Old 05-19-2024, 08:32 PM   #1
ijoe13's Avatar
Seattle , Washington
Tow Vehicle - Mud Flaps/Rock Guards
I have a Ram 2500 with a 2” lift and slight offset. I’m considering adding a wide mid flap / rock guard mounted at the hitch receiver to avoid potential rocks flying into the AS I’ll be picking up soon. Anyone else running a similar setup? Which make / model flaps should I consider?
ijoe13 is offline   Reply With Quote
Old 05-20-2024, 02:00 AM   #2
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
Rock tamers
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - ďFly Fish InnĒ
2023 F150 XLT
FishByFly is online now   Reply With Quote
Old 05-20-2024, 06:31 AM   #3
JJTX's Avatar
2024 23' International
South of Austin , Texas
Originally Posted by ijoe13 View Post
I have a Ram 2500 with a 2Ē lift and slight offset. Iím considering adding a wide mid flap / rock guard mounted at the hitch receiver to avoid potential rocks flying into the AS Iíll be picking up soon. Anyone else running a similar setup? Which make / model flaps should I consider?
Get rid of the lift and You will have fewer problems and more things will fit and line up correctly.
I see daily several brands or styles of rear flaps that span the back of the bigger trucks, but when you lift it, it reduces the effectiveness. A 2 inch lift at the wheels translates to several at the rear bumper.
In my view, you have one or the other, a tow vehicle, or a lifted truck, not both.
JJTX is offline   Reply With Quote
Old 05-20-2024, 10:20 AM   #4
pjshier's Avatar
2017 27' International
Wasilla , Alaska
Rock Tamers for us
Our late model F350 and now F250 are somewhat "tall" from the factory so wheel well mounted flaps are inadequate. Learned the hard way attempting the Denali Highway during the first year of ownership. Picked up dents in the protectors and one crack in the plastic window shield.
Been using Rock Tamers since and no new damage, even traversing the common areas of highway construction that are part of life here every summer. There are other interesting solutions, but at the time the Rock Tamers were easiest and reasonable cost.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 05-20-2024, 11:31 AM   #5
2014 19' International
Port Townsend , Washington
No extra lift on my F-150 but have Towtector setup and it worked great on nasty Montana country roads. But must say I have not used it since those trips. It slips on rather easily and seems to help, maybe, a bit more on kkeping the dust down than the traditional "mud flaps".
LBelle is offline   Reply With Quote
Old 05-20-2024, 12:51 PM   #6
2022 33' Classic
Chesapeake , Virginia
Interesting thread. Wish we had installed Rock Tamers earlier than we did. Hoping they help us in Alaska this summer.
BGClassic is offline   Reply With Quote
Old 05-20-2024, 04:18 PM   #7
2022 25' Flying Cloud
Tualatin , Oregon
I also wish I had rock guards before I went too fast down a recently prepped gravel road. I looked at Rock Tamers but went the DIY route.
Superstrut from the big box store, bolts, washers and some used conveyor belting.
Steve
ID:	443602   Click image for larger version
TitusNW is offline   Reply With Quote
Old 05-21-2024, 01:33 PM   #8
hikingcamera's Avatar
2024 25' Trade Wind
Those towtector look nice, unfortunately it sounds like they will not work with my setup without extending the hitch further from the truck, which I'd rather not risk changing my tow dynamics. Looks like I may go with some rock tamers instead. The only dent we got in our last trailer was probably too high up and in too awkward a location (right between the rock guard and the window guard) to have been from the rear wheel, but still, I don't want to have to make another insurance claim like that one.
hikingcamera is offline   Reply With Quote
Old 05-21-2024, 09:33 PM   #9
2022 27' Globetrotter
DALLAS , TX
Duraflaps work great. The extra long, extra wide version is equally effective vs rock tamers.
We have them on our F350. Lots of dirt and gravel roads and boondocking behind us and our Airstream and truck has zero damage.
ID:	443651   Click image for larger version
foobar is offline   Reply With Quote
Old 05-21-2024, 10:14 PM   #10
2024 25' Trade Wind
I was looking at those too: would be a lot more ideal… I hate the bulk of the rock tamers.
How was the install?
