Old 05-21-2025, 10:42 AM   #1
Lexington , Kentucky
Tacoma towing a Caravel 22fb
We purchased a new 2025 Caravel 22fb with a Blue Ox hitch to pull behind our 2024 Toyota Tacoma. We had the dealer install a 2" receiver and 3" lift kit before picking it up. On our first trip we attached the bike rack and two bikes for a total weight of 120 lbs.
The trailer weight was about 4600lbs with over 1/2 tank of fresh water in the tank in front of the axle.
The trailer sway was terrible, scaring us and other drivers on the interstate. We had to stay below 60mph. Changing settings on the Blue Ox hitch did not make much difference. That night I put the bikes and rack in the back of the truck. After that I could get up to 65mph but had to use the manual button on the brake controller frequently. An uncomfortable drive. The dealer has not come up with useful suggestions.
I will remove the lift kit and test drive with no bikes. Then I will remove the 2" receiver and test drive.
Is the Tacoma an unsuitable tow vehicle? Its towing capacity is 6500lbs. I do not wish to replace it.
I have read posts about other more expensive hitches but I dont want to go down that road if the Tacoma is unsuitable.
I would love to hear from other Tacoma owners but anyone experienced in these issues would help.
dpreston is offline   Reply With Quote
Old 05-21-2025, 10:54 AM   #2
2019 28' Flying Cloud
Broward , Florida
Is the Tundra by any chance an off-road model? If so, it won't handle as well as a road model because of the softer suspension and tires.
Andy543 is offline   Reply With Quote
Old 05-21-2025, 11:21 AM   #3
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
We have a lift in our 22FB and it hasn't made any issue with sway.
It is important to keep the tongue weight higher. We move a lot of stuff into the front storage under the bed. I would take the bike rack off and carry the bikes in the truck. We have our tongue weight at 12% and the trailer is very stable with or without the WDH.
You should be shooting for about 600 lbs on the tongue. That will smooth things out. You will need a way to measure that, and there are a few different ways. A Sherline scale or blocking and a bathroom scale.
We have pulled our Airstream with a Honda Ridgeline, Toyota Tundra and now a Chevy HD. (The Chevy happened because of our work)
The Tacoma is a smaller platform truck but should be able to handle the Caravel but you will certainly notice the trailer back there.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 05-21-2025, 12:39 PM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I’ve towed my Safari with my 2022 4Runner and had no issues. I normally tow with my first gen tundra which has very similar suspension to a Tacoma and have towed 40,000km without trouble.
Sway as you described is most likely a weight distribution issue and too little tongue weight.
https://youtu.be/N-5_Wk6MM6A?si=BMEiqGbCkhErwv7p
AldeanFan is offline   Reply With Quote
Old 05-21-2025, 03:34 PM   #5
2019 22' Sport
High River , Alberta
Do you have photos? It would be good, in particular, to see how the hitch is set up.
AlbertF is offline   Reply With Quote
Old 05-21-2025, 03:40 PM   #6
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
you need sway and wd to tow properly
give andy at canamrv.ca a call. he can walk you through this
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,3x MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 05-21-2025, 03:58 PM   #7
2019 22' Sport
He does; Blue Ox.
Old 05-21-2025, 07:21 PM   #8
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Some things to check.
We had a similar experience towing our first 23’ Airstream with terrible sway. It turned out we had the wrong size bars and I wasn’t applying enough tension on the bars. I didn’t know I should raise the tongue with the jack to make it easier to hook up and disconnect.
What size bars do you have? For your trailer, you should have at least 750 lbs. bars. We moved up to 1000 lbs. bars after consulting with Blue Ox engineers. When properly connected, you should have 3 1/2” links showing to apply enough sway control and weight transfer and the bars will have a noticeable bend.
Also, make sure the tongue of your trailer is level or slightly down when attached to the tow vehicle.
