Old 04-24-2019, 03:34 PM   #21
1999 28' Excella
Lake Mary , Florida
Suggest you do a test drive before making the big TV investment. And so many choices,,,,,,,2 door, crew cab, quad cab. Try your local Enterprise or Hertz car rental, they usually have pickups and good 2 day weekend rental rates. Try a Dodge, Ford and Chevy...,,,,,even a Nissan if they have one. Drive to the store, on the interstate and around town. Figure out what size and style truck you want before commitment.
suncoasteng is offline   Reply With Quote
Old 04-24-2019, 04:22 PM   #22
2019 27' Tommy Bahama
Ocean Pines , Maryland
Hitch lock
What do you recommend to lock the hitch when youíre away from your Airstream
Crystalcp is offline   Reply With Quote
Old 04-24-2019, 06:20 PM   #23
I chose the f150 ecoboost due to its safety and gas mileage. If you go this route make sure to check the door sticker thatís yellow, it should read a capacity north of 1600 lbs. spec with max tow and heavy duty payload. I didnít get the heavy duty payload and Iím still at @1759 capacity.
Jay Leno asks the ceo of airstream if an f250 is necessary in this video itís worth a watch.
https://youtu.be/6Vi37dKPCrg
Kanusport is offline   Reply With Quote
Old 04-25-2019, 04:42 AM   #24
JJTX's Avatar
2018 19' Flying Cloud
South of Austin , Texas
Whatever you do, realize that not all '1500 series trucks are the same, and not designed for the max towing capable of that truck.
You usually need a feature package that is specific to that brand.
JJTX is offline   Reply With Quote
Old 04-25-2019, 08:05 AM   #25
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
We use this one and are very happy with it. However, if someone is determined to steal your airstream, they will. You need to just make it as inconvenient or difficult as possible, increasing the chance they will move on to easier pickings.
thewarden is offline   Reply With Quote
Old 04-25-2019, 01:11 PM   #26
JJTX's Avatar
AMPLOCK is the only lock I will put on my trailer when the time comes.
Old 04-26-2019, 05:47 AM   #27
Tavares , Florida
Originally Posted by Squirestrhn View Post
hey guys!
so we are currently in the process of looking at a 25-27ft airstream and we are needed a truck to be able to tow (currently have a VW CC). we will be purchasing both at the same time, so im trying to keep it ina budget hopefully. what truck recommendations do you have that will fit what we are looking for? side note we will be one the road for 2-3 months and traveling across the us in this time. i was looking at the f-150s but new to this whole process and just extremely excited! would this be adequate? any help would be appreciative!
Hi Squirestrhn,
Sent you a private message yesterday morning, with an option to consider.
wv2017
wv2017 is offline   Reply With Quote
Old 04-27-2019, 10:26 AM   #28
SteveNdebbie's Avatar
Dalton , Ohio
Originally Posted by thewarden View Post
The 25 and 27 have tongue weights in the 1000 lb range regardless of what the brochures tell you. The 25 has a heavier tongue weight than the 27. I point this out because you need to pay attention to the cargo capacity of the vehicle you choose. Depending on options, this is different for every vehicle, so pay attention to the cargo capacity sticker on the specific vehicle you are looking at.
When you add up the weight of the trailer tongue, the weight distributing hitch, driver, passengers and gear you stow in the cab or the box (in the case of a truck), you need to make sure that you are not exceeding the cargo capacity of your vehicle. Most, if not all 1/2 ton trucks will be maxed out, or close to. That may not be an issue for you.
If you are traveling in an area that has hills, or mountains, you will appreciate the power of a 3/4 or 1 ton diesel going up and the larger brakes and engine brake when going down, as well as a cushion in load carrying capacity.
Properly rigged, even a mid size SUV like a Acura MDX will do the job. The tradeoff with smaller vehicles and trucks is the lack of cargo carrying capacity. The upside is a very comfortable vehicle when not towing.
I towed our 27 with our Cayenne for many thousands of comfortable miles, but it is always on the edge of it cargo capacity with just the GW and I and not much more in the cab. We also tow the 27 with an '18 Denali HD Duramax. With it I can bring along the BBQ, lawn chairs, generator, etc., and I have no worries about staying within capacities. All these things stay home when towing with the Cayenne. I can just set the cruise at 65 and that is where it will stay, up and down the steepest grades. All I do is steer and enjoy the scenery.
Good luck with whatever you decide, you are about to embark on a great adventure!
Right on! Thanks Warden.
SteveNdebbie is offline   Reply With Quote
Old 04-27-2019, 11:11 AM   #29
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
San Antonio , Arkansas
I looked at the payload sticker of a Denali HD Duramax just the other day and was surprised that it was only 300 lbs more than my 1500 SLT w/ 6.2 L gas and Max Tow Package. Those items you listed ride in my Airstream until we reach our destination.
twbucksr is offline   Reply With Quote
Old 04-27-2019, 11:32 AM   #30
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Name:	wd hitch needed.jpg
Can anyone tell me where to find the payload sticker?
out of sight is offline   Reply With Quote
Old 04-27-2019, 12:00 PM   #31
2007 22' International CCD
Usually on the driverís door sill below the door latch. 🤪
Old 04-27-2019, 03:25 PM   #32
It’s the yellow sticker on the drivers door jam, in the case of that dump truck it should be 40000 lbs
Old 04-28-2019, 09:05 AM   #33
2014 22' FB Sport
Davie , FL
That's not much. I decided to upgrade to the Cat 797. The door sticker says not to exceed a payload of 800,000 lbs, but I'm not sure if that includes the weight of the driver.http://www.airforums.com/forums/atta...4&d=1556464219
Name:	my new tow vehicle.jpg
Old 04-28-2019, 09:11 AM   #34
2014 22' FB Sport
Davie , FL
Having a problem with the hitch, though.
Old 04-29-2019, 04:12 PM   #35
2017 25' Flying Cloud
Burleson , Texas
hahahaha
Traveling Doodah
Mappity map
rodo is offline   Reply With Quote
1969 Ford F-250 Camper Special Truck with a 1968 Avion C11 Truck Camper Wppcdlh4 Airstream Classifieds 0 08-24-2017 12:45 PM
My truck is better than your truck Alluminati Towing, Tow Vehicles & Hitches 48 12-15-2016 03:23 PM
