01-26-2021, 12:42 AM
#1181
Santa Cruz
Hello,
Thanks for the ongoing advice related to the brake controller. I’m still learning so my comments will continue to sound naive... At this long we don’t anticipate towing anything but the Airstream. We only have one vehicle that can tow the Q8. Our 2014 Q5 TDI doesn’t have a tow package and I believe the tow capacity is 4,400 and being new at towing we just don’t want to push it especially since we bought the Q8 to be our tow vehicle.
I normally would lean toward a wired brake controller since supposedly the Q8 is pre-wired for it.
Who would install wired brake controller? The Audi dealership (seem unnecessary... the AS dealer?
I know our dealer has recommended a blue tooth brake controller staying they have had issues with newer Q7, Q8, and Porsche Cayenne and that many have had to trade their Audi or Porsche in tow. —- a message that is not very reassuring to me!
I’ll review the thread again to make sure I fully understand what people believe are the positive and negatives of both...
Appreciate your insight! Learning curve is big but the forums helps a lot.
01-27-2021, 10:53 AM
#1182
1967 26' Overlander
Bugtussle
, Oklahoma
Pairing Tekonsha Prodigy RF solution
Try this if you can't get the Prodigy RF to pair with your european vehicle and trailer. This worked for me when using a neighbor's Chevy truck did not. I have a vintage trailer that does not have LED lights so I did not need an LED adapter. Here's the link to the original eTrailer discussion:
https://www.etrailer.com/question-77832.html
1. Put electrical tape over the pin in the 5 o'clock positon on the back of the trailer mounted Prodigy RF box before you plug in the trailer umbilical.
2. Now follow the pairing instructions
3. Once paired, remove the tape and plug the trailer back in.
4. Joy
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
01-28-2021, 11:33 AM
#1183
Tom T
Orange
4. Joy
Thanx for this tip Mike.
I've also seen some other workarounds on the eTrailer & Tekonsha websites.
We too have a vintage 1960 Avion still with old school incandescent lights.
But the 7-pin adapter is not to correct for the trailer's lights LED or standard.
The adapter is to bypass the TV's LED/Light-out circuitry/programming, so the use of it would depend on your Cayenne or other TV.
As I've posted before on here, I've even had to use the adapter on the newer 2016> Ford F250 with limited success in getting it to run at least the trailer's brake lights.
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
01-30-2021, 12:19 PM
#1184
BOTHELL
, WA
Tongue Weight Concerns - 2017 Cayenne
First, let me apologize for not buying an Airstream, but the towing knowledge for Cayennes in this forum looks second to none! I hope you will indulge my inquiry.
I'm looking to buy a new Passport SL 219BH. I have put down a refundable deposit on the trailer and would purchase upon delivery in April. Here are my specs in lbs. I think my "weakest link" may be tongue capacity. I've seen varying specs for the similar Porsche/VW/Audi Chassis ranging at least up to 770 for the same tongue design. I'm also looking at the Andersen hitch instead of the e2 as it appears to be about half the weight (~50 vs ~100 lbm). I plan on 2x20lbs LP tanks and 2 batteries. Family of 4 in the tow vehicle. I bought the TV this month specifically planning it to be a TV.
I suppose my biggest direct questions are: do I need hitch reinforcement? What other kinds of tongue weight management should I be planning (e.g. tongue scale?). I'm aware of the 10-15% tongue loading rule of thumb for sway stability. Besides TW, am I approaching other limits? I live in Western Washington State and will be going over Mountain passes.
Tow Vehicle per the manual, 2017 Porsche Cayenne Special Edition w/ Factory Hitch and Tow Package
Powertrain: 3.6L 300hp@6300 V6, 8-speed automatic, Gas
Curb weight: 4,497 - 5,280 (I have not actually weighed yet, these numbers are per the manual and the DIN 70020 standard)
Front axle max: 2,910
Rear axle max: 3,693 (when towing)
Max gross weight: 6,195
Max braked towing: 7,716
Max hitch (tongue) load: 616 (sticker says the same with or w/o WD)
Gross combined WR: 13,911
Travel Trailer - 219BH Specs on Keystonerv.com
Shipping Weight: 4,672
Carrying Capacity: 1,758
Hitch: 535
Length 25' 5"
Fresh Water: 43 gal
Finally, I've heard my TV may have some sway control via "brake pulsing." I presume this is side independent trailer braking. Are you aware of this being a stock capability?
I have also emailed Mr. Andy Thomas of Can Am and am eager for his response.
I'm extremely thankful for this group's consideration.
01-30-2021, 02:08 PM
#1185
2018 25' International
Slidell
, Louisiana
For American made travel trailers tongue weight must be 13-15% for the trailer to be inherently stable when there are no outside forces (wind, harsh cornering or braking, etc.) at speeds above 62 mph. Thus you can expect tongue weight to be 800-950 lb depending on how much gear and water you are carrying. The Cayenne and similar vehicles are at risk for oversteer and sway under certain conditions with this much tongue weight. The factory hitch does have a bit of flex with these excessive tongue weights so making it stiffer is advised.
