Old 08-26-2020, 02:31 PM   #1
sanibel , fl
please help the newbie
All;
Trying to determine if anyone is successfully towing a 16-22 ft airstream with a 4wd, 6 cylinder toyata tacoma???
Can you tell me what trailer you are pulling and what trailer limit you would recommend in length and weight for the tacoma? I know it says 6500 lbs for the truck but that seems optimistic.
Thanks in advance for the value of your actual experience
Bill
weroach is offline   Reply With Quote
Old 08-26-2020, 06:16 PM   #2
2020 23' Flying Cloud
Sebastian , Florida
You seem to be conservative in your expectations- that’s fine. Do you expect to be driving mountain passes? Load your trailer to the gunwales?
I would expect you’ll be comfortable if you keep the loaded trailer weight to 5000 #, give or take, WITH an appropriate hitch. If you push it... well, Tundras are nice too.
Also consider the tongue weight, your truck’s payload, and GCWR.
Also consider how much togetherness you and your traveling companion can handle.
There are tons of posts on this subject. Fine tune your browsing skills!
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 08-26-2020, 06:22 PM   #3
The Joymobile
2011 22' Sport
MERIDEN , CT
I JUST purchased a 2011 Sport 22 with a dry weight of 3,850# and gvw of 4,500# and tow it with a 2016 Nissan Frontier. The Frontier has a tow capacity of 6,100#. I maiden voyage was 950 miles through NY, PA, Ohio and Connecticut. Pulled very well.
JeffofCT is offline   Reply With Quote
Old 09-01-2020, 11:25 AM   #4
sanibel , fl
thank you!!
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
Newbie Help Please with purchase jaguarmk2 Member Introductions 5 03-05-2011 11:01 PM
Newbie with a roof leak. Please Help! JackP Member Introductions 0 05-04-2009 07:52 PM
Electrical Newbie with circuit breaker that won't reset...help please! Kerina Electrical - Systems, Generators, Batteries & Solar 13 05-04-2008 09:18 AM
Newbie trying to decode Serial Number: HELP, please? rocklobster Member Introductions 4 08-06-2007 08:09 AM
