Old 08-25-2020, 05:55 PM   #21
2019 25' International
Providence , Senior Electrical Engineer
Originally Posted by Jason P M View Post
It’s a digital temp gauge on the lcd driver info display right in front of steering wheel. I assume it replaced the analog gauge. It’s not an “idiot” light. It gives the actual temp. I was driving around without any load today and it was registering 150-160.
What was the external temperature when you were reading those temps?
Sounds about right for normal driving in mid 80's temperature.
kittmaster is offline   Reply With Quote
Old 08-25-2020, 05:57 PM   #22
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thats exactly where ours is w/o the AS.
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 08-25-2020, 06:08 PM   #23
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I don’t disagree in principle. What makes me think it would be fine is that the only difference between the 2018 suburban with the “regular” towing package rated at 6000 max trailer and 12000 GCWR, and the suburban with the “max” trailering package rated at 8000 max trailer and 14000 GCWR, is the rear end. Regular towing package has stock 3.08 rear. Max towing package is 3.42 rear. Everything else is identical - frame, engine, springs (mine does have air springs).
That being the case, it could work, but is not optimum. Even with the max tow rated at 14,000, the total of the two GVWRs is 14,800. Could be done with careful attention to what is loaded. A friend of mine at work, also a system engineer, once said when referring to design of hardware for his sailboat, "...overkill is just about right."
Old 08-25-2020, 08:13 PM   #24
2007 22' International CCD
Towing 25ft GT with 2018 Suburban
Love that quote. I’m an alumni of Macgyver University and the Department head of the local Department of Overkill Engineering.
Old 08-25-2020, 08:34 PM   #25
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
GM is very squirrelly with their definitions of various tow packages. I have a 2018 GMC Sierra Denali 1500 tow vehicle. It has an integrated trailer brake controller and a 3.42 rear end, but it does not have the Max trailering package. It has the trailering equipment package, listed on the window sticker. There is also an option called the enhanced towing package. GM doesn’t release details on any of these packages. When I look at the door jamb sticker on my truck, the capacities fall in line with the standard capacities, not any of the enhanced packages. It’s very difficult to determine exactly what GM trucks can do without extensive research. I asked my GMC service advisor about this when I went in for my last oil change, and it was like I was speaking a foreign language. He had absolutely no idea what I was talking about.
Dennis C is offline   Reply With Quote
Old 08-25-2020, 08:56 PM   #26
2021 25' Globetrotter
Kinnelon , New Jersey
Yes about 85 outside.
Jason P M is offline   Reply With Quote
Old 08-25-2020, 08:57 PM   #27
Thanks Bob.
Old 08-25-2020, 09:10 PM   #28
I generally fall into that camp too. At some point in the next couple years I would probably trade my 2018 suburban in for the new model and get the 6.2L with the 3.23 gears. Trying to avoid biting that bullet today. I took my 2003 suburban to Baja and left it there. Might have to bring it back. That truck has 7100 tow capacity with a base engine and 3.73 gears. Fuel economy wasn’t the primary factor on that truck.
Old 08-27-2020, 07:14 AM   #29
We are at JC now. Yesterdays towing, 87 ambient, thru the hills towing... 190 max.
Tahawus
RLC
Old 08-27-2020, 08:31 AM   #30
Who is working on your trailer?
We had Steve on our last trip and Brandon on our 1st trip.
Just axles or other stuff too?
What is the wait room like, anyone hanging around?
Old 08-27-2020, 11:58 AM   #31
Matt is doing the axles. DW wanted him to look at the broken storage drawer slides but the drawer works just fine sliding on the floor and the latch still holds it closed ...plus it's just my stuff in there anyway.
Folks come and go in the waiting room, they take your temp once when the RO is written and if in a small group inside most all will mask up...all in all pretty darn good.
They are pumping them out in the new building down the road but it's not open to the public yet....it's unbelaivwblr
I'll post some pic's when we get home.
POI...not only was I waring out one new tire, but Matt said both axles were worn and the axle was NOT bent at all, just worn out.
Some folks here know how I have babied them since realizing the axle rating vs GVWR descripency .(off the ground every winter since new). My takeaway....the trailer really should have had a higher rated axle right from the start.
Bob...live from the AS Service Center
Tahawus
RLC
Old 08-27-2020, 12:56 PM   #32
Sounds exactly like what we had when we were there.
Good to see they are getting it all resolved.
Live from Rhode Island....Chris
Old 08-29-2020, 05:12 PM   #33
Back from JC
A few pic's....The new building is up and running but not open to the public.