The Porsche does have asymmetric braking built into the chassis program module to arrest sway if it occurs and it may be effective in most situations.
Be aware that loaded for camping this combination does increase risk of oversteer and sway. by pulling this trailer, you will be over the limits Porsche has determined are safe for this vehicles in most situations. The vehicle will perform very well but you as the driver will have to maintain awareness to prevent the trailer from getting outside the narrow window of stability. If you keep the trailer in alignment with the vehicle it will do very well, if you don't the trailer will overpower the vehicle and it will go out of control. This is particularly true on steep downgrades on approach to a sharp corner. Manufacturers recommend limits that prevent the trailer from dominating the situation regardless of alignment. You can further reduce risk of sway with a quality hitch but there is not much you can do to prevent oversteer except stiffen up the rear tires with 7 psi of additional pressure, run the fronts 2 psi low and run the trailer tires at no more than 15-20% over minimum load rating from the charts.
01-30-2021, 02:39 PM
#1186
2020 16' Nest
St. Catharines
Porsche Cayenne, VW Touareg, Audi Q7 owners
I thought the recommended Tongue weight was 10 - 15% for American made travel trailers? Has that changed?
01-30-2021, 02:44 PM
#1187
Vancouver
, British Columbia
It is 10-15%, but those with larger trucks for two vehicles tend to shift that band up. Not everyone is towing with a heavy pickup.
01-30-2021, 02:47 PM
#1188
Slidell
, Louisiana
10-15% for the full range of trailer types where additional loads are applied. Closer to 10% for Utility trailers where load can be clustered just forward of the axle, closer to 15% when load is broadly distributed. Custom trailers for boats and such not intended for additional cargo will have a tongue weight optimized for the particular use. Some will be as low as 5%.
01-30-2021, 03:07 PM
#1189
Vancouver
, British Columbia
10-15% per Airstream.
And SAE use 10% (no range, just 10%) for their test standard.
01-30-2021, 03:56 PM
#1190
1967 26' Overlander
Bugtussle
, Oklahoma
Check with Andy to be sure, but I think you lose several inches of ground clearance with the hitch reinforcent. Something to keep in mind if you tow off the beaten path. One of the reasons I freeball. I tow down some roads that would mangle a WD hitch.
01-30-2021, 04:32 PM
#1191
Slidell
, Louisiana
To complete this, the SAE tests encourage use of flatbed utility trailers which are optimized for stability at 10% tongue and result in a stable configuration with the maximum trailer weight.
Airstream and all other manufacturers repeat the industry guidance so if it ever comes up they are able to refer to the standard as an explanation for their rationale.
None of this changes the reality that US manufactured utility trailers are most stable at 10% and travel trailers are most stable at 15%.
01-30-2021, 06:24 PM
#1192
Vancouver
, British Columbia
That must have changed since my version of SAE J2809 was published several years ago. In that version, SAE required the use of box type cargo trailers, and specified the minimum trailer frontal area, with a maximum corner radius. Flat deck trailers were not permitted.
Could you post a reference to the new standard? Has this changed the ratings obtained under the new version of the standard vs the old standard?
01-30-2021, 08:09 PM
#1193
Slidell
, Louisiana
Cargo Utility trailers are required for the performance tests to address impact of aerodynamic resistance. All the utility trailers flat or box have the same stability performance when head and crosswinds are not involved. The sway and oversteer test are done in calm conditions where frontal and side areas are not relevant.
01-31-2021, 12:45 PM
#1194
Tom T
Orange
Welcome Ascendingnod from another non-AS owner!
They advertised our Avions as "Better than an Airstream" - so don't worry about it from this group for your Keystone.
I have a good friend who lives in Bothell, small world!
See my comments in bold italic inserted into your message below >>
Cheers!
Tom
The discussion explained why the 616 lbs is the Euro/UK/TUV rating, & 770 is the USA/SAE rating. So scroll back a few posts to the one where they said that they got the proper USA hitch sticker showing 770 lbs HW, and order one (PM them for how to do that) - or check with your local Porsche dealer up there to order one, & go to Sunset Porsche's Parts website (Portland) for best prices on parts.
Check with Andy T for the best hitch option(s) when he answers. I think he likes the EAZ, but you can also call to discuss with him, but it is international to Canada, so make sure your cell plan has it when you call him.
Also order a Sherline HW scale, then you can pack & distribute your load in the trailer to best effect for your actual net HW to stay within the 770# Cayenne limit - i.e.: load heavy items low & above or behind the axles, bikes & bike rack & spare at the back bumper, etc. - but stay within the 10-15% of Gross Trailer Wt. Rating (get the actual GTWR - their shipping wt. is just a BS number).
If your HW is 600# or under & GTWR is 6000# or under, then you can also opt for a Hensley Cub for not much more than Anderson. Although Hensley & ProPride hitches are heavier at 160# Cub & 180#+/- for Hensley Arrow or ProPride - the 10-15% HW doesn't apply to them because it's only required to hold the trailer coupler on the ball on other hitches - whereas the Hen/PP physically lock the coupler/ball within their hitch head, and the trailer links to the TV with a solid bar that won't go anywhere at any weight.
