Old 09-02-2019, 07:50 AM   #1
FLEMING ISLE , Florida
New to towing AS
Wife and I are renting a 25' FC and are planning on towing it with our 2013 Jeep GC. It's an overland summit awd with the towing pkg and 5.7 V8 Hemi. Our towing capacity looks fine,b but concerned about hitch weight. Any thoughts. Thank in advance.
drewsully is offline   Reply With Quote
Old 09-02-2019, 07:59 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
What is the payload on your Jeeps door sticker?
CRH is online now   Reply With Quote
Old 09-02-2019, 08:17 AM   #3
AirstreamJim's Avatar
2009 34' Classic
Lake Worth Beach , Florida
I wrote this in response to a similar question a couple years ago:
I love my 2015 JGC EcoDiesel, which has basically the same specs as yours. I towed our '07 Safari 25FB from Salt Lake City home to Long Island and it did a great job. But the payload capacity is a problem: with a 25FB you will be maxed out with just you in the Jeep and NO passengers or cargo. The 25FB has a tongue weight of almost 900 lbs, which, with driver, eats up all of your 1,050 lbs of payload. After a few trips, we upgraded to a RAM pickup.
You may be fine with a 23.
Check out these threads:
http://www.airforums.com/forums/f238...le-146333.html
http://www.airforums.com/forums/f463...-140961-2.html
And there are more. Go to google and search for "cherokee site:airforums.com" (without the quotes) to get all the threads about the Grand Cherokee on Airforums.
Good luck!
The Diesel engine in my JGC doesnít change any of the important specs for towing. The Hemi engine has the same tow capacities and max payload rating as the diesel. (Interestingly, I looked at several JGCs on a dealer lot, all configured differently and with different engines, and all had the same max payload rating: 1,050 lbs. Maybe coincidence, maybe FCA thinks it best to limit Jeeps for some reason.
What Iíve learned since then is that the 900 lb tongue weight I mentioned is probably a pipe dream. The 25FB fully loaded for camping often has a tongue weight north of 1,000 lbs, which means youíll need to have a self-driving vehicle because once a driver gets in, the Jeep is over its payload rating.
We had a very well-regarded dealer tell us we would be fine with the Jeep pulling the 25í Airstream. Of course he wanted to sell us the trailer. Donít fall into the dealerís trap.
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2009 Airstream Classic Limited 34
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is online now   Reply With Quote
Old 09-02-2019, 09:08 AM   #4
Thanks, great info. Renting from an individual on Outdoorsy. We'd be driving it about 200 miles all highway from Jax to Savanah. Also, owner says it weighs 6200 lbs. It is a 2010 flying cloud. Does this soung about right? Thanks again.
Old 09-02-2019, 09:16 AM   #5
1050 lbs
Old 09-02-2019, 09:28 AM   #6
2009 34' Classic
6200 lbs is the lightly loaded weight. Dry weight officially is 5,443 lbs., and max weight is 7,300 lbs.
Unless youíll be dry camping and need to bring water, leave all the tanks empty when towing. No cargo in the Jeep; you donít have capacity for it.
WBCCI 1433
Old 09-03-2019, 09:18 AM   #7
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
We tow a 1978 31' Sovereign with a the Diesel Jeep Grand Cherokee. It is a super tow vehicle. We have 20" low profile tires, a cheap weight distribution hitch, 2 friction sway bars and a P3 brake controller. Been all over the country without a problem. Even been side swiped at 65 mph and were straight as an arrow. Our tongue weight is around 650 lbs.
tcrum is offline   Reply With Quote
Old 09-03-2019, 10:37 AM   #8
To lighten the load, do we need to fill tanks if we are going to a site with all the hook ups. It will be our only stop on our maiden voyage. Thanks and sorry for all the ? Looking forward to our first time Rv'ing
Old 09-03-2019, 04:48 PM   #9
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
Rent a 23 to give you some room TV wise...
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 09-03-2019, 04:52 PM   #10
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
or rent an F150 from AVIS or what have you
wulfraat is offline   Reply With Quote
Old 09-03-2019, 05:13 PM   #11
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
IMO your tow vehicle is a little too small......I would rent a smaller airstream. Pulling a camper with an undersized tv is not fun.
Remember, horsepower is the least important factor in a tv......Everything else is more important.....
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Old 09-03-2019, 05:16 PM   #12
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
You got side swiped in a vintage Airstream and you are still using it?
