RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-22-2021, 08:21 PM   #1
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Proper Trailer Loading Question
Washing my trailer the day I happened to pause at the manufacturer's weight sticker. Trailer is a 2013 27FB. I noticed the GVWR is 7,600 lbs, which I remembered. I also noticed each axle has a GAWR of 3,800 lbs. My first thought was, that makes sense 3,800 x 2 = 7,600, the GVWR. But then I thought, what about the tongue weight? That's carried by the truck. I had sometime earlier weighed it at about 950 lbs.
So my question to all you trailer weight and loading experts is.... Is tongue weight part of the trailer GVWR?
As an added point, today I weighed the truck and trailer at a CAT scale. Weight distribution hitch still in place and trailer loaded for camping, the trailer axle weighed 6,560 lbs. Both truck axles between 200 & 300 lbs under their respective axle ratings per sticker on door jam so that's good news
So if trailer axle is 6,560 lbs and tongue is 950 lbs, then is the trailer at near max GVWR, or well under? Appreciate your thoughts.
kscherzi is offline   Reply With Quote
Old 01-22-2021, 10:17 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
The trailer GVWR is the rating for the whole trailer, axles and tongue all together.
So your trailer is close to its GVWR. And your axles will be well under their axle weight rating unless your trailer is loaded well over its GVWR.
One other thing to know is that when you have your WD bars hooked up, some of the trailer tongue weight is transferred to the trailer axles. On my 25FB, that has been around 15%.
Oh, and I read somewhere on the interwebs that our Dexter axles ride smoother when they are partially loaded than when they are near their limit.
SSquared is offline   Reply With Quote
Old 01-23-2021, 07:28 AM   #3
2018 25' International
Slidell , Louisiana
From a vibration, stiffness and smoothness standpoint the Dexter axles perform best when near their rated load. This is by design so it is not true for all axle designs. The Brakes also perform best near rated axle load. FYI, depending on WD tension and tow vehicle geometry, an amount between 10 and 35% of the tongue weight will be redistributed from the tow vehicle rear axle to the trailer axles with WD set properly. Optimal WD settings are specific to the combination.
Old 01-23-2021, 09:15 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Our #'s from a trip last Season, before our 4000lb axle up grade, (3500 OEM).
760lb off the TV front axle with no WD and a loaded for camping rig.
560lb returned to the FA with WD set, 200lb light
AS axles 7480lb with no WD, 7640lb with WD, 160lb moved to the AS axles.
560+160=720lb total weight moved,
TV rear axle +920lb with WD set
ďItís not the system thats the problem, think Circus, itís not the car, itís that the car is full of Clowns.Ē
John Turley
Tahawus
Loading YOUR TRAILER may be Different Ray Eklund Tow Vehicles 3 07-16-2020 04:36 AM
Trailer Loading/Sway Demo dkottum Towing, Tow Vehicles & Hitches 0 03-09-2016 10:59 AM
Question on loading AS... kidsgone Member Introductions 1 02-13-2010 08:52 PM
Reducing Tongue Weight by Loading Rear of AS FranzB Towing, Tow Vehicles & Hitches 20 11-11-2006 01:37 PM
Problems with viewing pics.. not loading?? Happycampers Forum Admin, News and Member Account Info 8 02-26-2004 02:16 PM
