Old 02-11-2021, 05:26 AM   #1
Advocate28
2020 16' Basecamp
Sheboygan , Wisconsin
Tow Vehicle for Flying Cloud 25' or 27'
I am currently towing a 16' Bambi with a Toyota Highlander. I am considering trading up to a 25' or 27' Flying Cloud. I don't completely understand how to evaluate the towing capacity of a particular vehicle, and I don't trust the car salesperson to help with that. I definitely prefer Toyotas to other vehicles, but I'm not sure the Sequoia is big enough. Land Cruisers are awesome, but new ones are too expensive for me and used ones are hard to find. The towing capacity is 7,000 to 7,400 lbs. I'm also looking at a Nissan Armada (price is right). Nissan says it can tow "up to" 8,500 lbs (what does that even mean?). "Gross weight" of the 25', according to Airstream, is 7,300 (what does that mean?). For the 27', the gross weight is 7,600 lbs. "Unit base weight" (which I guess is with LP and without water and cargo) is 5,868 lbs. Does that mean gross weight includes water? Sorry for the lengthy post. Any TV suggestions appreciated. I would prefer not to buy a truck, but would consider it.
Elizabeth28 is offline   Reply With Quote
Old 02-11-2021, 08:02 AM   #2
DewTheDew's Avatar
2020 30' Classic
Frederick , Maryland
There are a number of similar threads but I will provide some highlights and our experience. First off, the "gross weight" of the trailer is that maximum allowable weight. If the Unit Base Weight" is 5,868 and the gross weight is 7,600 then you can put up to 1,732 lbs in the trailer (water, clothing, and so on). Those are guidelines as each trailer may weigh a bit more or less depending on options (the gross weight is defined structurally and doesn't change, but the actual weight of a delivered trailer may be more or less than 5,868).
There are two key things to pay attention to when pairing a tow vehicle and a trailer. First is the overall weight, which is what most people pay attention to (including me when I started). As a first cut at it, you should have a vehicle that will tow the weight of the trailer you buy (for the 27' that is 7,600). That is not hard to find. The second thing, and the thing that caused me to end up trading in my F150 for an F250 to tow my 27' FC, is payload. Similar to the calculation above, the Armada has a gross vehicle weight rating that is fixed, though each individual Armada may weigh different amounts. The difference between the gross vehicle weight rating and the actual weight of that particular one is called "payload". That should be listed on the drivers side door jam of a vehicle. My F150 was tarted up with all the fancy bits so its payload was only about 1,400 (can't recall exactly) and once I hooked up the trailer (with a weight distributing hitch), had my camping stuff in the bed, and included passengers and dog, I was right about the payload of my truck as weighed on a CAT scale. The camper itself puts about 900 lbs of weight on the truck (it varies by model and how you load it). That will likely be the limiting factor of what you can tow with.
Rule of thumb; for a 25' AS you can almost certainly tow with an SUV like the Armada or 1/2 ton truck, but with the 27' you likely want to move up to a 3/4 ton if you plan on loading up much (or if you like the fancy stuff in the truck; a stripped down 1/2 ton would still work fine). There are various schools of thought; some people will claim you can tow a 27' AS with a Toyota Camry and others feel you should have a 1-ton truck to tow a Bambi. I am passing along my experience, which is somewhere in the middle.
Have fun and good luck!
DewTheDew is offline   Reply With Quote
Old 02-14-2021, 08:58 PM   #3
Collyn's Avatar
Church Point , NSW
By and large what car maker mean by 'it can tow "up to" 8,500 lbs (what does that even mean?).
It's essentially the weight it can pull 'up to whatever' (starting and restarting) on a 14% gradient - on the end of a rope. The specs may also show the maximum tow ball load. If so its the lesser of both.
That '8500 lbs' may be far less if via an overhung hitch.
In this area check it out from the maker's specs - not what a salesperson tells you.
Also, if an RV seller tells you the time - check your watch.
Collyn
(In Australia)
The problem is not so much what people do not know, it's what they think they know that simply is not true.
Collyn is offline   Reply With Quote
Old 02-15-2021, 06:55 AM   #4
Advocate28
2020 16' Basecamp
Haha! Thanks.
