05-15-2016, 10:16 AM
2019 27' Globetrotter
Salem
, Oregon
Tonneau Cover for truck
Many of you have experience with tonneau covers on their trucks. Would like opinions on your choices.
I have had a bak flip fibermax that I was happy with and am going to change trucks and looking for ideas.
Dave
05-15-2016, 10:26 AM
1993 34' Excella
Estancia
, New Mexico
Xtrac vinyl fabric snap on cover. Inexpensive and easily removable. I have a model that I can use with my tool box.
05-15-2016, 10:29 AM
2002 30' Classic S/O
Fleming Island
I had rigid fiberglass tonneaus on both of my previous trucks. I wanted something more amenable to hauling taller items so I got an Extang Solidfold. I like it, it is easily removable by two people and can be removed by one, but it does leak a little at the fold spots. I'm considering getting a full-size cab-high topper to give me a little more room.
Al
05-15-2016, 10:48 AM
1972 31' Sovereign
Lexington
We also have the Extang Solidfold, and we love it. As Al mentioned, it does leak a bit at the folds occasionally in heavy rain, but we like the extra security of the solid cover and our locking tailgate. I can remove it ok by myself, but seldom need to.
Chris
05-15-2016, 09:59 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
I have a "Truxedo" tonneau and the quality is great. I've been abusing it for three years and still looks new. Uses velcro instead of snaps along the sides, easy install.
Bought it from Amazon.
05-15-2016, 10:09 PM
2012 25' Flying Cloud
Battle Lake
We have an Extang Trifecta and like it a lot. Very easy to install and remove with four latches. Trifold design allows easy access to gear.
Doug and Cheryl
05-16-2016, 10:22 AM
Yertle01.com
2006 22' International CCD
Estes Park
I have an Extang Encore tri-fold. I like it in every respect except one -- any idiot with a coat hanger could break into it in 5 seconds.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
05-16-2016, 10:30 AM
Henderson
, Kentucky
I've used roll-ups for 15 years. The one on my 2000 F150 was still in good shape when I replaced the truck this year and I put the one from the link below on my new 2016. It may take a little longer to open up than the rigid ones but it's completely out of the way when rolled and absolutely dry.
http://tonneaucoversworld.com/access-lorado.aspx
2017 25' International
Carlsbad
Truckcoversusa.com
My second and would have nothing else to keep my things safe. But they're pricey.
05-16-2016, 10:39 AM
2013 30' Classic
Greenwood
, Mississippi
I have the BakFlip G2 purchased from Amazon.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
2016 23' International
Centennial
I had an Undercover Flex installed on my truck. The dealer said it is the best rated for hail resistance. It has drain tubes and we have had a lot of heavy snow and rain this spring. No leaks so far. It's a tri-fold, so I can open it up just about all the way and it has support arms that hold it open but don't allow it to touch and rub against the back window of the truck. I like the way is becomes secure when I close the tail gate. I, then, lock the tailgate.
Steve "Centennial Man"
2016 30' Classic
Santa Rosa
I also have the Bakflip - the version that works with our Ramboxes. Ive been very happy with it. How did you like yours?
05-16-2016, 10:47 AM
2005 25' Classic
Austin
I have the BakFlip and like being able to keep things out of site and somewhat secure with the tail gate lock. It does sometimes leak a little bit at the edges. I can easily remove it by pulling a couple pins. The rails stay in place so re-install is easy.
Dennis
05-16-2016, 11:00 AM
Battle Lake
We thought about the security of various covers and careful calculated the difference between cutting into our soft cover with a knife, and prying or hammering into a hard cover was 5 seconds. If you want to slow them down, use a cable/chain and padlock for your equipment inside the bed.
Doug and Cheryl
05-16-2016, 11:01 AM
2016 25' Flying Cloud
Holly Springs
, Mississippi
Like Doug, I also have the Extang Trifecta. I considered a hard tonneau, but opted for this one for two reasons: (1) It's a lot lighter than the hard fiberglas ones, and (2) the Trifecta's bows arch up slightly, which provides just enough room for my Honda genset. The fiberglas ones are flat. Some even sit below the top of the side rails. Choose carefully in light of the height of what you put in the truck bed.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
05-16-2016, 11:02 AM
2008 27' Classic FB
Coppell
I bought the aluminum Retrax/Gatortraz from AutoCustoms. It is very solid and very easy to install. Permanently lubed roller bearings, manual roll up into a canister next to the cab. Solid locking, easy roll up. locks in any position, and looks quite good on the truck. Gatortrax is the "store brand" for AutoCustoms and is identical to Retrax, but $100 cheaper. I also bought a CargoGlide bed slide to make easier getting to everything in the truck bed.
I do get a little seepage of water around the Ford tail-gate step, and sides. Other than that it is pretty water tight. I would highly recommend it.
05-16-2016, 11:12 AM
1983 31' Excella
The Woodlands
I have a BAKFLIP MX4 Premium Hard Folding cover. It has drain hoses and the genny fits under it. Also I can place items on top of it.
05-16-2016, 11:21 AM
2015 27' FB Eddie Bauer
Box Elder
, South Dakota
I've been using the Roll-N-Lock for many years and have had good luck with it. Many of my friends were so impressed with this tonneau cover, they bought one for their trucks and had me install it.
05-16-2016, 11:32 AM
Likes Shiny Tings
1958 26' Overlander
Portland
, Oregon
I just bought a 3 fold hard cover by LEER for our short bed. So far its waterproof and I really like it. Price was $795 and they installed it.
Of course I wouldn't expect it to be burglar proof, just keeping some things dry and out of the way. I keep the tailgate locked.
I just completed a 3500 mile road trip (sans trailer) and didn't really find that it improved gas mileage as they claim about tonneau covers, (though only 10% claimed) but maybe I should have slowed down more often. (eh who am I kidding, I drove through Nevada twice)
05-16-2016, 11:33 AM
2013 30' Classic
Greenwood
, Mississippi
TAC #MS-10
Airforums #70955
