Old 02-16-2020, 07:24 PM   #1
2009 30' Classic
a city in west GA , Georgia
My new 2016 F350 diesel has corrosion on the post
What do you guys recommend for the post. ? To keep em clean?
Joyman is offline   Reply With Quote
Old 02-16-2020, 07:33 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
https://www.amazon.com/CRC-Battery-T...1906798&sr=8-4
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 02-16-2020, 08:15 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Super Lube grease on the posts and the hold down hardware.
CRH is offline   Reply With Quote
Old 02-18-2020, 04:27 PM   #4
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
Smell Sulfur? Be very careful...
Mix some Baking Soda in water and pour it onto the Battery Posts and cable ends. It will fizz. This is neutralizing the Sulfur Acid on the terminals.
Keep another batch in the event your battery is creating Oxygen and a spark will cause an explosion. You can then wash your face and any skin that may be on you.
Rinse well with fresh water until they are sparkling clean.
The WORST CASE:
I had one battery my 2016 F350 Diesel that has two batteries. One shorted internally and I could smell Sulfur from the battery acid. I thought it was where we had stopped that had a sulfur smell. When I figured out it was under the hood, the smell of sulfur was my battery.
I touched the side of the battery and it was warm to hot. This was not good at all. A battery can explode with a spark due to Oxygen being released from the battery and here we are in a gravel lot in a small town. I covered the battery with a couple of wet towels, disconnected the cables and wore sun glasses for eye protection. I was able to lift the battery out of the vehicle and sat it down on the gravel.
Then leaned it over to pour the Sulfuric Acid into the crushed limestone in this empty lot. It fizzed and was neutralized. Now harmless. Whew...
I am sorry if this is a typical Ray post... but this is something you DO NOT want to happen to you and not know what to do.
After the battery was drained, I looked into the battery (from above three feet or so) and two or three lead cells were fused into a grey mass. It had shorted. I was the first owner of this 2016 truck. This occurred last year while Boondocking towing our Airstream.
A local resident saw the commotion as some kind of exciting thing to check out and took myself and the battery into town to a Automotive Shop that was closing within an hour. I check the date on the equal sized battery that had more turning amps than the Ford Battery... got a deposit for mine, installed the battery, left the plastic handle that most people remove... ON.
If you have ever been around a battery that is vaporizing, like yours may be, it will EXPLODE if a spark occurs removing a cable connection. This caustic acid will eat through your clothing even if you wash any that have been contaminated. It can disfigure you if not rinsed and neutralized immediately. It will corrode metal and do general harm to everything from paint to metal.
If you SMELL Sulfur. Please be aware it looks harmless... but is potentially dangerous.
Please let us know what you discover. Be careful.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 02-18-2020, 04:48 PM   #5
Ray Eklund's Avatar
To clean the terminals ONLY. Use the Baking Soda mix. It will fizz. Keep pouring lightly, with someone rinsing with a hose, once the fizzing slows down. Repeat. Avoid getting any into the battery itself or on yourself. If you use gloves, you may end up wasting them. Use the thin rubber gloves that are disposable.
Those of us who worked on cars on the street or alleys... been there, done it.
Dry off. Once dry, apply wheel bearing grease... is what I do in this case. Just lightly and it will keep corrosion off the surface. Also try to figure out WHY? Probably Sulfur Acid splashed out from a very rough road... or check for an upper cap leaking.
OK. This has been my cure. Others may have improved it over the years.
Human Bean
Should I use Corrosion X on brand new trailer to prevent corrosion ILOVESALLY General Repair Forum 39 03-24-2024 09:37 AM
About To Pull The Trigger On A 2002 Ford F350 XL 7.3 Turbo Diesel Yhottys Tow Vehicles 22 04-28-2010 10:10 AM
used F350 '02 diesel for '08 25' Safari FB? Roamin Cat Tow Vehicles 6 03-14-2008 07:55 PM
MPG of F350 Diesel Dually??? joossens Tow Vehicles 13 06-13-2004 12:55 PM
