12-04-2023, 10:03 AM
#81
1994 30' Excella
alexandria
, Kentucky
Very nice truck!
You made a good decision as I would have gone with the 3/4 ton too. That's plenty of payload for what your using the truck for.
2009 Dodge 2500, 6 Speed Auto, CTD, Quad Cab, Short Bed, ARE cap, Bed Rug
Propride 3P Hitch
WBCCI # 3072 Airstreaming since 2008
12-05-2023, 06:26 AM
#82
Sombrero
2018 30' Classic
St-Jérôme
, Quebec
Originally Posted by gypsydad
Think he did post; see post #71 above, if thats the same truck in the sticker? Surprising...not sure how the new Platinum FX4 model shown has such a big payload? Perhaps some options left off, like Sunroof, power running boards? Or, how did Ford get to that payload with a true 4x4 and 6.7L on a loaded up Platinum? Very attractive!
No its fully loaded, sunroof!, like everything!, It has the 6,7 High Output engine in it boasting 1200 lbs/Trq 500 hp! with increase GVWR to 11500 Lbs and maximum towing package, the truck can tow, 20500 Lbs and 3000 Lbs payload!, this is why I have fallen for this truck! I truly think its special!
God is the Sun
12-05-2023, 06:35 AM
#83
Sombrero
2018 30' Classic
St-Jérôme
, Quebec
Originally Posted by crispyboy
Very nice truck!
Thanks so much for the kind words, yes there was that 350 for the same price with 1000 lbs more payload but after consideration, I KNOW I would never use it!, as it is, this 3/4 ton truck with the trailer attached, the hitch weight, I will still have 1700 lbs of cargo, added to the cargo of the trailer 2200 it's, 2 tons of possible cargo!...if I use half of the 1700 Lbs I would be pretty loaded! I did not want to fall in the payload anxiety because then you end up buying a 450 Duelly!, I had to consider daily driving the thing as well! No sincerely this truck is the one, I think its absolutely gorgeous, equipped they way we want, and more than sufficient capacity wise! we're picking it up today!
God is the Sun
12-05-2023, 03:27 PM
#84
2023 25' Globetrotter
Ancient City
Looked at a lariat today with the 11500 gvw. If I add a topper and bed slide, I might go 350 hmmmm
12-06-2023, 06:41 AM
#85
Sombrero
2018 30' Classic
St-Jérôme
, Quebec
Yes topper and Bed-side that is a definite 350 IMO!
God is the Sun
12-06-2023, 06:56 AM
#86
2022 33' Classic
Chesapeake
, Virginia
Yep. F350 here, 12,400 GVWR. ARE topper and bedslide. 4200 lb payload.