All these points are things I learned along the way. We moved up to a 27’ Airstream and still using the same Blue Ox SwayPro with 1000 lbs. bars.
Good luck with your troubleshooting!
ID:	453424   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 05-21-2025, 10:17 PM   #9
Moreland , Georgia
Count your chain links, from the free end. It needs the nineth, or tenth or 11th link to be in the slot in the rotating latch. Most likely the only way you will get that is to hitch the trailer to the truck and use the tongue jack to raise the trailer AND truck up, which will bring the bars up enough to get the 9th or better chain link in the slot. Count from the free end of the chain, that is how BO tells you to do it.
The pics Jeff posted above are a good example of how it should be. The bars should have a noticable bow in them.
Go to Harbor freight and buy a 24 inch long 1/2 inch square drive breaker bar, and a one inch socket. It will make the rotating latch much easier to latch and easier to control when unlatching.
Charles
'03 Ram 2500 CTD, 5.9L HO PacBrake six speed std cab long bed Leer top and 2008 BigfootRV 21RB trailer.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 05-22-2025, 05:57 AM   #10
JJTX's Avatar
2024 23' International
South of Austin , Texas
Without seeing the hitch and how its configured its impossible to say much about it, or what version of the blue ox you have.
What concerns me is your statement about lift kits and 2 inch receiver install, and why the receiver was not there already. It makes me believe there was no tow package on this truck to start with. And thats not good. These are factory installed and usually not done after the fact.
I dont think your truck is a good tow vehicle for a 22 footer. You are too close to the maximum rating of this mid range truck.
You should have went with the Tundra
Will the Tacoma do it? Sure. But I think whatever 'Lift kit " was installed contributed to the real bad sway, and the possibility of the hitch not providing any sway control was the issue here.
What is on the PAYLOAD sticker on the door frame?
I'm not sure you should give up on what you have, but someone needs to put their hands on it that knows what they're doing.
JJTX is offline   Reply With Quote
Old 05-22-2025, 06:36 AM   #11
Peter417's Avatar
1966 17' Caravel
1972 21' Globetrotter
SW , Missouri
You can make this truck pull this trailer safely. Dealers don't know how to setup a hitch correctly. They pay the guy minimum wage and he will only last a year or 2 before the next guy comes to replace him. You'll have to take responsibility and learn to do the setup. Watch some of the canam videos with Andy.
Once the hitch and correct bars Are setup you'll most likely be fine. But, Toyota's come with notorious weak springs in the rear. Most people are using Tacoma's for taking a kid to school not for doing truck things. I have upgraded 2 of my Toyotas with HD springs. Emergency maneuvers are much more stable. Post a photo of your setup.
Peter417 is offline   Reply With Quote
Old 05-22-2025, 09:16 AM   #12
2018 Basecamp
2019 22' Sport
Coon Rapids , Minnesota
check and make sure you truck / camper weights are good. Not sure where the bikes are mounted but we have a 2021 F150 2.7 pulling a 23' bambi. we have the lift kit installed on the bambi. That said, we are heading out to NY later this year and did some checks to make sure things look correct. Just doing a sanity check here. Have a 2021 F150 XLT with 2.7 eco-boost. Pulling a 2019 22' Bambi Sport. Truck 6600 lbs GVWR and GAWR is 3450 lbs front / 3400 lbs rear. Camper is 4500 lbs GVWR and has GAWR of 4300 lbs. Checked in at weigh station and truck front axel is 3140, rear 3280 and camper at 3820. Truck with me, wife, dog and gear loaded - full fuel and Anderson wdh attached. Camper fully loaded with fresh water (24 gallon). Camper / truck are level, tows great. I think I have it dialed in right. Getting 13.1 mpg 60 mph and 12.3 mpg when running about around 68 mph. All I can say is do your homework, make sure you are not overloading the truck. Also, with your WDH - measure your front and rear fenders before you hook up the camper and then afterwards. make sure you WDH is balancing your load to the truck. good luck.
