Old 09-25-2022, 09:30 AM   #1
Carmel , Indiana
Tire Loading and PSI
Were completing our Freshman season. Have so much to LEARN. Great forum.
I'm investigating weights, tire loading and pressures.
For some background..
I have a 1Ton GMC 2019, and was just interested in her weight unhitched. I brought it to the Cat Scale with the following results
Steer Axle 4900
Drive Axle 3860
Gross Wght. 8760
Truck
GVWR sticker is 11500
Payload sticker is 3475
I have a loading chart from my tire mfg that recommends varying tire pressures depending on the load on the tire.
I don't see from the Cat Scale report a weight for each tire? Or do you just divide the axle weight by two and use that as a close approximate?
Although this is a truck question for overall reference we are in a 21' GB 27FB.
Sorry if I sound like a dunce, just wanted to see what others are doing?
Mr Wonderful is offline   Reply With Quote
Old 09-25-2022, 09:46 AM   #2
ITSNO60's Avatar
Tucson , AZ
Standard recommendation is to add 10% to allow for uneven side to side loading. That said, when my F350 is unladen even adding 10% puts my rears between 35 and 40. I don't run them that low, instead I keep all four around 60 when unladen, I need the 60 in front due to diesel engine weight.
Brian
ITSNO60 is offline   Reply With Quote
Old 09-26-2022, 06:19 AM   #3
Carmel , Indiana
Thanks ITSN. So I understand your taking the axle weight / 2 and adding 10%?
Are you aware of any commercial scales that measure loads per tire?
Old 09-26-2022, 07:20 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Check the Google Satellite view for the CAT scales near you. Some are configured with the scale plates even with the surrounding asphalt and in such a way that lets you drive onto the plates with only one side of your truck on the scale. This gives you the weight on one side. Go around, do a re-weigh with the other two on the scale.
You might not be able to do this with the steer axle on the front scale plate where it normally would be, but you can usually get the axles each on one of the plates further back.
Some are built with the scale raised up above the surrounding parking area, so obviously this method won't work.
If the CAT scales near you can't do this, start searching for other scales in the area. I've seen some independent truck stops and fuel stations which have scales open to the public, and many of these are built without anything blocking you from straddling the scale plates to get one side measured at a time.
Richard
11018
richard5933 is offline   Reply With Quote
Old 09-26-2022, 07:52 AM   #5
ITSNO60's Avatar
Tucson , AZ
I tried that at one of our CAT scales and not only did it not work but the attendant came running out yelling at me "You can't do that on our scales!"
The only way I know of to get corner weights is to buy a portable scale or join Escapees Club and wait for a weighing event in your area.
Brian
Old 09-26-2022, 07:54 AM   #6
ITSNO60's Avatar
Tucson , AZ
Yes, adding a minimum of 10%. Like I said on my rears it is more than 10% when unladen.
Brian
Old 09-26-2022, 10:51 AM   #7
S/O#080
Tschupp's Avatar
2006 30' Classic S/O
Naples , Florida
Escapees “boot camp” in Congress AZ and had individual tire scales.
Tschupp is offline   Reply With Quote
Old 09-26-2022, 11:03 AM   #8
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Just as a side note. For my AS, I run at 65psi or even 60psi, anything higher will give your AS a rougher ride and pop rivets (from experience).
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 09-26-2022, 11:18 AM   #9
1988 32' Excella
Robbinsville , New Jersey
You can also check places that sell stone by weight. Some will work with you to get weights if they aren't busy at the time. Though some are not setup so you can just weigh one side.
Old 09-28-2022, 03:04 PM   #10
Carmel , Indiana
Thanks all.
Old 10-05-2022, 11:43 AM   #11
Berkel-Enschot , Noord-Brabant
If you give me the tirespecifications, I will make an extra safe pressure/axleload list for you.
For that I made a spreadsheet in wich I use a better calculation then those of the lists, and go from 90% used from the loadcapacity for the pressure.
This gives max reserve with still acceptable comfort and grip, for an LT tire.
Need
1. Maxload or loadindex
2. Loadrange to determine reference pressure, but better if given on sidewall, pressure behind AT given
3 speedcode would be nice.
And if you want other reserves, write it.
Also give dual maxload.
jadatis is offline   Reply With Quote
80 psi vs 65 psi - are both safe in this situation? GOUSC Tires 72 10-16-2019 05:56 AM
weight distribution and tire loading out of sight Towing, Tow Vehicles & Hitches 57 03-18-2019 01:34 PM
Maximum PSI and Tire size Jase Tires 27 05-01-2017 01:12 PM
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 11:11 AM
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi Driver1 Tires 3 06-23-2008 09:26 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
