Old 08-02-2020, 03:57 PM   #1
2020 30í Globetrotter
Phoenix , Arizona
The 2021 Ford F-150 will have a big generator . . .
The recently announced 2021 F-150 lineup includes a hybrid model that has an optional 7.2 kW generator and a lithium battery pack.
Not much detail is yet available, including pricing and towing capacity, but what I've seen so far is certainly intriguing as a boondocking TV--one that can delivery 30amps of power.
Any thoughts here?
Mike
mkaiseraz is offline   Reply With Quote
Old 08-07-2020, 08:30 AM   #2
2016 30' International
redondo beach , California
Great idea! All trucks should be like this.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 08-07-2020, 08:40 AM   #3
Silvr_Bullet's Avatar
42į 2' 27" N / 74į 7' 6" W , US
Thatís a great option, wonder what itís toll is on payload. But great for people that donít mind or truly need carry all over power requirements.
Silvr_Bullet is online now   Reply With Quote
Old 08-07-2020, 09:51 AM   #4
Long Island , New York
Question
Just a big battery/inverter. The term "generator" is there to catch eye-balls . . . quite successfully IMO.
The truck's engine is the mechanical device sending electrical power to the large battery, which then inverts the 12-volt direct current to 120-volt alternating current.
Earlier threads:
24 posts -- lots of good info and links: https://www.airforums.com/forums/f46...or-208957.html
3 posts: https://www.airforums.com/forums/f14...ng-210391.html
FYI
FWIW
Peter
Let the music lift you up . . .
Old 08-07-2020, 11:50 AM   #5
It reads as the vehicle engine acts as a generator, additional there is battery that stores power, when load exceeds a certain draw the car engine/generator kicks on. Sounds like a generator to me.
Old 08-07-2020, 12:17 PM   #6
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
Earlier threads:
FYI
FWIW
If this is similar to the Chevy Volt plug-in hybrid, the engine turns a generator, but I do not believe these engines drive a 12v generator for anything more than on-board accessories (lights, radio, etc). The engines are attached to a generator that produces a lot more than a 12v generator can create and be inverted. The battery packs and drive line system voltages are 360v. Pretty sure all electrics and plug-in hybrids also use higher voltages drive lines than 12v inverted to 120v and I am also pretty sure they don't put in a 4 banger engine just to generate 12v to invert. The wiring alone in these types of cars are far more dense (size) than simple 120v cables and they are colored bright orange.
As for this application in a truck, Bob Lutz the guy that pushed GM to make the Volt later said they got it wrong, they should have done it with a truck first. Seems that philosophy only took automakers 7 years to realize. The concept is just a consumer grade version of what electromotive locomotives have been doing more than 60 years, so the ability is there to make it work....the question really is.....can it be built and sold at a price consumers can afford and does it make sense at $2.50/gallon. The higher gas prices go, the more thee make sense. Best of both worlds.....electric for say 100-150 miles towing, then a internal combustion engine to produce electricity to the drive motors, run low on gas, roll up to the next station and fill 'er up in 3-5 mins and off you go for another 300 miles (on gas)...get to your campground, plug in the RV and the trailer, or don't.
I use the Volt as an example, but pretty sure all plug-in hybrid electrics will behave and use similar tech. See pages 18 and 19 of the attached PDF for some general info on the drive line electrical system that supplies the electric motors.
As you'll see, it's not simply 12v inverted.
File Type: pdf Chevrolet Volt Collision Awareness Guide.pdf (2.85 MB, 27 views)
panamerican is offline   Reply With Quote
Old 08-11-2020, 08:55 PM   #7
2019 16' Sport
Hillsboro , OR
2021 Ford F 150 hybrid
Any thoughts here?
Mike
I am new to RV camping and would prefer to boondock as opposed to using a traditional RV Park. Iím very intrigued with this hybrid Ford F 150. Other than vehicle cost, what could be the downside?
CRRVP is offline   Reply With Quote
Old 08-11-2020, 10:01 PM   #8
Phoenix , Arizona
Towing payload for one. It will be interesting to see the specs in detail.
Mike
Old 08-12-2020, 03:16 AM   #9
You have to run the truck's engine to charge the battery, as opposed to having a separate stand-alone generator with its own gas/propane-fired engine to power its own electrical generator. Less efficient this way, plus campground rules and neighbors may not like a truck engine idling for an hour or two, just to accomplish this [unnecessary] task IMO.
See sources referenced in earlier Post #4:
Earlier threads:
Of course solar panels can augment either system.
Welcome to the forum CRRVP.
Happy trails,
Peter
Old 08-12-2020, 07:03 AM   #10
2017 23' Flying Cloud
Bartlett , Tennessee
Only the hybrid can get the 7.2 kw generator. An ICE vehicle gets a 2 kw generator, less than what a Honda 2200 watt generator puts out. Not to mention that the vehicle engine has to be running full time (on the ICE). That is far less efficient that just getting the Honda. It is all about the trade offs. What does the battery of the hybrid take from the payload capacity?
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 08-12-2020, 08:39 AM   #11
SailorSam205's Avatar
South East , Michigan
A couple of thoughts.
I was on a ride and drive of the 2020 hybrid Escape. I was amazed at how small the battery pack was for the vehicle. I don't remember the weight, but it wasn't much. Could be equivalent or less than a 2k inverter generator.
I wonder if the 2k watt rating is surge or continuous.
