Old 01-30-2018, 09:12 AM   #581
2014 27' FB Eddie Bauer
Orleans , California
Porsche Cayenne, VW Touareg, Audi Q7 owners
Originally Posted by ChiAir View Post
Lol Andy I knew you’d say that. I’ve been emailing with your colleague Philip who has been super helpful. I’m curious what the end users are saying. Thanks!!
Love pulling our 28’ Eddie Bauer with the Touareg TDI. As Andy said, less space for stuff but much more convenient for getting around and backing in.
Shawn & Kara
Hamish is offline   Reply With Quote
Old 01-30-2018, 01:09 PM   #582
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
There are many who tow with these who get a little explanation fatigue so they don’t fallow the forums as much.
One our customers with a Cayenne GTS. (Likely the best tow handling tow vehicle you can buy) named his Airstream “This and the Porsche “That”. Because people often ask “you tow this with that”.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 01-30-2018, 03:27 PM   #583
Mountain View , California
Love the comment!
Originally Posted by Andrew T View Post
(...) Of course the Cayenne is much safer as well.
bono is offline   Reply With Quote
Old 01-30-2018, 05:49 PM   #584
ID:	303259 we have better images but this is easily available.
Shawn & Kara
Old 01-30-2018, 05:53 PM   #585
Coldwater , Ontario
Beautiful, where is that?
bbandeddie is offline   Reply With Quote
Old 01-30-2018, 06:29 PM   #586
Faver Dykes State Park Florida...30 sites. Very quiet and just 20 mins or so from St Augustine
Shawn & Kara
Old 01-30-2018, 08:39 PM   #587
dooleyfan's Avatar
2017 30' International
Collingwood , Ontario
“Explanation fatigue”! We get that a lot towing a 30’ with a Cadillac SRX. 5,000 miles and crossing 2 mountain ranges, we’ve had no problems at all. My wife and I have considered printing cards explaining all the reasons why we don’t need a big truck. But we don’t because it’s a great conversation starter.
https://www.bettynearl.com
dooleyfan is offline   Reply With Quote
Old 01-30-2018, 08:41 PM   #588
waninae39's Avatar
2017 22' Sport
NCR , Ontario
as22FB towed with audi q5
i have no problem pulling this trailer
fully loaded , my gas mileage goes down by 35%
waninae39 is offline   Reply With Quote
Old 01-30-2018, 08:45 PM   #589
Our last trip (albeit pretty flat and doing no more than 60mph) we managed about 16 mpg with our TDI
Shawn & Kara
Old 02-11-2018, 04:00 PM   #590
Glencoe , Illinois
Air suspension or no?
I’ve read the threads and several are years old and everyone’s use case is different.
We just bought a 30’ safari. 6500# dry.
Will buy an ‘11 or ‘12 CS. Should I get one with air suspension or not?
PS will take to Can Am for hitch reinforcement, brake controller, eaz lift elite and sway control.
ChiAir is offline   Reply With Quote
Old 02-12-2018, 05:05 AM   #591
2017 27' Flying Cloud
Pittsburgh , Pennsylvania
I was afraid the compressor would run all the time so I bought the normal suspension. It works fine but I’m wondering the same thing.
foster2 is offline   Reply With Quote
Old 02-12-2018, 06:56 AM   #592
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
I have a 2014 ML diesel with the air ride and it works well. Towing my 25 fb I use sport mode which has increased dampenING over the comfort mode. The air ride keeps the vehicle level under load which helps with load distribution on the TV. I had my setup and hitch reinforcement done by Canam. They set it up in sport mode which maintains a constant height. I don't notice the compressor working ever and would not worry about it.
TRIPPPIN is offline   Reply With Quote
Old 02-12-2018, 11:10 AM   #593
If I understand weight distribution correctly, air suspension does not transfer any load (or any significant load). I would appreciate, if somebody correct me, if this is not correct.
Old 02-12-2018, 08:04 PM   #594
wulfraat's Avatar
Broomfield , Colorado
You are correct. Air suspension does not transfer load from one axle to another on the TV.
wulfraat is offline   Reply With Quote
Old 02-13-2018, 07:21 AM   #595
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Ditto, hence the fallacy of installing rear air bags to pick up a squashed rear end to level, and assuming all is well.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 02-13-2018, 07:25 AM   #596
dasams's Avatar
Palm Desert , California
I agree as I've adjusted my WD hitch many times trying to move weight forward with limited success. Having said that, I've been very happy with the tow performance of my Cayenne S.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 02-13-2018, 12:02 PM   #597
Which hitch you are using? With ProPride I do not have problems transferring weight to the front axle up to the axle limit.
Old 02-13-2018, 01:54 PM   #598
dasams's Avatar
Just to confirm, your X5 has air suspension, right? I used a Husky Center Line WD hitch with my 25 FC and am currently using an Equalizer with our 27 FC.
2018 FC 27 FB
2017 FC 25 RB Gone
Old 02-13-2018, 03:29 PM   #599
No, I do not have air suspension, just standard coil springs.
Old 03-12-2018, 03:41 PM   #600
Centerville , Ohio
VW Touareg TDI Post Recall Update Towing
Has anyone towed with a VW, Audi or Porsche TDI after having the Recall Update performed?
I have a 2013 TReg TDI. I had not towed prior to the Recall Update. Last weekend I pulled a 3,600 lb trailer for roughly 20 miles on mostly flat Interstate (I-75) near Dayton, OH. I set the cruise at 64 MPH. The tranny was constantly shifting and running at 1,800 (probably 8th), then 2,000, 2,500 and even 3,000 RPM.
I haven't read where anyone experienced this in a pre-Recall TDI. I have about 2,000 miles on my pos-Recall TDI. The low gear shifting is entirely different when the engine is cold. It extends the upshift in at least the first 3 gears to 2,000 - 2,500 RPM. Do you think the shift changes are effecting towing.
I hope at least one of you has towed with an Updated vehicle.
Thx
TBDub is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Porsche Cayenne Diesel pman Towing, Tow Vehicles & Hitches 22 05-06-2021 07:38 AM
Input on Porsche Cayenne as TV (& 928??) Tom_T Tow Vehicles 154 07-08-2016 11:47 AM
Porsche Cayenne V6 or s socool69 Tow Vehicles 27 01-21-2015 05:28 AM
Porsche Cayenne with Airstream & SOB cameront120 Tow Vehicles 7 06-23-2008 12:29 PM