Old 02-15-2021, 07:05 AM   #5
Advocate28
2020 16' Basecamp
Thanks, this is very helpful. I did search other threads, and I found a detailed one about a tow vehicle for a 25', which I read in its entirety. (I've now decided on the 25'.) If there's a search term I should enter other than "tow vehicle for 25'), I'd appreciate the guidance. Also, thanks for the tip about the CAT scale. It never occurred to me to do that. I travel very light, but it never hurts to check. I was thinking the Toyota Sequoia, with towing capacity of 7,000-7,400, might be good enough for the 25', with dry weight 5,503. The gross weight is 7,300 and I wasn't sure how to evaluate that. I don't generally travel with full tanks, and my cargo is almost nothing. I suppose I shouldn't take the chance.
Old 02-15-2021, 11:00 AM   #6
2019 25' Flying Cloud
Houston , Texas
The location of the bedroom on 25's affects how much real world (after loading) tongue weight there is. We have a SUV with 1,552 payload. After looking here extensively, I concluded that it would be better for us to get the rear bedroom model because the front bedroom models loaded tongue weights would likely be too much for our SUV. The receiver on a tow vehicle (the part into which the hitch ball goes) has its own rating. Ours is 950lbs, for example. Many here have reported front bedroom 25's to be in the 1,100lbs range on tongue weight.
As it is, we cannot carry all that much in our SUV because of the payload limitation. Hasn't been a problem for us, but there are just two of us and two smaller dogs.
DCPAS is offline   Reply With Quote
Old 02-15-2021, 12:02 PM   #7
2018 25' International
Slidell , Louisiana
The Sequoia is very marginal as a tow vehicle for a 25' Airstream. As Collyn implied the statement that it can tow a 7,400 lb trailer is not the same as assuring you it will always safely manage a 25' Airstream. Folks like Collyn have significant practical experience in vehicle design and behavior resulting from same. In the case of the Sequoia there are limits associated with performance and combination stability that make it poorly suited for a travel trailer that large. The manufacturer limits the tongue weight to 710 lbs max. The 25' Airstream will have a tongue weight near 1000 lb. If you choose this vehicle you are accepting much more risk of oversteer and sway, the primary causes of serious towing crashes than the manufacturer intends and what most informed people would advise. It will tow nicely on a straight road and gentle curves, but it will not be able to manage the trailer if you happen to get it out of alignment in an emergency maneuver at highway speeds. It will push the vehicle around and the combination will go out of control. If you are comfortable with this risk, exceed the Toyota tongue limit guidance. If you want to be as safe as the manufacturers intend and in line with best engineering practice, go with something like the Armada as was previously suggested. Your safest approach is to stay below both the towing limit and the tongue limit.
Old 02-15-2021, 12:51 PM   #8
Houston , Texas
Consider looking at a Ford Expedition. Among the SUV's, I believe it has the most towing capability and payload. The new GM SUV's will be pretty capable too.
Old 02-15-2021, 01:20 PM   #9
B. Cole's Avatar
1977 31' Sovereign
Rochester , WASHINGTON
A longer wheelbase/ heavier truck, like a 3/4 Ton F-250, just for example, would be much better for towing a large 25 foot Airstream, than a shorter wheelbase, lighter vehicle, like a SUV or a 1/2 Ton truck, like a Ford F-150.
You don't want a tow vehicle that the trailer is capable of driving.
Safety is the #1 issue with any size combination vehicle.
Airstream rodeo clown, it's my turn in the barrel 🤡
B. Cole is offline   Reply With Quote
Old 02-15-2021, 02:31 PM   #10
2017 25' International
West Lake Hills , Texas
Wish I had a little more truck
We are new to towing, too. We pulled a 2017 International 25FB home across 1500 miles with a 2020 Ford F-150 Supercrew gasser with the max tow package. The AS was mostly empty...just 10 gallons of water, plus some light luggage and the bumper of the truck (deer encounter). E2 weight distribution hitch.
I felt like the trailer pushed around the truck a little more than I would like. No real white-knuckle moments of sway but it wasn’t rock solid when being passed by semis. We had planned on a 23 foot FC but accidentally found a gently used 25 footer in the heavier class that would have made the F-250 a better option as a TV. Porpoising on concrete interstate highways and driving across northern Louisiana were not fun in the F-150, too.
