Old 08-10-2020, 11:53 AM   #1
2007 25' Safari
Rogers , AR
Towing with "pizza cutter" tires?
My 2005 2500HD has a torsion lift and factory 16x6.5 wheels. It currently has 285/75R16s. This tire is too wide, minimum spec is a 7.5" wheel, and I broke a belt on one while towing the Airstream this weekend.
Because it is lifted I'd like to maintain a 33" tire, but have a correct size for the wheel width. That leaves me with one tire size option: 255/85R16. This tire is about the same width as the OEM tires, just taller. Hoping the narrower tread will also aid in fuel economy. The truck got 12-13mpg on this weekends trip to the highest point in Arkansas. There are few options in this size and they are all aggressive off-road tires. I've pretty much narrowed it down to the BFG KM3 Mud-Terrain.
Does anyone have an experience with towing on tires like these?
2007 Airstream 25FB Safari LS - GY Endurance Prodigy Wireless - Andersen
2005 Chevy Silverado Crew Cab 2500HD Duramax Allison
2008 Porsche Cayenne Turbo 500hp/516lb-ft
2014 Porsche Cayenne Turbo S 550hp/553tq
2005 GMC Sierra Crew Cab 5.3L built 4L60e, 40k Tru-cool
Mr. Merk is offline   Reply With Quote
Old 08-10-2020, 12:14 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I have towed alot with BFG ATs. I ran them over 20 years on one of my trucks. No complaints....I don't think I would like the noise of the Mud Terrains.
CRH is offline   Reply With Quote
Old 08-10-2020, 12:18 PM   #3
2007 25' Safari
Rogers , AR
I would probably jump on K02s if they were available in the needed size.
Old 08-10-2020, 03:00 PM   #4
2019 27' International
Western NC , North Carolina
That is what I run on and would suggest.
2019 International Serenity 27 FBQ “TC Escape”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 08-11-2020, 09:49 AM   #5
1964 30' Sovereign
Ione , CA
Tip #1 - Buy some slightly wider wheels. You have plenty of room in the wheel wells.
Tip #2 - Unless you spend a lot of time off-road in mud get All Terrain tires. Mud Terrains have 20% to 30% less rubber on asphalt and wear much more quickly on a 3/4 ton truck. You'll also get worse mileage with Mud Terrains due to greater unsprung weight. Most importantly, your braking distances will be 4 to 5 feet longer at 55 MPH without the Airstream...probably 10+ feet longer pulling your trailer.
Tip #3 - Look at Cooper Discoverer ST's. I had run one set each of Goodyears and BFG tires on our Dodge 2500 with limited mileage results. Found Cooper Discoverer ST's were being used by our local energy utility (we live in the Sierra foothills) for their off road trucks. Tried a set and got 30% more wear than the prior Goodyear MT's and BFG All Terrains. They also have excellent traction off road and in snow...and pretty good in mild mud. Last month, I pulled a Fish and Game 1 Ton backwards up a muddy hill when they got stuck planting fish in a lake. Two half tons with MT tires had spun out trying before I helped the driver (ok, I admit that throttle control may have helped me and the F&G driver too...but the Coopers worked great).
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 08-11-2020, 11:14 AM   #6
2007 25' Safari
Rogers , AR
Switching to the OEM Hummer H2 wheels would get me slightly wider 17's, but I'm a huge fan of the OEM 16x6.5 wheels.
I always do this to myself, and pick odd sizes that limit my tire options to a small group of abnormal tires. I run 2" wider than original, but OEM 16" wheels on my 80's Porsche 911 and that gives me two options for tires. I drive the car hard all over the country and in the past two years have run through 3 or 4 sets of DOT legal, but not for street use R-compound tires.
Now I'm looking hard at the Toyo MT tires. A little taller, stiffer and wider than the BFG option.