Old 09-03-2019, 05:57 PM   #13
Richmond Hill , Georgia
I tow that area regularly and live in Savannah - a couple thoughts.
Iíd keep the tanks near empty for the trip. With tanks empty it is unlikely the trailer is near gross. Go to any truck stop if you want an accurate weight. My local waste drop off site also has a scale but I question its accuracy.
You didnít mention if you are setup with a brake controller or anything about the brakes on your truck. Stopping is typically more an issue than going.
The roads are generally flat - If needed I would go west of Jax on the bypass rather than east on the high bridge across the St Johns or thru the center on 95. ( If you have to go east look for the May port ferry - itís more fun anyway). If you really want to take it slow travel US 17 that parallels 95 - keeping in mind there is another high bridge in Brunswick and a third in Savannah. Any number of good seafood places. If Dorian doesnít wipe out the shrimp try B&J in Darrien for shrimp right off the boat.
Enjoy
RobdaSlob is offline   Reply With Quote
Old 09-04-2019, 09:30 PM   #14
2015 25' Flying Cloud
Gainesville , Florida
I tow a FC 25' RB with an 07 Diesel Grand Cherokee. Not sure if they improved the rear suspension since 07, but my TV is really challenged to handle the tongue weight of the AS. I have a weight-distribution hitch that supports 1000#. Even with that, my back end used to really bottom out on bumps. I fitted helper airbags which have made a big difference in reducing suspension travel.
My sense is that with a stock rear suspension you will be bottoming out. If you are not using a weight-distribution hitch as a part of your tow set up, I think you are taking on a lot of risks. You also really need to have a decent brake controller for towing.
FWIW, I do not tow above 60 mph with my set up. The challenge isn't having the power to go, you need to be able to stop. Be Careful.
Specsalot is offline   Reply With Quote
Old 09-04-2019, 09:59 PM   #15
waninae39's Avatar
2017 22' Sport
NCR , Ontario
your jeep looks underrated to pull that AS safely.
i would look into a longer base 1/2 ton or 3/4 ton Ford, GM, Ram truck
you need a vehicle with a long wheel base, and sufficient margin in both tow pull and tongue weight
as others have stated, don't be stuck under-powered as you can get into trouble fast
look at the towing video on the CANAM RV site
andy is a very good guy to talk to and he can give you great advice
https://www.canamrv.ca/
waninae39 is offline   Reply With Quote
Old 09-05-2019, 07:16 AM   #16
Thanks everyone
Thanks for all the helpful advice. We unfortunately had to postpone trip due to Dorian. Looking forward to rescheduling and getting on the road. Cheers!
Old 09-06-2019, 11:07 PM   #17
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Listen to W-39 above.
Search my other posts for experience with a GMC Yukon and 25' AS ...
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 09-08-2019, 05:06 PM   #18
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
Worse case scenario - Your trailer COULD weight 7300lbs and tongue weight COULD be 15% of that which would be 1095lbs of payload.
StreamDog is offline   Reply With Quote
Old 09-08-2019, 07:35 PM   #19
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Regardless of what others have seen, the *only* thing that counts is the actual sticker on the real door post of the Jeep you will be using. If you are going to use numbers, that number is the one to go by. Once you have the number, you need to look at what is (or likely is not) already included before the number is calculated. You may already have more stuff in the Jeep that what they figured when they did the number.
The tongue weight *plus* the weight of the hitch have to go somewhere. They (at least in part) will show up on the axles of the Jeep. Depending on what sort of WD hitch you have and how it is adjusted, that gets into the calculations.
One example:
1,000 lb rated tongue weight
1,200 lb real tongue weight "as packed with our stuff"
300 lb hitch
450 lb of "needed stuff" in the back of the TV
1000 lb of passengers and dogs
It's unlikely that all will fit if the label on the post reads 1,050 lb
Old 09-09-2019, 06:26 AM   #20
Peninsula , OH
I have used this same setup for the last couple of years. 2016 V8 Summit GC and 25 foot. Get an equalizer hitch and you should be fine with the hitch weight distribution.
dmackay is offline   Reply With Quote
Towing 19ft Bambi with 2009 Tacoma v6sr5 w towing package Shany Tow Vehicles 6 07-03-2017 10:44 PM
Avoiding Chicagoland while towing? EZ-Pass when towing? JustSomeGuy On The Road... 86 04-24-2015 10:33 PM
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
