Closed Thread
Old 10-28-2020, 08:48 AM   #141
2018 25' International
Slidell , Louisiana
Addition of a tow vehicle rear stabilizer bar is not generally recommended for towing particularly near the upper limits for the vehicle. The bar reduces roll and improves handling when not towing but it unloads the inner rear wheel when cornering while towing and increases rear axle wheel slip reducing safety margin for oversteer.
To jcl's point on slalom tests, they are great for handling performance but not a good way to test for sway oversteer instability. Those interested in testing towing safety margin would repeat the SAE tests. Those wishing to create an impressive distraction may choose other demonstrations.
Brian
BayouBiker is offline
Old 10-28-2020, 05:23 PM   #142
Collyn's Avatar
Church Point , NSW
Originally Posted by jaybauman View Post
Collyn
What are the error bars on the blue bold statement? For example, I have ordered an Airstream with 10,000 lb. GVWR (please forgive the barbaric units) and my tow vehicle weighs about 8500 lbs. when we're fully loaded up for a camping trip. I'll be pulling it with a "1 ton" truck. Practically speaking, I don't know how to get a heavier tow vehicle than what I already own. While I'm not challenging your knowledge or logic, this just doesn't feel right to me...especially when my truck is certified by GM to be able to tow 20,000 lbs. with a conventional hitch. Can you help me rectify these statements?
Jayson
Jayson
I can understand your confusion re this (you are far from alone).
The problem is that the vehicle industry does not adequately define (and often barely at all) what it means by 'towing capacity'.
In essence, it is not what a vehicle can tow via an overhung hitch - it is what it can tow 'on the end of a rope' and stop and restart on a specified gradient.
Travel trailer owners rarely appear to realise they are a tiny minority of those towing trailers. Most by far are the military and tradespeople. And what most tow is about two tonnes on a twin axle trailer about 16 feet long. And not at 60 plus mph.
The only way you realistically tow a long and heavy travel trailer reasonably safely is to tow it with something that at least as heavy, have 10%-12% nose weight and above all to keep speed below 60 mph. With your rig I would suggest a lower maximum when descending any hill that - particularly if it has any bends. Also to keep the tow vehicle at its maximum legal laden weight - use sand bags if necessary. Also keep you tow vehicle rear tyre pressure 10psi higher than the front (they should at normal advised pressure).
The Hensley hitch will assist but most other 'stability' aids assist their vendor's bank balances - not the vehicle's. This particularly applies to any frictional device.
Re 'barbaric units' - it is a shame the USA public does not use metric units (all US engineers etc have done so since 1950 and many before that). It makes physics and mechanics so much easier to explain.
Collyn
The problem is not so much what people do not know, it's what they think they know that simply is not true.
Collyn is offline
Old 10-28-2020, 05:28 PM   #143
DKB_SATX's Avatar
Alamo Heights , Texas
Collyn can't have paid much attention to US roads if he thinks most American tradesmen don't tow their utility trailers over 60 mph.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
DKB_SATX is offline
Old 10-28-2020, 06:14 PM   #144
jaybauman's Avatar
2021 33FB Classic
2019 30' Flying Cloud
Katy , Texas
Originally Posted by Collyn View Post
Jayson
Collyn
Thanks, Collyn
In my previous setup, I had 8500 lb. truck, 8200 lb. trailer that's 31 ft long, Propride (Hensley) hitch, 60psi steer, 80psi drive, 80psi trailer, and 16% tongue weight. My max tow speed was 65mph. In general, I'm nearly within your recommended ranges, albeit with slightly greater velocity.
I've sold that trailer. New trailer will be 33 ft. long and should weigh (estimate) about 9500 lb. when loaded. Trailer GVWR is 10,000 lb. I will use same hitch, same truck, and same tire pressures. In terms of a sensitivity analysis, how critical is it that my trailer will outweigh my tow vehcial by 1000 lb. (12%)? For me this is really an academic exercise because practically I'm not likely to make any further changes. It's more piece of mind. We spend most of our traveling miles in flat Texas. We only get deep into the Rocky Mountains for a single multi-week trip once per annum. Thoughts?
Thanks again for your knowledge and advice.
-Jayson
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
jaybauman is offline
Old 10-28-2020, 11:41 PM   #145
Collyn's Avatar
Church Point , NSW
Thanks, Collyn
-Jayson
Jason
I can only (as an engineer) ethically advise you to reconsider that proposal.
While not raised on this thread, excess length is as bad as excess weight (and you propose to increase both.
It is not feasible (or legally wise) to attempt to quantify this, but it is virtually a recipe for an accident looking for somewhere to manifest. It's critical speed is likely to be as low as 50 mph.
I suggest you obtain a second opinion from a USA specialist in this area.
Collyn
Collyn is offline
Old 10-28-2020, 11:51 PM   #146
Collyn's Avatar
Church Point , NSW
Having visited the USA over 20 times and driven across and up and down it several times I am well aware that American tradesmen may tow above 60 mph.
You are overlooking that those trailers are typically only 16 ft or so long and weight a laden two or so tonnes. The speed at which they are likely to start swaying is way over 60 mph.
(Do you not have tradeswomen there too? Or, being mostly saner than men, do they not tow above 60 mph?)
Collyn
Collyn is offline
Old 10-29-2020, 12:28 AM   #147
DKB_SATX's Avatar
Collyn
I am not overlooking anything, I'm pointing out that your statement (which you actually DID make, though you seem to be deying it) does not comport with reality:
ó David
DKB_SATX is offline
Old 10-29-2020, 04:24 AM   #148
2012 19' International
Southeastern MI , Michigan
Originally Posted by panamerican View Post
You and Bob are talkin' my language. I realize this is off topic, but really 10w40 without zinc additive? Never thought of that. Then again, up until maybe 5-6 years ago I also never considered zinc additives either....
