Old 06-17-2019, 03:59 PM   #741
Bruce B's Avatar
2021 25' Globetrotter
Jamestown , Rhode Island
Thanks Phil and Cedonly,
I have no concerns towing with the Q7. I've even gotten Andy to answer a few emails where he suggests that the experience will be entire different than what I am used to.
Not sure what I'll do yet..
Next question, can you still open the tailgate when hitched to the trailer with a shortened hitch stinger...?
Thanks again,
Bruce
Loving our 2021 Globetrotter 25 shopping for the next tow vehicle and 2020 GMC 2500 Sierra Denali Duramax.
Bruce B is offline   Reply With Quote
Old 06-17-2019, 06:24 PM   #742
Phil Krogh's Avatar
2008 16' Safari
Woodinville , WA
Yes. Mine clears the propane tanks by about 4 inches.
Phil Krogh is offline   Reply With Quote
Old 06-18-2019, 10:16 AM   #743
cedonly's Avatar
2013 20' Flying Cloud
minneapolis , Minnesota
Tailgate
No problems with the tailgate. On the cayennes it will open but if the tv and as are at an angle it will have interference
cedonly is offline   Reply With Quote
Old 06-18-2019, 10:57 AM   #744
mikextr's Avatar
1967 26' Overlander
Bugtussle , Oklahoma
Originally Posted by Bruce B View Post
I opted for a Q7 with the adaptive chassis package mostly because I wanted the 4 wheel steering after 10 years of parking a truck...Any thoughts?
Bruce
The Q7 with the adaptive chassis package is quite possibly the best TV available today. I'm a Porsche guy, but for a TV I think I would have to choose the Q7 over a Cayenne if I was in the market today.
mikextr is offline   Reply With Quote
Old 06-20-2019, 06:31 AM   #745
2007 25' Safari
Rogers , AR
I tend to tow in sport mode. For one it starts out in first gear and it feels much more stable. Probably doesn't make a difference but I figure being lower to the ground might aid in aero.
What mode do you tow in?
Mr. Merk is offline   Reply With Quote
Old 06-20-2019, 07:28 PM   #746
Bruce B's Avatar
Just brought it home last night.
Hitched it up just to take a quick look...
Bruce
ID:	343948   Click image for larger version
Old 06-20-2019, 10:47 PM   #747
Tom T
Tom_T's Avatar
Orange , California
Bruce
Looks great Bruce - now take them out for a run!
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 06-21-2019, 02:16 AM   #748
Bruce B's Avatar
I’m trying to get a reasonable number of miles on the Audi before doing more than a quick tow around the neighborhood!
Of course I will report back...
BB
Old 06-25-2019, 06:20 PM   #749
2018 Basecamp
San Jose , California
Bruce,
I have a 2017 Audi Q7 3.0T as TV for our 2018 BC. I'm considering a Globetrotter 23 or 25, so would like to upgrade from straight towing to WD hitch.
Do you have, or can you point me to, pictures, parts list, and instructions for the hitch receiver reinforcement done on your Audi Q7? I'd like to get a local shop in California to do it for me since I'm 2500 miles away from Andy and CanAm.
Mark
P.S. You can private message me at donnelly.m@mac.com
madmac157 is offline   Reply With Quote
Old 06-25-2019, 11:12 PM   #750
Mountain View , California
I did my reinforcement at this place
https://www.yelp.com/biz/midnight-au...redwood-city-7
You may experience some scheduling issues, but overall I am very happy with the service.
bono is offline   Reply With Quote
Old 06-27-2019, 12:12 AM   #751
2018 Basecamp
Bono, thanks. I’ll give them a call since I live in NorCal.
Mark
Old 07-26-2019, 07:57 PM   #752
2018 Basecamp
Hey Bono, I got the 2017 Q7 hitch receiver reinforcement done this week at Midnight by Luis.
He first modified the hitch receiver by welding a small section of 2” box tube underneath the existing receiver between the existing safety chain hookup holes. A small flat steel plate with 1/2” bolt holes drilled into it got welded to the modified receiver. He welded a new safety chain hookup ring into place. The long reinforcement piece was fabricated out of 1/2 inch thick flat plate solid steel, measured and cut, bent into shape by a 10 ton hydraulic press, and then attached to the rear suspension support and the modified hitch receiver plate with 1/2” Grade 8 bolts of medium carbon alloy steel, quenched and tempered. The bolts were torqued to 110 ft/lb.
