Old 08-17-2020, 06:13 AM   #21
2016 16' Sport
Miami , Florida
Originally Posted by Roger Cordes View Post
Thank you so much. What, in your opinion, would be my “best choice”?
I’m not sure of the capability of you SUV so id rather not give an opinion. I just want to make sure you have al the information you need to make a decision.
Shiny16 is offline   Reply With Quote
Old 08-25-2020, 07:05 AM   #22
Johnnyooo's Avatar
2016 16' Sport
Colrain , Massachusetts
Originally Posted by Gills View Post
PLEASE Help I’m new to Airstream forum!!
We are closing in on a new 19ft Bambi and have some
concerns regarding my TV.
My 4Runner limits are 5000lb and 500lb at the hitch.
My TV has no problem with a heavy 17ft BW fishing boat
but I’m I pushing its limits with the 19 ft Bambi?
We want to eventually cruise around the USA with it!?
Specs on the 2021 Bambi 19 footer
Base wt 3650
Max GVWR 5,000
With a net carrying limit of 1,350
19 ft Bambi has a hitch at of “525” slightly over!?
Would my 4Runner with a good WD hitch do the trick!?
Hello Gills....I have a 2016 Bambi 16’ with a 3500 GVWR, and 350 LB tongue weight which was increased to 450 LBS because of some additional weight from segment protectors which I installed and a larger Battery.....I also changed from 14” to 15” wheels including the spare which added a little more to the tongue weight....I guesstimated that I added another 100 lbs of tongue weight... I towed with a 4 liter 4Runner which did a decent job of pulling it ... A had a couple of times when the tail wagged the dog so to speak and the 4Runner was at its limits... It struggles going up the mountains and the motor sounded like it was really working very hard at 4000 RPM..... I started to get concerned with the motor and how much it had to work to pull it....It did well on flat ground .... I used it for 2 seasons and it was decent but I decided I needed more power so I changed the 4RUNNER to a Sequoia and it made a huge difference... My personal opinion is your 4RUNNER is not adequate for a 19’ ... It’s way too close to the margins.....Especially for going up and down the mountains..... I really liked the 4RUNNER, but it just wasn’t enough power for mountainous terrain....
Johnnyooo is offline   Reply With Quote
2013 Toyota 4Runner and 2019 Basecamp X AirstreamCSH Towing, Tow Vehicles & Hitches 9 07-05-2020 08:14 PM
Weight capacity and towing Toyota 4runner V6 waf Tow Vehicles 2 03-10-2010 09:35 PM
Toyota 4runner towing capacity wonkabar Tow Vehicles 3 03-06-2009 07:38 PM
Toyota 4runner and 19' safari bebelee Tow Vehicles 5 02-14-2009 02:49 PM
Toyota 4Runner TV ? OhScottyOh Tow Vehicles 22 04-30-2008 10:47 PM