Much of the discussion on inverter generators focuses on noise. I suspect my 2019 F150 EB is as quiet or maybe quieter than these generators.
Unlike the stand-alone generators, the truck has a full set of emission control devices.
Also, not sure how many people have seen them, but there is a company selling a gizmo that plugs into any vehicle to provide AC power called the CarGenerator. I haven't seen the detail specs for their 2k unit though they claim a F-150 with a 36 gallon fuel tank will run at idle for 90 hours. I expect the Ford OEM version will have similar run time.
Al
2017 29' SOB, 2019 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 08-12-2020, 11:53 PM   #12
2019 16' Sport
Hillsboro , OR
Happy trails,
Thanks!
I was originally thinking that the F 150 hybrid would be great for boondocking. Less gear to mess with; fuel containers, portable solar panels, inverter generator,
Lithium batteries, etc.. Just plug into the truck. Easy. Plus the truck bed is great for hauling my bicycles.
Or, just get a Honda 2200 inverter generator to top off the battery and help run the trailer when needed. Should I spend $70,000 or $1,000?
What to decide?
Old 08-12-2020, 11:57 PM   #13
2007 22' International CCD
Oh, go for the highly complicated and elegant solution, like the Department of Overkill Engineering almost always does.
Yeah, I caved and got a Champion 3500 watt inverter generator. SWMBO only allows me to buy Toyota vehicles.
rmkrum is online now   Reply With Quote
Old 08-13-2020, 05:24 AM   #14
Thumbs up
What to decide?
Peter
Old 11-03-2020, 09:53 AM   #15
F150 Powerboost On Order
2019 22' Sport
Tabernash , Colorado
New Specs
I am looking closely at this truck and see that the payload is 1830 pounds which is approx 100 pounds more than the 2020.
I am still talking to the Ford dealerships to understand exactly how the battery will work when I plug my camper into the 240 volt outlet. I do know that I will need to convert 240 volts down to 120. When taking to my engineer friends they suggest that the 7.2KW battery at 120 volts will equate to having a 60 amp battery. The question I have is how will that work? Will it be like plugging into a pedestal? Will the gas engine need to be running? Will the truck need to be in accessory mode? My understanding is that once the truck hybrid battery gets too low then the gas engine truck will start and charge the battery automatically.
I have spoken to a large Ford dealership specifically about these questions and have not received a definitive answer. They are supposed to get me the answers to these questions or if possible put me in touch with a Ford engineer.
If I learn more I will share.
JeffCross is offline   Reply With Quote
Old 11-03-2020, 06:38 PM   #16
2009 30' Classic
a city in west GA , Georgia
This is very interesting, I will continue to follow this post. Maybe not for the 2021's but maybe 22 or 23 technology is moving so fast....
Joyman is offline   Reply With Quote
Old 11-03-2020, 07:14 PM   #17
Saluda372's Avatar
2021 20' Caravel
Plaistow , New Hampshire
We've been Ford for a lot of years, been good to us.
Sorry for the drift but how quiet is that generator ?
Saluda372 is offline   Reply With Quote
Old 11-03-2020, 07:34 PM   #18
Quiet enough to easily hold a normal conversation next to it without raising your voice any at idle. When my air conditioner compressor comes on it is still about that quiet. It barely comes off economy idle. I donít have a MicroAir EasyStart installed yet, and I think installing it will quiet the load transition more.
The airstream is a 30 amp system, and even in the heat of the day in El Paso Texas in September last year it was not real loud. Still conversational, and with the generator on the tailgate of the truck and the exhaust port pointed at the front of the trailer we couldnít hear the generator over the air conditioning fan.
We only run ours on propane, and Iím quite happy with the noise and the price. It has plenty of capacity for our setup.
For reference Iím strictly a Toyota guy...
Old 11-04-2020, 10:16 AM   #19
Looking at the power center in the truck bed, there are 4 standard 20 amp outlets and one 4 wire 240 volt outlet. So, if you want to use the 240 plug, most likely, you will need a dog bone similar to what you would use to plug in to a 50 amp pedestal outlet. You could also use a 20->30 amp adapter.
https://www.repairerdrivennews.com/w...ard-scaled.jpg
Al
Old 11-04-2020, 10:33 PM   #20
2019 22' Sport
That at least is my plan to convert the 240 down to 120. Of course I can plug the camper into one of the 20amp outlets too just to charge the batteries assuming I didn’t need the full 30 amps.
On a side note Ford is next week having a show in 2 Texas cities and in Phoenix to demo the new F150s. You can register at f150drive.com. It’s a 12 hour drive for me but I am pretty tempted. If there is anyone reading this thread who has the ability to go, I would love to have you ask questions about the hybrid from a camping perspective. I have found that Ford is focusing the use of this hybrid for “job site” activities and not campers. I don’t think they realize there are a lot more campers than there are guys buying this for the construction site.
Ford Transit all-electric van in 2021 OTRA15 Tow Vehicles 73 04-05-2021 03:42 AM
2021 f-150 Hans627 Tow Vehicles 3 11-03-2020 07:17 PM
2021 F150 to Have Onboard Generator kscherzi Tow Vehicles 23 06-28-2020 09:25 AM
Ford 150 Ecoboost with Max Tow vs. Big Butt Trailer ShullsinUtah Tow Vehicles 15 09-17-2013 08:45 PM