Old 08-11-2020, 12:56 PM   #7
amxpress's Avatar
2021 22' Bambi
Clayton , North Carolina
Why not use Goodyear Endurance tires? Their 255/85R16 is 33” in diameter and will work on a 6.5” rim.
https://m.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Endurance&pa rtnum=585NR6END&vehicleSearch=false&fromCompare1=y es
amxpress is offline   Reply With Quote
Old 08-11-2020, 02:13 PM   #8
2007 25' Safari
Rogers , AR
https://m.tirerack.com/tires/tires.j...omCompare1=yes
Because those are trailer tires.
Old 08-11-2020, 02:31 PM   #9
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
I have 16” non radial E rated truck tires , works fine.
bibbs is offline   Reply With Quote
Old 08-11-2020, 03:59 PM   #10
amxpress's Avatar
2021 22' Bambi
I was admiring your picture of your truck towing your trailer. Pardon my ignorance but why don’t you want to install a tire designed for a trailer on your trailer? Am I missing something?
Old 08-11-2020, 04:16 PM   #11
2007 25' Safari
Rogers , AR
Haha, yes. We're talking about tires for the truck!
Old 08-11-2020, 08:52 PM   #12
Mikebrady62's Avatar
Rogers , Arkansas
Mr. Merk,
I just put on some new Cooper AT3 all terrain 10 ply tires, Mine happen to be 20" but I'll bet Norm's in B'Ville has them instock in your size. Just not sure if they would fit your wheels?? They are much quieter than I expected. Not much different from my Goodyear LT road tires the truck came with. They got me out the door with a front end alignment, balancing and road hazard for right at $1100.00 No one else around could touch it on 10 ply tires.
Good luck with whatever you decide to go with!
Mikebrady62 is offline   Reply With Quote
Old 08-12-2020, 05:37 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
10 ply rated equals an E load tire...plies don't apply.
I've always used Michelin E load on the TV.
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 08-12-2020, 06:53 AM   #14
2014 27' Flying Cloud
Wenatchee , Washington
You’d definitely want those “pizza cutter” tires on your truck if you lived where it snows a lot in the winter. (Living in WA, I don’t run anything but snow tires on my truck (year round.)
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 08-12-2020, 07:14 AM   #15
2007 25' Safari
Rogers , AR
Originally Posted by Mikebrady62 View Post
Mr. Merk,
I considered Cooper ST Maxx as it is available in my size but it is quite a bit shorter than the BFG or Toyo options.
Lots of good advice in this thread but unfortunately most of the options mentioned aren't available in tall & skinny.
Old 08-13-2020, 12:31 PM   #16
bibbs's Avatar
1975 26' Argosy 26
Vista , California
Go to etrailer they have what you are looking for
Old 08-13-2020, 02:34 PM   #17
2007 25' Safari
Rogers , AR
How so?
Ended up ordering a set of 5 Toyo Open Country MT in 255/85R16. They'll be here tomorrow. We'll see how she handles.
Old 08-15-2020, 09:22 AM   #18
2007 25' Safari
Rogers , AR
worn 285/75R16 Terra Grappler vs new 255/75r16 Toyot MT. you can see the broken belt on the top of the 285
Old 08-16-2020, 04:50 AM   #19
Rogers , Arkansas
Those certainly have some meat to them. Should feel plenty supportive in curves. I hope they are fairly quiet on the road for you.
Old 08-16-2020, 11:38 AM   #20
Berryton , Kansas
You could go to 265/75's on 1 ton SRW (single rear wheel) Chevy/GMC OEM wheels. 265's only require 7" rims and that's what these are, 7". Lots of those SRW wheels available in the junk yards. No fittment problems whatsoever.
Ron Nielson is offline   Reply With Quote
pizza dough recipe- using bread maker waninae39 Stella's Kitchen 1 08-05-2019 01:51 AM
Pizza in a 1973 Airstream oh2bcarefree Stella's Kitchen 12 08-09-2013 01:14 PM
Cardboard Box Oven v2.0 + 20" Pizza GCinSC2 Stella's Kitchen 1 09-18-2011 03:28 PM