However, you will want to adjust your trailer loading balance to keep the total HW under the Cayenne's 770# & for your Cay's useful load at both overall GVWR & rear axle WR.
Your door sticker should give the accurate curb wt. as equipped with options, and the higher end of the range would apply to the V8 with full options. You're probably in the high 4000s. - ditto for the actual wt.s for those below.
Get the correct 770# HW rating sticker, as noted above. Also use your Keystone's rear storage etc. areas to load bags, gear, kids' stuff, etc. & other cargo, plus the kids/adults bikes at a hitch mounted bike rack (within the trailer's limits/ratings (or bikes inside) & other trailer loading tricks to keep the 4 passengers etc. + HW & cargo inside the Cay within its specs, as noted above.
You need the actual legal/Federal 'Gross Trailer Weight Rating" GTWR) & the actual Trailer Curb Wt. as equipped - the subtract for yourself what your true carrying capacity will be - from which you will lose some capacity by LP tanks, water/grey/black tanks & everything you pack, as noted above. This carrying capacity & shipping wts. is just marketing fluff!
Hitch: 535
Length 25' 5"
Fresh Water: 43 gal
It is and was just recently discussed a few posts/pages back - read there.
Tom T
Orange CA
01-31-2021, 12:52 PM
#1195
Tom T
Orange
Anybody can adjust their HW to 10-15% by how they load their trailer.
Also FYI All - The 10-15% HW doesn't apply to the Hensley & ProPride PPP hitches, because the 10-15% is only required to hold the trailer coupler on the ball with other hitches.
Whereas the Hensley/PP physically lock the coupler/ball within their hitch head & A-frame attachments assembly, and the trailer links to the TV with a solid bar/tube "Stinger" Tow Bar locked into the TV's receiver & hitch's receiver box - so that hitch won't go anywhere at any weight - it is a sold mechanical connection.
I agree with others that the minimum HW is 10% otherwise.
Cheers!
Tom
Tom T
Orange CA
01-31-2021, 11:11 PM
#1196
Slidell
, Louisiana
Regardless of the hitch design, best practice is to load the trailer so it is inherently stable on a straight road with no external forces at normal travel speed. For travel trailers this would be 12% if you travel about 60 mph, 13% at about 62-65 and 15% over 65mph.
The Hensley design arrests sway only when the articulation angle is close to zero, so only on straight roads. On a modestly sharp corner the trapezoid angles become sufficiently shifted that the trailer can a will initiate yaw acceleration. In addition if the trailer is sufficiently unstable, tire slip can allow the trailer to generate sufficient yaw acceleration and sway. The hitch is good, but it can't work miracles so it is best not to force the hitch to constantly yoke the trailer. Better for the trailer to naturally track with the vehicle and rely on the hitch only for unusual conditions.
02-02-2021, 11:17 AM
#1197
Tom T
Orange
A good thoughtful answer Brian.
To be clear, I've only suggested in here to load the trailers in a balanced manner using a Sherline or other scale, such that there isn't excessive tongue weight, as well as heavy stuff low and near the axles - in order to avoid "a Lucy moment" (Lucille Ball's rocks & canned goods scenes in "The Long, Long Trailer" classic movie).
Likewise to be clear, the solid locked tow bar connecting trailer to TV of the Hensley & ProPride hitches, with the ball & coupler solidly locked into the head assembly & properly mounted & adjusted eliminates the need to hold the coupler on the ball with the 10-15% weights of other hitches - although the trailer should still be balanced fore-&-aft, street-&-curbside, weight-wise in order to prevent yaw, porpoising, etc.
And as always - safe driving & towing, proper tires, condition & inflation, etc. are the rule of the day for all towing.
Also, if I recall - the active sway correction angle for the Hensley/ProPride hitches' "trapezoid" that you mentioned is something like 30+ degrees, and then the TV induced turn override kicks in in order to make tighter turns (which I mentioned in a prior post a shot while ago).
So no - one should not be making tight turns at too high of a speed for conditions when towing with any hitch, except to the extent necessary & stable in an emergency maneuver.
In any case, I do believe that the Hensley/ProPride hitches do a far better job in stopping dangerous trailer sway, than does any other form of friction, cams, torsion, pneumatic (shocks), etc. methods of doing so.
Cheers!
Tom
Tom T
Orange CA
02-02-2021, 08:28 PM
#1198
2019 27' Tommy Bahama
London
, Ontario
I thought some on this thread might like this video. It’s not an SUV it’s a Dodge Caravan towing a 1993 30’ Airstream. The first link is Ana who works in our sales department doing her first pass through the slalom. The second is me driving. The same combination.
https://youtu.be/CLD_V7F3JsY
https://youtu.be/5jrKXyVR044
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
03-02-2021, 05:02 AM
#1199
Dalton
, Ohio
03-03-2021, 05:10 PM
#1200
1967 26' Overlander
Bugtussle
, Oklahoma
Thanks for the informative article. I was blown away to learn that Thomas Aquinas and John Duns Scotus were able to foresee the Cayenne's exceptional performance as a tow vehicle over 700 years ago! This confirms what I have thought all along. Magnificent!
