Old 10-27-2018, 08:40 AM   #1
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Too many miles for a TV?
Old 10-27-2018, 08:49 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Gas or Diesel? If gas and weíll maintained it prob ok
If Diesel and well maintained itís just getting started.
Old 10-27-2018, 09:08 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Taking stock before we went to Alaska this year:
218,000 miles and 12 years on the TV
30 year old Airstream
Both occupants past 75.
What could go wrong?
Nothing did. It was a fine trip.
Old 10-27-2018, 09:14 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I am going to have to admit to stirring the pot a little with my original post.
I would tow my trailer anywhere with my high mileage tow vehicle without trepidation. LOL
Old 10-27-2018, 09:17 AM   #5
sbowman's Avatar
1972 31' Excella 500
Grapeview , Washington
The check engine light?.............
Best regards and safe travels
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
sbowman is offline   Reply With Quote
Old 10-27-2018, 10:06 AM   #6
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Nothing a little black electrician's tape won't take care of.
Mattirs is offline   Reply With Quote
Old 10-27-2018, 10:37 AM   #7
1988 25' Excella
1987 32' Excella
"I am going to have to admit to stirring the pot a little with my original post."
We know that.
Old 10-27-2018, 10:47 AM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Here is my read on this issue. I have always maintained two tow vehicles to use with my Airstream. Right now I have a 2018 Duramax pick-up and a 2005 3/4 ton Suburban. This old suburban has nearly 180,000 miles on it.
The engine and transmission on the Suburban run just fine without any problems. It is all of the ancillary systems that break down, one after another. Within the last couple of years we have replaced or repaired the starter, the brake lines, the alternator, a power window motor, air conditioning control module, air bag sensor unit, dash board gauge rebuild, headlight control switch, two door latches, and both hinges on the rear gate glass.
We use the old Suburban for our winter Airstream trips. Unfortunately, many of the failures mentioned above have happened while we are on a trip. This has made us a little gun shy about continued use of the Suburban as a tow vehicle.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 10-27-2018, 10:49 AM   #9
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
On any vehicle, the question of "how well maintained?" is at least as important as this or that number of miles or years. Nobody ever thinks they do a bad job of keeping a vehicle in shape ..... half of them are below average at doing so ...
Also important is just how lucky you happen to have been with this or that vehicle. Some vehicles do better than others. If you are into the "major rebuild of this ..." every year phase .... might not be a good sign. Some vehicles hit that phase a lot earlier than others (regardless of make / model / year / engine).
To me the deciding point is as likely to be financial / time as anything else. If it's costing me significant money to keep on the road *and* that's taking up a lot of time I could be drinking beer .... time to trade it in.
So very much a "that depends" sort of thing.
uncle_bob is online now   Reply With Quote
Old 10-27-2018, 03:46 PM   #10
2012 19' International
Southeastern MI , Michigan
How many fuel pumps has it had? Mine had 4, two transmissions and the speedometer started to act up. 325,000 miles on it now, still going strong.
2018 International Serenity 27' FB
Michelin 16Ē tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
Countryboy59 is offline   Reply With Quote
Old 10-27-2018, 04:53 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Itís on itís third fuel pump, I rebuilt the gauge cluster two years ago and the transmission earlier this year. Five years ago I ďupgradedĒ the engine from a 5.3 to a 6.0. All window regulators have been replaced, the a/c blower motor and itís associated resistor and pigtail. A new master cylinder and rear brake shoes earlier this week. I think thatís about it though.
The replacement fuel pumps arenít nearly as good as the OEM pumps, even when I buy Delco...
Old 10-27-2018, 05:38 PM   #12
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Guess Iíve been lucky - very well maintained - original owner 2002 3:4 ton avalanche 208000 miles Iíve only replaced water pump alt and fuel pumps - all maint items none failed :-)
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 10-27-2018, 05:51 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I had forgotten about the water pump and a starter too. We swapped the engine at about 150,000 miles, although it didnít need it, everything else was real close to or after 200,000 miles.
You will have a fuel pump failure before 220,000.... Iím surprised you havenít had a gauge issue yet. GM had a problem with the stepper motors. There are businesses that will fix the cluster in a few days for $125 if you mail it to them, or if you can solder you can buy the motors for about $20 and fix it yourself in a couple of hours. (Iíve done both with a couple different vehicles)
Old 10-27-2018, 06:16 PM   #14
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I had a 2000 Silverado 1500 Z71 crew cab 5.3. I used it for a daily driver and a tow vehicle for 10+ years, ~230,000 miles. Had issues with a throttle plate and the solenoid that switched the 4 wheel drive, replaced by the dealer under warranty. I replaced water pump, wiper blades, brakes, and battery. No issues with the drive train at all. I sold it after 10 years. That guy is still driving it local daily and towing occasionally with it. It is well past 300,000.
Alan
Old 10-27-2018, 07:15 PM   #15
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I bulletproofed my 2005 F250 6.0 recently. Iím planning on 450k
VaTravelers is offline   Reply With Quote
Old 10-27-2018, 07:28 PM   #16
Ken J's Avatar
Durango , Colorado
Images: 14
Nope no gauge issues - oh ya -4 batteries and many windshield wipers :-)
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 10-27-2018, 07:29 PM   #17
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
This is the biggest complaint that I have, and hear about from friends; that the quality of replacement parts sold these days is terrible. If you can get NOS; get NOS.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 10-27-2018, 09:21 PM   #18
2007 22' International CCD
I always keep my vehicle as long as I like them, or the wheels fall off. Tow vehicles are no different. Most of my trucks have gone at least 250,000 miles without major issues (Toyotaís all)
How many miles is to many miles for a used TV? Belbein Tow Vehicles 20 04-24-2018 11:27 AM
How many miles are too many??? crabbey1 Tow Vehicles 26 03-29-2014 07:34 PM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
OT: How many trailers is too many? Amazing short video. SilvrSausage On The Road... 1 09-10-2008 04:44 PM
How many miles will you tow this year? Moonshot Community Polls 18 03-08-2005 09:04 AM
