01-09-2011, 03:27 PM
2010 27' FB Classic
N/A
Truck towing Showdown
01-09-2011, 03:33 PM
A.K.A "THE STREAM"
2010 25' FB International
Arlington
Originally Posted by Bluto
Only done in High Altitiude.
Bring it down to real time towing and the outcome would be completely different. Besides who races while towing.
Senseless test, IMO.
ALSO,......""
The first point was that we didn't test Ford’s "Job 2" engine calibrations for the all-new 6.7-liter Power Stroke V-8. The free powertrain software update for 2011 diesel Super Dutys boosts the ratings from 390 horsepower and 735 pounds-feet of torque to an astonishing 400 hp and 800 pounds-feet, eclipsing GM’s 6.6-liter Duramax V-8 rating of 397 hp and 765 pounds-feet. We didn't test the re-rated Ford trucks because they weren’t available at test time."""
Shane
01-09-2011, 03:45 PM
1967 22' Safari
1960 Caravel
Edmonds
ALSO,......""
Shane
So Shane, You don't own a Ford by any chance???
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
01-09-2011, 03:47 PM
A.K.A "THE STREAM"
Arlington
Well of course.....
I bleed Blue.
I can also read inbetwen the lines.
Shane
01-09-2011, 03:50 PM
2010 27' FB Classic
N/A
Shane the test is of the new Ford powertrain. Read it further.
01-09-2011, 03:52 PM
1967 22' Safari
1960 Caravel
Edmonds
Well of course.....
I bleed Blue.
Shane
What are you reading between the lines? That print can be very small and hard to read....I like to just read the lines and not read too much into anything.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
01-09-2011, 03:55 PM
A.K.A "THE STREAM"
Arlington
No Sir! Current Powertrain but not with current power upgrade.
Please read my quote in the 2nd post,,,from the article you posted.
Again, not a fair real world test.
Craziness. Any one of us would pull that much weight up that hill and down at a safe and comfortable speed, probably 4th gear and 45-50 mph, and keep an eye on the temps and fuel economy. Then, it's back to 65-70 for comfortable cruise. Heck, maybe 3rd gear and 40mph. I don't know. It's a random circumstance that few will ever do and I hope nobody actually races to see how fast they can go up that hill.
Shane
01-09-2011, 04:30 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
Looks to me like the Bowtie just kicked butt.Glad they wouldn`t give me more money for my 2500 HD,or I may have ended up with one of those blue ovals. lol. Dave
01-09-2011, 04:34 PM
A.K.A "THE STREAM"
Arlington
Shane
01-09-2011, 04:53 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
That was a very interesting read. I guess I've always leaned toward the GM Trucks even though I own 2 Ford cars. Between this test and the Trailer Life Magazine shootout of the 3/4 tons, it looks like Chevy is walking away with all the honors.
I am researching a new tow vehicle right now, and have narrowed it down to the Ford and Chevy. The Dodge just isn't up to what I plan to carry and tow. I'm shopping for a pop-up truck camper to put in a long bed single rear wheel diesel 1 ton and still pull Lucy at 7400# with a 1000# tongue weight.. The truck camper will go a little over 3000#. This will be a big load. I don't wan any disappointments with a new tow vehicle.
This test pushes me hard in the Chevy direction. The lack luster performance of Ford's engine brake system is a major negative for me. Chevy's engine braking function sounds miles ahead. We do a lot of mountain towing. The last thing that I want is to smell the brakes as I am careening downhill with 20,000+# of truck, camper, and Airstream.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
01-09-2011, 05:07 PM
A.K.A "THE STREAM"
Arlington
Brian
Shane
01-09-2011, 05:11 PM
2004 25' Classic
Prescott
We agreed with a few conditions: Chevrolet had to use test trucks purchased off the lot from Chevy and Ford dealers and the Super Duty had to have the 400/800 power ratings
The test was with the up-date on the Ford.
Julia & Bob
W/ Deedee & Boo
AIR #30685
01-09-2011, 05:19 PM
A.K.A "THE STREAM"
Arlington
BTW,.........Quoted from another site.....
"I did a little calculating and came up with some numbers which might explain the percieved difference in exhaust brake performance that was reported in the " Rumble in the Rockies" test. Considering the fact that GM chose the location and set up the parameters of the test it is not surprising that the results are what they are. Taking into account the different gear ratios and tire diameters of the two trucks, this is what I discovered. The GM down shifted into 2nd gear allowing the engine to rev to a comfotable 3570 rpm. This rpm pumped enough air through the exhaust brake to produce the necessary "negetive HP" that when multiplied by the gear ratio of 1.81 the truck was under control. At 50 mph in the Ford, if the transmission would have shifted into second, the engine would have reved to 5108 rpm. So it remained in 3rd where the engine was reving at 3350 rpm and not pumping enough air through the exhaust brake to create the necessary "negetive HP", when multiplied by the third gear ratio of 1.52 to keep the truck under control. With a little lighter load on the same hill the Ford may have felt more comfortable than the Chevy. I think it is more about gear ratios than exhaust brakes - and most about who was instigating the test. "
Shane
01-09-2011, 05:33 PM
1972 21' Globetrotter
nc
hummmm ford
01-09-2011, 05:38 PM
nc
a guy said on another forum that ford would of done better but that new exhaust brake was stuck shut.
he said he got it fixed then on the down hill run it stuck open.
01-09-2011, 05:56 PM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
Brian
Brian, I know you wanted to stick w/SRW for off-road...the 1 ton GM SRW have the greatest GVWR for SRW...you will be heavy with your full setup.
Check it out...can't go wrong with the D/A...
I hope the new Ford does better than the last couple of gens...time will tell...the rest of the truck is very nice...the verdict is still out on the new power train.
Bill
01-09-2011, 07:00 PM
Vintage Kin
Fort Worth
. . I'm shopping for a pop-up truck camper to put in a long bed single rear wheel diesel 1 ton and still pull Lucy at 7400# with a 1000# tongue weight.. The truck camper will go a little over 3000#. This will be a big load. I don't want any disappointments with a new tow vehicle.
Brian
There's a decent bunch on the truck camper sub-forum at RV.Net for yet more context and experience. That's a helluva load contemplated.
