Old 04-25-2020, 07:43 PM   #21
2018 25' International
Slidell , Louisiana
Originally Posted by CruizinDux View Post
Just an aside re CA...pulled into Jalama Beach ( not an easy approach) i CA and parked next to Cayenne pulling a new 28 Int...all set up by Andy @ CA. many more andy @CA comments on fofums. BTW, so much for the argument against shorter wheelbase TV's! Interestingly...they had just traded their fc20 for the new int 28.
B
BTW, this is pro CA comment. Agree wuth others of the buru being shy of capacity for a 20 which is our TT.
Just because you find light short wheelbase SUVs pulling trailers 25-40% heavier than their SUV from time to time does not make it a safe set-up and does not mean they will make to their next destination. There is no end to blissful ignorance. In California, towing speed limits are 55mph and perhaps this person stays in California and follows the limits to a tee. If so, great because that set-up can have significant stability issues in Nevada, Oregon or Montana with strong variable crosswinds at 65 mph. Is it safe at 45? for sure. At 55mph? most likely. 65? no, 70 hell no.
Brian
Old 04-25-2020, 08:42 PM   #22
CruizinDux's Avatar
Washington , Missouri
Hey Brian, can't say i disagree. A 28 is a pretty big mainsail.
I'm what some would consider a shorter wheelbase, but my TV does weigh more than my TT and has been rock solid outside of Spokane, and la grande, lower san Joaquin valley as well TX, Ok etc. IMO, wheelbase is a factor but so is weight, suspension and WD setup.
CruizinDux is offline   Reply With Quote
Old 04-26-2020, 05:06 AM   #23
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
( BTW, so much for the argument against shorter wheelbase TV's!
B
The shorter the WB, the less the payload...Not for us 👎.
Where would we put the boat?🚣🏾*♂️
TETO
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 05-02-2020, 09:43 AM   #24
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
We started out with our Beetle and pulled this around for about 4 years.
We did a lot of work to the car to make it stop and also to make it go. Our little Camplite served us well at only 2,200 GVW with a dry weight of 1,620 lbs.
We played with the idea of pulling a Bambi 16 with the car but the little Bambi was nearly twice the dry weight of the Camplite.
The Camplite has been replaced with a 2019 Sport 22FB and the Beetle has been replaced with a 2019 Ridgeline AWD. We really like the way the RL pulls the Sport up and down the hills in our province.
I am looking forward to may years of use with our new setup.
I know Canamrv does a great job with their hitch configurations and are worth a look if a Subaru or Jetta is your choice for tow vehicle.
Please make sure that you don't go overboard with the capabilities of your tow vehicle. Just consider how your combo will stop from 60 mph going down a 10% grade!
PB_NB is offline   Reply With Quote
1980 Excella (31 Ft) Gross Weight/Tongue weight? jnichols 1981 - 1983 Excella 10 03-20-2021 09:12 AM
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