The Service side is swamped...There must have been over a hundred tagged trailers waiting in the lot.
New SWAG from the money sponge shop.😂
ID:	377199   Click image for larger version
ID:	377201   Click image for larger version
ID:	377203   Click image for larger version
ID:	377207   Click image for larger version
Tahawus
RLC
Old 08-29-2020, 05:32 PM   #34
Thanks for the pics.....looks like they got you all sorted......safe journeys home.
Old 08-29-2020, 05:58 PM   #35
We were slowed down by "Laura's" 50mph horizontal rain.
100mi at 30-40mph to finally get out of it. Good roads and light traffic and towing an Airstream made outrunning doable. Once out we rested overnight 70mi from home.
The Service side was 5 stars as usual, Matt was outstanding and had everything done in one shift.
The TerraPort was full, with at least 100 tagged units in the back lot waiting for completion.
The new facility is HUGE, couldn't get inside but they are pumping them out, hope it's not too fast though.
Tahawus
RLC
Old 08-30-2020, 01:02 PM   #36
Newland , North Carolina
Hi I have a 2018 Suburban Premier. I am considering purchasing a 25FB Globetrotter. Anyone have experience pulling a late model 25ft with a late model Suburban?
We towed a 23 foot Flying Cloud with a Yukon Denali from North Carolina to San Diego and back with many side trips along the way.
The check engine light never came on. Yeah!
7Newland7 is offline   Reply With Quote
Old 08-30-2020, 02:00 PM   #37
2018 27' Tommy Bahama
Virginia Beach , Virginia
I am pulling a 27FB Tommy Bahama with a 2018 Chevy Tahoe RST with towing package and 6.2 liter V8. It works well but I understand the longer Suburbans have a 500 lb less tow rating than the shorter Tahoe. I believe my rating is 8500 lbs with a 7,700 lb fully loaded trailer - pretty close to max. I assume the 25 weighs less.
Stellablue is offline   Reply With Quote
Old 08-30-2020, 06:11 PM   #38
Thank you! Yes the suburban towing capacity is about 400 less than the Tahoe. The other difference between your Tahoe and my Suburban is mine has the 5.3L engine. The Suburban with the 6.2L would have 8000 lb trailering capacity.
Old 05-27-2021, 04:09 PM   #39
Grassy Creek , Kentucky
Wanting to Tow a 25ft RB with a 2016 Suburban LT
Hey, Everyone!
I know that this as more than likely been asked and answered, however, this is merely to calm my fears. I'm looking to buy Flying Cloud 25ft RB in the very near future and I'll be towing it with a 2016 Chevy Suburban LT. I intend to have a Hensley anti-sway bar installed on my SUV but I'm curious if my vehicle will make the cut. HALP!!
OldJumper71 is offline   Reply With Quote
Old 05-27-2021, 05:40 PM   #40
StreamNTyme's Avatar
2007 25' Safari FB SE
2000 30' Excella
1999 30' Excella 1000
Low Country , South Carolina
Images: 27
If you really want an SUV you need a Ford Expedition w extra long wheel base, heavy duty tow package, 3.5 turbo engine, 4 wheel drive rated at 9300 lbs. We tow our 25' FBSE with this Expedition SUV and a Propride hitch. Just returned from the nearly vertical steep hairpin turns in the Utah mtns, SUV did not even sweat..it just went straight up the mountains with no strain. Felt very safe on some really terrorizing roads. Super control on the steep downhill hairpin curves. We towed through a 40/50 mi. hr. blowing snow blizzard in 4 wheel drive; lots of trucks and cars in the ditches, we had no problem, no sway. This is our 3rd Expedition, its very comfortable and safe, the SUV just gets better and better.
Safe Travels.
StreamNTyme
StreamNTyme is offline   Reply With Quote
Towing 25ft airstream with 2018 Suburban Jason P M Towing, Tow Vehicles & Hitches 14 09-23-2020 09:42 PM
Towing a 25ft Airstream down Hwy 1 Maggiefoss On The Road... 27 03-30-2013 10:39 PM
2005 Airstream Safari 25WB 25Ft Travel Trailer S2005 Airstream Safari 25WB 25Ft Trave eBay Watch Airstreams on eBay 0 04-10-2012 02:10 PM
Nice 2007 airstream safari 25ft travel trailer snice 2007 airstream safari 25ft trav eBay Watch Airstreams on eBay 3 12-31-2011 02:09 PM
Nice 2007 airstream safari 25ft travel trailer snice 2007 airstream safari 25ft trav eBay Watch Airstreams on eBay 0 09-07-2011 08:50 PM
