Old 03-30-2023, 05:51 PM   #1
2021 20' Caravel
Newburyport , Massachusetts
Towing a Caravel 20FB - newbie
Hi. We are new owners of a 2021 Caravel 20FB. GVWR = 5000, Dry Wt = 4300, hitch weight = 565
We would like to tow with a 2022 Nissan Pathfinder Platinum - 4WD, V6, 3.5L
Max towing = 6000
GAWR = 2943 FR and 3373 RR
GCWR = 11,100
Does anyone tow with this vehicle. Are we cutting it too close? Thanks!
jedpetty is offline   Reply With Quote
Old 03-30-2023, 06:52 PM   #2
2019 22' Sport
High River , Alberta
The numbers work, and you can readily buy a suitable hitch receiver.
It’s a very good engine, now mated to a proper automatic transmission. A guess - you will probably tow in 5th or 6th gear notwithstanding the fact it’s a 9 speed transmission. Power is more than adequate, and these Nissan engines like to rev. (My personal car has the 3.7 version of this engine.)
I wouldn’t hesitate to go with this combination. As always, proper weight distribution setup is key.
AlbertF is offline   Reply With Quote
Old 03-30-2023, 08:29 PM   #3
2021 20' Caravel
Thanks. That give us some comfort. We will likely try it on some short trips and just evaluate it as we go.
Old 05-27-2023, 04:38 PM   #4
2017 20' Flying Cloud
Williamson County , Texas
Key will be watching your payload so as not to exceed max or your rawr (especially).
2018 GMC Canyon V6 Mallet Supercharger
2000 Chevrolet K2500WT 454
SYC2Vette is offline   Reply With Quote
Old 05-27-2023, 04:50 PM   #5
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
Check your tongue allowance on the hitch. Your trailer will be heavier on the tongue weight by about 100 lbs. and you need to add the weight of your hitch too.
Our Ridgeline had a limit on the hitch of 600 lbs. We were just at that with out 22FB that has a published weight of 422 lbs. The reality is usually greater.
Some of the unibody SUV’s have a rather low limit which you should be able to find in your owners manual. The trick is to be able to measure it. A Sherline scale is a good choice to determine what the trailer tongue actual weighs.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 05-27-2023, 06:01 PM   #6
The battery options (single lithium vs dual agm) and propane tank size are a relatively easy way to get your tongue weight down to a reasonable level. Of course watch what you put under the bed too.
Old Yesterday, 07:11 AM   #7
2007 16' International CCD
Somewhere , Colorado
As pointed out above, you need to verify the vehicle’s maximum weight spec’s for the hitch, and probably go to a scale to determine your trailers actual tongue weight. Not safe to exceed that limit.
Then, subtract the actual tongue weight from your vehicle’s payload which is on a sticker on the door jamb. The difference is what you can load into the vehicle, including the weight of passengers. For example, the payload is probably about 1,400 pounds and with a tongue weight of 600 plus 300 pounds of people you will have 500 pounds remaining for all of your stuff. That is not a lot.
Not mentioned previously is the subject of performance, by which I mean the ability to accelerate when needed and to maintain speed on hills and at elevation. This is a personal judgment, but you should be aware the the industry established performance standards are very low — equivalent to a 1962 VW bug.
Depending on your camping style and personal performance standards, this could work or you may prefer something more robust.
field & stream is online now   Reply With Quote
Old Yesterday, 08:07 AM   #8
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
we tow our FC 25FB QCH with an Audi Q5 sport
CANAM RV in London, ON made a reinforcement hitch for our Q5
we use WD and Sway
no issues with towing
2023 25' FB with hatch and Queen beds
NCR , Ontario
VE3HIU since 1978
waninae39 is offline   Reply With Quote
caravel
Ordered a '21 Caravel 20FB -- any specific items to watch out for or modify Flat6Fan 2020 And Newer Caravel 5 02-19-2021 09:20 AM
Towing Bambi 20FB with 2020 Ford Explorer ST JWAUGH2020 Towing, Tow Vehicles & Hitches 8 08-24-2020 02:30 PM
Caravel 20FB Thread! Jason in TX 2020 And Newer Caravel 33 07-16-2020 10:33 AM
Tires for a 2013 Toyota 4Runner towing a 2020 Airstream Caravel 20FB 4Runner Tires 2 06-19-2020 04:09 PM
Buying 2020 Caravel 20FB - Which Blue Ox for 2016 F150 Limited? Jason in TX Towing, Tow Vehicles & Hitches 15 09-07-2019 12:13 AM