jccoder is offline   Reply With Quote
Old 05-22-2025, 10:01 AM   #13
Lee Brisk's Avatar
1960 Caravel
Pewaukee , Wisconsin
you are light on tongue weight
Lee Brisk is offline   Reply With Quote
Old 05-22-2025, 12:11 PM   #14
1999 28' Excella
Lake Mary , Florida
Why did you install a lift kit on the Tacoma? What size tyres are on the Tacoma. As others suggest take photos,,,and one photo should be a side view of the trailer level - unhitched- 12 inches away from the Tacoma ball
suncoasteng is offline   Reply With Quote
Old 05-22-2025, 12:41 PM   #15
FYS
2016 20' Flying Cloud
Walnut Creek , California
I concurred with others. Have you tried adding more tongue weight, at least 10% of your trailer's gross weight?
FYS is offline   Reply With Quote
Old 05-22-2025, 01:45 PM   #16
2020 16' Basecamp
Louisville , Kentucky
I would recommend loading up your truck and trailer as you normally would for a trip and head to the nearest truck scales. Lots of online info for how to do this. Your Taco is a great truck but payload is limited and you may be overweight. The scales will help with correct weight distribution and payload.
Rolind is offline   Reply With Quote
Old 05-22-2025, 01:53 PM   #17
Broward , Florida
Yes. Weigh the truck and trailer at a truck stop. Also, it's a good idea to get the base axle weights of the truck without anything in it. If you have that data (plus the wheelbase and the rear overhang), you will be able to calculate the effect of any given trailer tongue weight on the truck's axle loading.
Old 05-22-2025, 03:32 PM   #18
To clarify:
The lift kit and 2” receiver were installed on the trailer, not the truck.
The Tacoma is a Limited - not an off road model.
750lb bars on the Blue Ox hitch.
Old 05-22-2025, 03:48 PM   #19
Broward , Florida
To clarify:
The Tacoma should be able to handle the trailer without swaying at 60 mph. I would check the tire pressures first. The trailer should have ST tires and they should be at the maximum allowable pressure as stamped on the tire sidewall. The rear truck tires should also be at the maximum allowable pressure. The fronts should be about 15% less than the rears.
The trailer tongue weight should be around 10% of the trailer weight. You can easily change the tongue weight on a single axle trailer by the way you load it. The heaviest items should be close to and a little bit forward of the axle.
Single axle trailers may sway easily, but the sway is not dangerous if, after an external disturbance, the sway diminishes with each swing until it's gone. It may take some time to get used to it.
Old 05-22-2025, 04:32 PM   #20
2018 22' Sport
Santa Fe , New Mexico
2013 Tacoma LMT and a 22' Bambi. Equalizer hitch with WD. Truck is stock, no lift kit, and has factory tow package and Tekonsha brake controller. No problems at all pulling the Bambi, which is the narrowest and lightest of all Airstreams, I believe. Many tell me the truck is too light but I've had no issues crisscrossing NM, AZ, CO, SD and Utah. So far. But I keep it at 65 max. I've heard several times not to add a bike rack to the back of the trailer- too much weight hanging off the back could be the issue.
Dandyburger is offline   Reply With Quote
caravel
Prepping My Tacoma To Tow a Sport 22FB Rounder44 Towing, Tow Vehicles & Hitches 7 09-04-2018 02:43 PM
Towing 19ft Bambi with 2009 Tacoma v6sr5 w towing package Shany Tow Vehicles 6 07-03-2017 10:44 PM
Towing a Bambi 22FB with a 2007 Tacoma krusty Tow Vehicles 15 01-16-2012 10:06 PM
Towing with a 2009 v6 toyota tacoma TGK Tow Vehicles 25 05-13-2009 04:25 PM
Towing 19' Bambi with 2005 Tacoma hiker Tow Vehicles 18 10-05-2005 08:03 PM