Old 05-22-2024, 03:21 AM   #11
baggs's Avatar
2013 23' FB International
aldinga beach , south australia
rock tamers
baggs is offline   Reply With Quote
Old 05-22-2024, 05:59 AM   #12
DALLAS , TX
Install wasn't difficult. Took a few hours though, mostly because I was taking my time and being careful.
We have over 8000 miles of towing with the Duraflaps and have nothing but positive things to say about them.
We originally decided on the Duraflaps after 2 different airstreamers on a recent Alaska caravan reported better protection from the Duraflaps than others on the same caravan experienced using the rock tamers. Basically they had no damage on their airstreams while using the Duraflaps, but the same wasn't true for the others using rock tamers. Nothing wrong with rock tamers, but I am satisfied with the Duraflaps.
The F350 diesel has so much torque that if you try and start moving on loose soil or gravel, your rear wheels frequently break loose and send a shower of debris rocketing backwards. The extra large Duraflaps have intercepted 100% of this debris so far. Last note: We have towed at least a thousand miles on dirt roads in Colorado and Utah so far. Exceptional performance from the Duraflaps.
Old 05-22-2024, 06:27 AM   #13
2024 25' Trade Wind
Awesome! Iím sold! And Iíd love not to deal with tamers on my hitch.
Question about the weights. Do they add any value other than looks? I couldnít find any reviews specifically talking about the weights on any mud flaps or rock tamer-style flaps.
Old 05-22-2024, 01:07 PM   #14
DALLAS , TX
The weights aren't necessary at all. They look better with the weights though, so I decided to waste the money to improve the esthetics a little bit :-)
Old 05-22-2024, 02:20 PM   #15
2024 25' Trade Wind
LOL, I kinda figured. They didn't seem big enough to add much to the heavy rubber. But what do I know? I may order them without the weights, I can always waste even more money later and get custom weights.
Old 05-22-2024, 02:47 PM   #16
2023 27' Flying Cloud
Buford , GA
Duraflaps
We have had the Duraflps on our F-150 for a year now and they seem to work great. You can order with wide width and longer length to get extra coverage if desired. They will customize them for your offset. Installation was easy, uses stock holes for the bolts.
J & B with Izzy the standard poodle
2023 FC27FBQ with a hatch! BRN 20813
2023 F-150XLT 4x4 5.0 max tow
JBamadon is offline   Reply With Quote
Old 05-23-2024, 03:24 PM   #17
2024 25' Trade Wind
Reporting back, I ordered the Duraflaps, and somehow they arrived within a couple days! I was surprised. Took a long lunch break and installed the two on the rear tires today. Seems like a very solid install. Can confirm I'm not sure what the "weights" could add from a functionality standpoint. These are quite rigid rubber/plastic/whatever they are made of. I got the long and wide ones, and they more than cover the back of the tire and go to within 6 inches of the ground. I imagine with the trainer loaded, they will be an inch or two closer. They look nicer and will be much less of a hassle to deal with than rock tamers. I'll look forward to see how they perform. I'll probably work on the front ones this weekend. Hopefully the combo will help protect our Airstream.
Old 05-23-2024, 10:50 PM   #18
ijoe13's Avatar
Can you share some photos?
Old 05-24-2024, 09:19 AM   #19
2024 25' Trade Wind
Here are some pics of the rear mud flap install
ID:	443719   Click image for larger version
ID:	443721   Click image for larger version
Old 05-24-2024, 09:40 AM   #20
1966 22' Safari
Fredericksburg , Texas
I had Rock Tamers for a few years and they seemed to have worked well. I got tired of taking them off and on so tried DuraFlaps. I like the mud flap design a lot better. They also help prevent dinged windshields on vehicles behind me when running around town at home. Either way, they both help prevent dings.
Bubba L is offline   Reply With Quote
Rear tire mud flaps instead of corner rock guards? GaryRI 2005 and newer - Bambi all models 15 09-01-2020 07:07 AM
Mud/Rock Flaps captsquid Rock Guards, Segment & Window Protectors 7 03-10-2020 08:48 PM
Mud flaps of the tow vehicle Melody Ranch Tow Vehicles 27 06-05-2017 11:09 AM
mud/rock flaps Snedwid On The Road... 7 10-03-2013 06:23 PM
