicle, which seems to be the majority of used with Max Tow. Good luck with your shopping
NorCal Matt is offline   Reply With Quote
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 08:12 AM
Ram Eco diesel vs. F-150 3.5 Eco-boost Vagante Towing, Tow Vehicles & Hitches 43 06-25-2015 03:16 PM
2011 1500 Suburban LTZ 3.45 Tow PKG & auto ride or a TV joeifagroup Tow Vehicles 19 11-29-2010 06:20 PM
2008 Highlander w/Tow Pkg 4WD 3.5L 270hp V6 zimode Tow Vehicles 3 08-16-2008 05:48 AM
