07-21-2005, 06:27 PM
Suburban 2500 springs
Someone mentioned on the Forum, removing a couple of spring leaves on rear of 2500 Burb to soften ride and shock to Airstream.
Has anyone tried and what was results.....how big a job?
George Jr.
07-21-2005, 08:45 PM
George,
Actually I mentioned it and got no response. Judging by how rough the 2500 rides and how little mine drops with a 25 Classic tongue weight added, I can readily see the benefit of removing a set of springs. My problem is that I may not keep this '99 and don't want to invest alot more into it.
OTOH, when dropping the same coach on my '01 Expedition, it sinks like a rock!! There IS a difference between the two. Also the Expy has passenger tires load C and going to load D or E 'WILL' make a significant difference.
My question still is out there about the newer (post 2000) 3/4 ton Suburbans. Are they sprung like the 98-99 models?
Steve
07-21-2005, 08:56 PM
Aluminut
2004 25' Safari
When I drop the Safari on our '04 2500 Suburban, the rear end drops about 4-6 inches. Our Safari has a hitch weight rated at 750lbs. I've measured it and the most I've seen has been about 675lbs.
The Suburban isn't any more harsh than say a 2500HD pickup would be.
07-21-2005, 09:06 PM
Thanks for your reply,
I think my '99 drops approx 1", and the Expy drops more like your Sub.
Steve
07-21-2005, 09:27 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
try doing a web search for "velvet ride shackles" and see what you find. i believe bf goodrich makes them.
i have heard they will lower the rear of your truck by 1 inch and improve the ride.
john
07-22-2005, 05:48 AM
Thanks for the replys. My main concern is the amount of shock transfered to the AS.
George Jr.
07-22-2005, 08:35 AM
1992 34' Limited
Falls Church
'Sub drop....
Hello all -
Just to muddy the waters a bit more....
When I drop my 34' coach (either loaded or not) on to the back of the '01 2500HD 'Burb, I get a suspension drop of no more than 1 inch. Just went 4238.4 miles on a tow and found there to be neglibable transfer or beating to the coach as evidenced by things being tossed about and such, also no sheared rivets.
DO NOT know about suspension either forward or back from the '01 design - sorry.
Hope my .02 helped?
Axel
07-22-2005, 08:46 AM
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise
I bought a new F350 Super Camper Special in 1979. The rear suspension was so stiff a 500# tongue load would not settle the truck by more than an inch. Needless to say it rode like crap - so I did exactly what you are talking about. I removed three leaves from the lower middle of each side. The ride was much more tolerable after that. Ride height was only affected slightly.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
07-22-2005, 09:10 AM
1992 34' Limited
Falls Church
Clarification on 2500HD
Hello again....
Sorry, I don't think that I was clear in my last post. MY truck is Factory Original - NO mods done. Perhaps with a large and LONG trailer the beating to death/apart tendency goes away???? No tendency or damage to report with my TV/Trailer combo.
Sorry if I was unclear or confused anyone.
Ciao
Axel
07-22-2005, 10:59 AM
1976 27' Overlander
Richmond
john
John,
The use chart did not recommend the shackles for the
Suburban 3/4 Ton * *Not recommended for 3/4 ton
I wonder why? My Burb does have a "firm" ride empty. I do have the Auto ride feature that came with Quadra steer and with just a little weight in back our Burb rides great.
Abe
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2020 GMC Denali Duramax
Hensley Hitch
