Old 01-31-2019, 10:38 AM   #1
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
TV Trip Odometer vs. Garmin GPS
I've been logging my Airstream travels since I started Airstreaming in 2006. I used my Garmin navigator's odometers to record the TV miles as well as the trailer's miles. A year ago, I upgraded my 2006 TV for a 2018 F-150 with all the bells and whistles.
I'm still logging miles for the truck and Airstream, now using both the truck's trip odometers and it's trailer accumulated mileage readout and the Garmin GPS. What I've noticed is that the truck gives me lower readings than the Garmin GPS.
I just completed a 1,100-mile trip, and these are the readings:
Truck: Trip 1,127.8; Trailer Miles 1,078.0
GPS: Trip 1,144.0; Trailer Miles 1,093.4
That's a 1.4% difference between the two. Both the truck's digital speedometer and the GPS read the same speed, and I checked them with an iPhone app—no disagreement. So, at the same speed reading, the truck's odometers are accumulating 1.4% fewer miles than the GPS's odometers.
I've been doing my Airstream maintenance based on the Garmin GPS distance for years and will continue to do that since that is the more conservative approach, but why would there be different readings between two devices?
Randy
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
SilverCabin is offline   Reply With Quote
Old 01-31-2019, 11:35 AM   #2
2007 22' International CCD
Historically vehicle speedometers and odometers are all over the map when it comes to accuracy, digital or not.
Our two Prius vehicles read speed as at least 2 MPH faster than GPS, and distance at least as bad. The 2012 Tacoma reads speed about 1.5-2 MPH LOW depending on tire wear. The 2002 Tacoma reads about 2 MPH high.
If I was looking for accuracy, I'm not going to find it on vehicle displays, obviously.
Feel free to skip the rest of the post...engineer hat on...
The problem is the difference between 'ACCURACY" and 'PRECISION' when you are talking measuring stuff.
Accuracy refers to displaying information that is correct based on some standard. In other words, if you put exactly 12 volts into some multimeter, it will display exactly 12 volts every time if it is properly calibrated.
Precision is just the ability of a display, given the same input to measure, to give the exact same output. It does not speak to accuracy--just repeatability under the same conditions of input and output.
So if you put exactly 12 volts into a precise digital meter, and it displays 12.1 volts every time you apply 12 volts to it, it is precise, but it sure isn't accurate or, for that mater, calibrated--its just precise and repeatable...
Unless you spend a lot of time (and $$) calibrating your measuring instruments, you can only assume they give a reference measurement, not an accurate measurement. For most of us humans, we tend to believe digital readouts, but if you carefully look at the specifications, they will be listed as Accuracy +- 3%, +- one digit. In other words, it is neither accurate or precise.
For casual use troubleshooting Airstream trailer electrical systems, a cheap Harbor Freight meter is 'just fine'. If you are calibrating industrial process equipment, you use a relatively expensive Fluke meter with an unexpired calibration sticker on it from the last time it was sent to the Metrology Lab and checked against the NIST-tracable and documented hugely expensive standards they used to calibrate it against every freaking six months....
So now you know more about this subject than you wanted to, assuming you read this far...bottom line, use the cheap meter. At least your measurements will be consistent until the next time you overload it or drop it off the roof of the trailer...(grin) Then just toss it and buy a new one. They run on smoke, by the way--that's why when the smoke leaks out they all quit working...
Old 01-31-2019, 11:54 AM   #3
Sag Harbor , New York
For dragging our small homes around the country, this is an acceptable margin of error IMO.
Avoid Analysis Paralysis.
Keep It Simple, Stu.
Look Up Once In a While.
[IMO]
Happy Trails!
Peter
Garmin recalls 1.25 million Nuvi GPS navigation devices for fire hazard Phoenix Computers, Internet & Satellite 3 08-29-2010 05:05 AM
Defective Odometer Byers Land Yacht/Legacy Motorhomes 5 03-29-2010 11:57 AM
garmin gps feedback PINKBIKE Phone, CB & Ham Radio 21 04-11-2009 05:04 PM
Garmin 2620 GPS unit wingfoot321 Electronics & Connectivity 1 09-11-2005 05:11 AM
Garmin Street Pilot 2610 GPS JaceBeck On The Road... 6 10-08-2003 06:59 AM