Bottom line...I’m investigating the F-250 and F-350. But first I’m adding the Roadmaster active suspension system to the rear suspension of the F-150 and switching to the Propride 3P hitch. I figure the RAS is an inexpensive upgrade and the expensive 3P will stay with me in the event that I trade in the truck.
But if I was searching for a tow vehicle from scratch, it’d be a three-quarter ton truck or larger.
Fungus is offline   Reply With Quote
Old 02-15-2021, 02:38 PM   #11
Slidell , Louisiana
I'd be surprised if you weren't satisfied with the upgrades, as both will make a large difference in towing performance and passenger comfort. It's a bit pricey but the combination is an effective solution.
Careful badmouthing Louisiana roads!
Old 02-15-2021, 03:02 PM   #12
Dennis C's Avatar
Castle Rock , Colorado
Good advice in this thread.
I tow a 23FB with a 1/2 ton GMC truck, and the top limiting factor for my trips is the max payload limit of the truck. The only reason that I stay below the limit is the fact that the 23FB has a very light tongue weight compared to 25 foot and larger trailers. There's no way that I could safely pull a 25 footer with a 1,000 lb. tongue weight. If you add the tongue weight, the hitch, my tonneau cover, and a tank of gas then I'm within a couple of hundred pounds of the limit. Add my wife and I, and our Great Dane, and we're over. And that's with an empty truck bed.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
Dennis C is offline   Reply With Quote
Old 02-15-2021, 03:52 PM   #13
Brian - Sorry about the Louisiana road comment.
Shreveport I-20 is no picnic but at least it’s better than I-10 from Beaumont to the Tx/La border, a nasty stretch of TxDoT highway reconstruction.
Old 02-15-2021, 04:27 PM   #14
Slidell , Louisiana
It was in jest. You are so correct and then 1-10 near Lake Charles.... Never again till that is fixed.
Years ago, my wife drove our daughter into New Orleans 6 days a week for Ballet. This was before they resurfaced New Orleans East I-10. Her vehicle tore through 2 complete front end suspensions in 60,000 miles
Old 11-03-2024, 02:24 PM   #15
2019 23' Flying Cloud
Toronto , Ontario
We have a Flying cloud 25FB Twin. We tow with a Dodge Durango RT so it has a Hemi. Not exactly a gas sipper but this thing will haul the trailer straight up if necessary. Going over the Rockies the engine temp goes up slightly - it has an oil cooler and is a damn good ride.
kitzel is offline   Reply With Quote
Old 11-03-2024, 06:14 PM   #16
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Its All Three
Hi Elizabeth,
You are asking good questions, and right to be wary of auto salespeople. Very few understand the math involved in selecting a tow vehicle.
So there are a couple of math concepts you will want to learn about.
Towing Capacity
Payload
Vehicle Weight and Trailer Weight
Towing Capacity. This is the most often cited number in car sales lingo. The Tundra can tow 10,000 pounds! Wow that sounds amazing. What does that mean? Tow capacity means that the engine and transmission and brakes are rated to safely pull and stop that much weight. That is all it means.
What's the catch? The catch is that Payload and the weight of the vehicle respective to the trailer matter a whole lot. A whole lot.
So if towing capacity is how much the vehicle can pull, payload is how much the vehicle can carry. This is a much more important number for towing, and the one that is hard to find out. In fact, many car salespeople don't know how to find it. HINT-It will be on a sticker on the door jamb of the driver side door in the vehicle. Payload is how much the vehicle can carry. Occupants, pets, gear, and the weight of the loaded trailer plus trailer hitch on the vehicle. This is really important because a vehicle is not engineered to handle properly if it's over payload.
Think of this. You can push a huge shopping cart at Costco loaded with 8 packages of bottle water. But you can barely carry 1 package of bottle water in your arms. The payload is what the vehicle can carry.
Now, we learned the hard way that both weight capacity and payload can be within spec, and the match can still be really hard to control. We started with a 2014 Tundra 5.7L V8. It had 10,000 pounds towing capacity but only 1300 pounds of payload. That was great for our Bambi 22, and marginally OK when we traded to a 25. But not as good. When we went to a 27 we had to really really load carefully to not be overloaded, and driving in the mountains was a lot harder.