In my opinion, the shaped steel plate looks nicer than the welded 2” square tube arrangements, has very little impact on ground clearance, AND IS REMOVABLE to allow maintenance of muffler or suspension. Although, I'm not an engineer, I feel confident it will likely work as well as the welded 2” tubes because the reinforcement is designed to put pressure directly between the hitch and rear frame support, and to not put shear load on the bolts or the suspension wishbones (the bolts are in line with the load).
For now, I'll just try towing my little 16 foot BaseCamp with WD to level out the car and trailer, and then see how it goes. I got a baseline empty weight CAT scale measurement of the car right out of the shop. I'll do the 3- pass CAT weighing with a loaded trailer and car next week. I'll report if I have any issues on the road.
madmac157
Old 07-26-2019, 11:15 PM   #753
Please post the photos. I think I know how your reinforcement looks like. I believe Luis did it on the first Cayenne he worked on.
Thanks!
Old 07-27-2019, 09:19 PM   #754
2018 Basecamp
See attached Photos of the 2017 Audi Q7 hitch receiver reinforcement using 1/2” thick steel plate tang and hardened heavy duty bolts.
Mark
ID:	347779   Click image for larger version
ID:	347781   Click image for larger version
ID:	347783   Click image for larger version
ID:	347785   Click image for larger version
Old 07-27-2019, 10:25 PM   #755
2018 Basecamp
Final product looks like this
Old 07-27-2019, 11:20 PM   #756
Looks good, thanks for sharing!
Old 07-29-2019, 06:45 AM   #757
2007 25' Safari
Rogers , AR
Finally got a few pics of the pair.....getting ready to head out in a month!
2007 Airstream 25FB Safari LS - GY Endurance Prodigy Wireless - Andersen
2005 Chevy Silverado Crew Cab 2500HD Duramax Allison
2008 Porsche Cayenne Turbo 500hp/516lb-ft
2014 Porsche Cayenne Turbo S 550hp/553tq
2005 GMC Sierra Crew Cab 5.3L built 4L60e, 40k Tru-cool
Old 07-29-2019, 09:30 AM   #758
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we tow a sport 22Fb with our Audi q5 Sline.
no issues.
we get about 1/3 less gas millage when fully loaded
waninae39 is offline   Reply With Quote
Old 07-30-2019, 05:52 PM   #759
ARF
ARF
2017 27' Flying Cloud
Breckenridge , CO
Performance post Diesel-gate recall work
Thought I would share how our Audi Q5 TDI is performing after the recall work was done on the emissions system. We completed our first extended trip since I had the recall work done, a 5000 mile trip towing our FC 27FB.
Towing - Dropped from 15-16 MPG to 14 MPG. However, biggest change is the amount of Blue Def/Ad Blue we went through. We were only getting about 500 miles per gallon of Blue Def.
Not towing - Dropped from 31 MPG to 29 MPG. We live in Summit County, CO and the MPG drop is more significant after the recall work. Went from 29MPG at high elevation to about 27MPG. In the winter, it is even lower, about 25MPG. Cost of living in paradise at 9500' elevation.
Anyone else experience the huge increase in the amount of Blue Def used when towing?
ARF is offline   Reply With Quote
Old 07-30-2019, 07:25 PM   #760
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this is our af22fb with the q5 when we first picked it up
and stuck between white 18 wheelers
Name:	airstream sport 22FB- in the rain3.jpg
ID:	348080   Click image for larger version
Name:	as22Fb between large trailers-sm.jpg
Porsche Cayenne Diesel pman Towing, Tow Vehicles & Hitches 22 05-06-2021 07:38 AM
Input on Porsche Cayenne as TV (& 928??) Tom_T Tow Vehicles 154 07-08-2016 11:47 AM
Porsche Cayenne V6 or s socool69 Tow Vehicles 27 01-21-2015 05:28 AM
Porsche Cayenne with Airstream & SOB cameront120 Tow Vehicles 7 06-23-2008 12:29 PM
