Old 08-23-2018, 04:28 PM   #21
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
A couple "interesting" things we tack onto a TV (GPS and camera) can pull more current than you might think. They may shut off with the accessory delay .... they may not. On my 2017 F-250, they don't shut off automatically.
I agree that running for 10 or 15 minutes is not charging your battery. It also isn't doing your engine or transmission any good. Far better to come up with a different way to charge the battery. If the vehicle is in storage for many months at a time, you may need to think a bit about things like engine oil ....
Old 08-23-2018, 04:38 PM   #22
2007 22' International CCD
Another possible data point.
I parked my pickup truck in the garage for three weeks at the beginning of summer. Wasn't thinking about it, but when I got back and tried to start it, the 2012 OEM battery was darn near flat. It fired, but it was close to needing a jump. Replaced the battery, but now there is a BatteryTender sitting close by, and if I'm going to have it sit over a week, it gets hooked up with the hood up to remind me.
My wife's shiny new 2016 Prius sat for a month, and the parasitic loads killed the 12 volt battery. Guess what? That fancy pants hybrid system flat won't start unless the old-school 12 volt lead acid battery is at least mostly charged...the 200 volt traction battery was perfectly happy, but there was no way to close the relays that heat up the electronics in the hybrid controller. Total silence--not even a warning light on the dash when I tried to start it--heck, I had trouble getting the door open!
The dealer was kind and warranty replaced the destroyed battery. The Prius fleet now also has a dedicated BatteryTender close at hand next to each of their normal parking bays.
Old 08-23-2018, 06:34 PM   #23
2010 25' FB International
Livermore , California
The brake controller is always powered but should go to sleep when the brake signal is inactive (brake pedal not pressed). If you hit the brake pedal with ignition off, you should see the controller wake up.
I believe the Curt brake controller had an issue with not going to sleep. Amazon reviews talk about it killing batteries. I had one for about a year with no issues. I watched a youtube video from Curt Mfg. to learn how to set up my controller, and the guy pauses to talk about how important it is that the controller goes to sleep. From all that I infer that they had a software bug, and it's been fixed. I'd give them a call if I were you.
MotoMannequin is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
house battery seem dead/ shore power dead joe rv guy Sprinter and B-van Forum 29 12-26-2016 12:36 PM
Best Tow Vehicle-Most likely Once Again srobison Tow Vehicles 93 11-20-2011 03:55 PM
Logging In Again and Again and Again Secguru Forum Admin, News and Member Account Info 4 11-01-2010 11:15 AM
dead battery in tow vehicle gettysburg Batteries, Univolts, Converters & Inverters 4 09-21-2010 08:50 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