When we needed to trade vehicles, we got into a F150 with 1900 pound of payload. We thought we were golden. It was worse and we didn't feel in control at all, either across the plains when passed by semis , or in the mountains. It seems that we had a problem with #3. The truck was lighter weight, and wasn't a good matchup for the 27 airstream.
After much discussion with fellow campers, we took their good advice and now have a 250 diesel Super Duty and it's Freakin' Amazing!! More payload, a heavier truck, and engine braking and now we have a great rig.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 11-04-2024, 09:33 AM   #17
Mollysdad's Avatar
Originally Posted by Piggy Bank View Post
Hi Elizabeth,
Towing Capacity
Payload
With all due respect, Payload is NOT a math concept. It's an EPA ruling.
That's simply not true.
I hate beating this horse, but Payload is an artificial number created by the EPA to classify 'light trucks'. The manufacturers want to have their fleet meet the EPA standards and Payload is where they "find" the limits.
I've posted this report previously, but the EPA ruled that "all light trucks under 10,000 pounds are basically built alike, so a COMMITTEE came up with an arbitrary number of 8,500 pounds. Under 8500# and it's a light truck, over it's not. How is Payload determined? The manufacturer weighs the truck coming off the assembly line. Let's say it weighs 7,000#. They slap a sticker on the door saying that Payload is 1500#. Understand that a wheel and axle hitting a pothole is a momentary but exponential spike in the force acting on the truck. The axle doesn't snap off, yet I'm told if my dog weighs too much the truck is under built??? Remember, bigger brakes and a beefier receiver REDUCE payload even though they make the truck safer and more capable, but cloth seats INCREASE Payload? They do zero, nada, nothing for structural integrity. Ford proposed removing the AM radio portion!
Sure, better components make the truck heavier. That's the point, heavier than what? An arbitrary number.
ID:	448642   Click image for larger version
Old 11-04-2024, 10:07 AM   #18
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
old post...
Hey guys...there are "recent" newer posts to get upset about on this topic...this one is almost 4 years old now!
2017 28' Twin Flying Cloud
Old 11-04-2024, 10:41 AM   #19
2020 25' Flying Cloud
Woodinville , Washington
Get a tow vehicle that satisfies the rating for the tractor/trailer combination listed below. Staying under these values for the combination will (in no particular order),
• ensure safety (you and others on the road)
• leave margins for errors and unexpected challenging conditions
• make a real comfortable ride in challenging road/traffic conditions
• keep you within legal limits
• limit your financial and legal exposure were something to go wrong
I tow a 25’ Airstream with a SuperDuty. And here are the various ratings.
<See attached graphic>
Once you find tow vehicles that satisfy these ratings and numbers for the trailer in mind, the choice of specific tow vehicle becomes a matter of preference.
Hope this helps. Good luck!
Name:	Screenshot 2024-11-04 083904.png
Nishad is offline   Reply With Quote
Old 11-04-2024, 03:16 PM   #20
JJTX's Avatar
2024 23' International
South of Austin , Texas
25+ foot campers need a 2500 frame. You max out your tow vehicle rating too fast, especially tongue and payload weight ratings on SUV's and 1500 frames unless they are truck-frames.
Do not tow at max-weight-tounge-rating. It's not a good idea. For the many reasons you can find in this forum. Not to mention it's a better ride with a loaded 2500 frame, vs a 1500 frame, or SUV.
JJTX is offline   Reply With Quote
Tow Vehicle and Hitch Advice for 2016 Flying Cloud 28' Smashke Towing, Tow Vehicles & Hitches 36 03-19-2017 02:14 PM
Need a Tow Vehicle for a 27FB Flying Cloud chuckkubly Tow Vehicles 40 04-30-2015 12:47 AM
Tow vehicle for a 2015 25' Flying Cloud RDale Tow Vehicles 16 04-03-2015 09:05 PM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 01:55 PM
Looking for a Tow Vehicle for a 57 Flying Cloud... Skellington Tow Vehicles 15 04-16-2010 07:49 PM
