Old 10-18-2020, 05:53 PM   #101
2008 28' Safari SE
Kemah , Texas
Tundra Tow Vehicle Capacity Seems Tight
We tow a 28 RB Serenity with a 2020 Tundra Crewmax. Like other posts the numbers are all within limits. I estimate we're at 80-85% GCWR.
The tundra and trailer rig pulls like a dream. However, at highway speed, 55-60 mph, uphill grades often bring engine revs up to ~4000. I normally slow down to keep the rpms below 4000 if I can. We average 9-10 mpg in hills and 11.5 on flat roads. Love the Tundra and plan a Colorado trip next spring. Any experience or comments would be appreciated.
dwight69 is offline   Reply With Quote
Old 10-18-2020, 09:22 PM   #102
2007 27' International CCD FB
San Diego , California
You might find it interesting that engines can be relatively less stressed using higher RPM than grunting torque.
Torque is directly proportional to cylinder pressures. Using less RPM means relying on more torque to produce the necessary climbing power, and cylinders correspondingly dealing with higher compression and heat loads. Not unlike biking, trying to lug a gear up a hill versus downshifting and using more strokes to ones advantage.
By allowing the engine to run at higher RPM, an engine can actually run less stressed, and cooler with more oil and coolant flow. While potentially using less gas as the A/F mixture doesn't have to be as rich for extra cylinder cooling.
This can also be true for the transmission as it has a better chance at locking up the torque converter, utilize gearing advantages, with more fluid circulation.
With the 5.7L, you are also be leaving 80HP+ on the table. Not saying you have to use all of it, but there are advantages to running at higher RPM at the same pace. It's a Toyota after all and these engines are reliable smooth running mills.
pteck is offline   Reply With Quote
Old 10-19-2020, 11:07 AM   #103
Peter417's Avatar
1966 17' Caravel
1972 21' Globetrotter
SW , Missouri
I agree. Use that power. These motors were designed for this.
I was in the mountains and I had about 42 pounds per HP. I used the motor and I did not keep up with traffic. Fully loaded with your Tundra you will be around 34 pounds per HP. You won't be a rocket ship but you will have no problems making it, provided you use the gears and power your truck has available.
Peter417 is offline   Reply With Quote
Towing: Tundra vs Sequoia vs Land Cruiser walter1 Tow Vehicles 47 05-29-2014 09:15 PM
Toyota Sequoia pdl2win Buyer Guidelines 2 02-10-2008 04:57 PM
TOYOTA Sequoia Ad Photos clancy_boy Tow Vehicles 3 01-16-2008 05:31 PM
Toyota Sequoia Towing an Airstream SE 23'? leetimes Tow Vehicles 16 09-03-2007 12:32 PM
Toyota Sequoia as Tow Vehicle Thegman Tow Vehicles 12 10-13-2006 11:15 AM