I worked in a shop where we worked exclusively on flatheads. The owner used only valvoline 10-40 and we never had a single issue. They didnít put it in when they were new and they donít need it now.
2018 International Serenity 27' FB
Michelin 16Ē tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
Countryboy59 is offline
Old 10-29-2020, 06:05 AM   #149
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Maybe thats because the oil back then had zinc already in it.
If you actually own a flattie, it's more important use quality not what brand of quality.
I use Z-Rod, "Bertha" has been on the road since new, never restored, safety wire still on the hood hinges and running just fine.👍
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
ROBERT CROSS is offline
Old 10-29-2020, 06:40 AM   #150
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Certainly youíre not advocating for vehicles with factory installed rear stabilizers to remove them when towing? Also, 70+ percent of my driving is without my AS. I noticed improved handling with the rear stabilizer. I donít think I want to remove it..
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline
Old 10-29-2020, 07:01 PM   #151
Slidell , Louisiana
You're well under the towing limit so no worries. The factory generally leaves them off depending on suspension specifics to get a higher tow rating. My comments wasn't directed at you but others who may be reading and are closer to the vehicle rating limit. I completely agree you are in good shape. I suppose I could have been more clear. Thanks for the pushback!
Brian
Old 10-29-2020, 07:23 PM   #152
Collyn's Avatar
Church Point , NSW
Re: I am not overlooking anything, I'm pointing out that your statement (which you actually DID make, though you seem to be deying it) does not comport with reality:
Re my
'Travel trailer owners rarely appear to realise they are a tiny minority of those towing trailers. Most by far are the military and tradespeople. And what most tow is about two tonnes on a twin axle trailer about 16 feet long. And not at 60 plus mph'.
Can only assume I had a senior moment (but as 90 plus that can happen!).
That 'blued' should not have been there.
Mea Culpa
Collyn
Collyn is offline
Old 10-30-2020, 07:05 AM   #153
GettinAway's Avatar
Wildwood , Missouri
Thanks. I am not an engineer, so I put some weight on the thoughts of those that are. Lots and lots of miles of experience which carries weight also. I continue to learn. One of the reasons I follow these tow threads. Along with the entertainment value. Every so often I have the thought, ďjust buy a one ton dieselĒ and Iíll never have to read another TV thread again. But whereís the fun in that?
2020 25GT FBT
Old 10-30-2020, 07:40 AM   #154
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
I think the tow vehicle thread is the most entertaining thread I've seen here. It's a great combination of useful information, useless information, and general banter. There's always some drama!
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline
Old 10-30-2020, 02:38 PM   #155
BoatnutG2
BoatNutG2's Avatar
2015 28' Flying Cloud
2013 Interstate Coach
Huntington Beach , California
We are happy with the performance of our same 2018 F150 and our FC28
BoatNutG2 is offline
Old 11-01-2020, 06:55 AM   #156
ďIf you actually own a flattie ď lol. Thatís a good one.
I use regular 10w40 valvoline in my current flathead (1929 Ford) and have in every one I owned, or worked on, since my first one in 1992. Zinc additive is a myth. Always has been. I usually stay out of these zinc arguments as Iíve owned and worked on more flat tappet engines than most, especially those on an Airstream forum. Letís go back to arguing about torque (my new F350 has 1050 ft lbs) or which tires are best.
Michelin 16Ē tires
Hensley Arrow hitch
Old 11-01-2020, 06:57 AM   #157
The first time you need to merge with that one ton diesel and you mat it and are doing 75 at the end of a short entrance ramp you will understand.
Michelin 16Ē tires
Hensley Arrow hitch
Old 11-02-2020, 06:31 AM   #158
GettinAway's Avatar
Wildwood , Missouri
Donít get me wrong, Iíd like to own one. I do appreciate the advantages, thatís for sure. I guess itís my minimalist nature that keeps me from switching. Itís like pounding in a small finishing nail with a sledge hammer. Well, maybe thatís a bit of an exaggeration.
We will see. If we start towing more miles, go to more places, it would be worth the added cost, and hassle. Iím retired now, Iím ďsupposedĒ to have more free time..
2020 25GT FBT
Old 11-02-2020, 06:49 AM   #159
dznf0g's Avatar
Oswego , Illinois
Ya see........there is no collective understanding. I can and have easily hit 75mph for a merge with my 6.2L gas 1500 while pulling my 30' Classic. Passing on 2 lane roads is equally effortless. After all, that engine's roots are Corvette and Camaro SS. It is unbelievably torquey in all the right places with the 8 speed, let alone the newer 10 speed.
-Rich-
dznf0g is offline
Old 11-02-2020, 06:55 AM   #160
TETO...Maybe if you had used a zink additive you wouldn't have had to work on all those 'flatties'...another 'good one'.😂
Notice the safety wire on the hood hinge, engine never been out never been apart.
Tahawus
RLC
Closed Thread
2012 27 foot AirStream Classic - 1/2 ton vs 3/4 ton Truck Question westie 978 2011 - 2015 Classic (all lengths) 82 07-14-2018 08:43 AM
Hitch system for 3/4 ton or 1 ton truck (GMC) Crazycanucks Tow Vehicles 31 04-02-2017 06:13 AM
1/2 ton vs 3/4 ton towing? subfan1 Tow Vehicles 7 12-13-2007 03:10 PM
