Old 11-13-2023, 04:59 PM   #1
steilkurve's Avatar
2020 22' Bambi
2022 25' Globetrotter
St-Laurent , Quebec
Not another TV thread!
Ok. I promise. This isn't another TV thread. I know how ugly these get. ;-) No, I'm trying to understand what makes my rig so wobbly over bumps and potholes. What I got:
-RAM 2500 Cummins (just coils no air suspension)
-2022 Globetrotter 25FB with two ACs
-Tongue weight is 975#
-Trailer tires are at 65 PSI
-BlueOX Sway Pro with 1000 bars at the 9th link
I did move my batteries inside under the bed and added 3, plus a beefier inverter which likely added 200# in total there but that also removed 60# from the battery box on the tongue. And the tongue weight barely changed after the upgrade.
My right is super stable on smooth roads. I love it then.
On bumps and potholes, it bounces a lot. I love it much less in those instances.
I'm attributing popped rivets and stuff coming to loose to the bouncing.
Went from Equalizer to BlueOX thinking a less rigid hitch would transfer less of that to the trailer. It helped as movement of one seems to affect the other less but the truck still bounces and transfers it to the trailer on big bumps and potholes.
What is the biggest culprit more likely?
-The truck
-Too much weight at the front of the trailer
If the truck, what is folks' experience with stiffer shocks (like Bilsteins) and LT tires (over the OEM Transforce ATs). Makes a difference in stability over bumps and potholes?
Thanks all!
steilkurve is offline   Reply With Quote
Old 11-13-2023, 05:01 PM   #2
2021 28' International
Knoxville , Tennessee
Wobbles....? Define what you're experiencing please.
Gibson3798 is offline   Reply With Quote
Old 11-13-2023, 05:04 PM   #3
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Sorry. Better way to describe it is bouncing. Changed the word in my original post. The truck bounces too much (IMO) over bumps and potholes.
Old 11-13-2023, 08:02 PM   #4
2017 23' Flying Cloud
Bartlett , Tennessee
Are you talking about porpoising?
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 11-13-2023, 08:12 PM   #5
Flagstaff , Arizona
Sounds like it to me and pretty classic for the Blue OX WDH.
When I changed from the Blue Ox WDH to the B&W Continuum WDH, no more porpoising.
2022 25' GlobeTrotter FB <->2023 Ford F-150 PowerBoost 7.2kW ProPower
Electric Globetrotter
goldenchase is offline   Reply With Quote
Old 11-13-2023, 08:12 PM   #6
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Yep. I am. The truck bounces on its suspension when going over big bumps and potholes.
Old 11-13-2023, 08:15 PM   #7
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Well, I had the issue with the Equalizer. Cannot say it’s new since BlueOx.
Old 11-13-2023, 08:29 PM   #8
I have always had the Blue Ox set up (in the 8th link, FWIW) you have and the same 2500 Ram. I've never had that experience.
I run with a higher trailer tire PSI than you.
Old 11-13-2023, 09:12 PM   #9
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Interesting. A 28 International would be rear bed correct? Your actual tongue weight is likely lower than mine. Mine’s a front bed. And I’ve added weight on top of that with the batteries. Your trailer could be more balanced. Don’t know. Just speculating.
Old 11-13-2023, 09:59 PM   #10
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Don't see where you mention the year on the truck. Could it be that your truck's shocks are not up to the task?
Richard
11018
richard5933 is offline   Reply With Quote
Old 11-14-2023, 05:43 AM   #11
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
It’s a 2021. It can handle the weight for sure. Barely squats when I lash it up. It’s really the handling over rougher roads that I’m trying to improve.
Old 11-14-2023, 06:20 AM   #12
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
slow down or avoid them, rough roads are just that, rough on everything
rbs is offline   Reply With Quote
Old 11-14-2023, 06:45 AM   #13
JJTX's Avatar
2018 19' Flying Cloud
South of Austin , Texas
2500 Frames are a more rough ride while towing.
What your describing is perfectly normal as far as I can tell.
JJTX is offline   Reply With Quote
Old 11-14-2023, 06:57 AM   #14
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
I have a 25’ FB twin, and I use the blue ox Swaypro. I had the porpoising you’re describing. I beefed up my rear suspension with a Roadmaster Active Suspension and swapped the factory shocks for Bilsteins. Problem 90% solved. I can still feel it some on a very bad sectioned concrete highway, but it’s not much worse than when I’m not towing.
I do pull with a half ton, but I think the problem isn’t payload or hitch related. I think it’s manufacturers wanting a more car like ride from a truck. Just my opinion, of course.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
GettinAway is online now   Reply With Quote
Old 11-14-2023, 07:15 AM   #15
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
For sure slower speeds help but this isn’t the cause here I think. Even when I drive below the speed limit, on an unavoidable bump like a bad expansion joint, it bounces beyond normal IMO.
Old 11-14-2023, 07:21 AM   #16
dznf0g's Avatar
Oswego , Illinois
Although I have a Chevy 1500, the suggestion of a better shock is not a bad idea. Although probably not a total cure, I think a set of Bilsteins would help your overall handling. I put 5100s on the rear and 4600s on the front and noted a considerable difference. however, I had some miles on the old ones. about 50k when the rears were replaced and 85k when the fronts were replaced.
If you go that route, gain some suggestions on model # for your particular truck.
-Rich-
Old 11-14-2023, 08:24 AM   #17
Mine is a rear bed, so you could have a point there.
My International rides rock solid with never a hint of what you encounter. Try upping your PSI in those tires, it can't hurt.
Old 11-14-2023, 08:37 AM   #18
2019 28' Flying Cloud
Broward , Florida
Your bouncing is most likely coming from the WD hitch. When you install a WD hitch it introduces a spring into the system. This spring, unlike the springs on your truck, does not come with a shock absorber. Once it starts bouncing it keeps on going. Try removing the WD hitch and see how it behaves. Your truck is big enough that it doesn't need a wd hitch.
Andy543 is offline   Reply With Quote
Old 11-14-2023, 09:09 AM   #19
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Thanks. I did ride at 80 PSI for a while. After reading several posts here on the forums, I brought them down to 65. My impression is that it has helped stabilize the trailer and has reduced the wear and tear inside. Wouldn’t lower PSI lower make it less bouncy?
Old 11-14-2023, 09:13 AM   #20
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Yep. Towed without. It’s not better. My TW is heavy enough that the weight off the front wheels is making it even less stable.
A question. My front axle unloaded weight is about 5K. With the trailer on but with no WD, I get the front at roughly 4600. With WD, I achieve about 4800. Should try and transfer even more weight forward?
Just another hello from another newbie nanaenes1 Member Introductions 7 12-16-2014 12:45 PM
Another trip, another repair swanky Classic Motorhomes 6 07-07-2009 03:24 PM
Not just another Univolt thread Lumatic Batteries, Univolts, Converters & Inverters 0 01-18-2009 07:29 PM
OH NO! ...Not another towing question blucloud Off Topic Forum 4 02-11-2006 06:29 AM
