03-03-2020, 02:05 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
Mercedes 2020 GLE 350 brake controller install
I'm selling my aging Touareg and have opted for a 2020 GLE 350 with a tow package. The dealer seems absolutely clueless about how to (or where to) install a brake controller because of knee air bags. Has anyone done this? Any suggestions?
03-03-2020, 02:51 PM
I've heard good things about the Tekonsha wireless brake controller. The main unit mounts on the trailer and you have a handheld unit in the drivers position.
03-03-2020, 03:46 PM
Mountain View
I confirm. I am using the wireless Tekonsha and it works without any problem.
03-03-2020, 03:52 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
03-04-2020, 09:32 AM
SilverFire
2007 19' Bambi
EUGENE
, OR
Mercedes Brake Controller Harness (none)
Mercedes are not wired for plug and play brake controllers under the dash like domestic trucks with factory brake controller harnesses. You have to wire brake controller adaptor plugs into the Mercedes wiring. So Mercedes tow package is a little deceptive. There is no brake controller harness, you have to create it. The other posters are correct, Bluetooth a better option. Do not pull a trailer in a Mercedes without a brake controller, otherwise, you have no trailer brakes.
The new blue tooth controllers are a better option and eliminate the need to pull your seat in a Sprinter to access the vehicle wiring. I have a wired controller in my sprinter van (pain in the rear to install) and a Bluetooth unit in my GLE 350 I prefer. The BlueTooth units let you move from vehicle to vehicle too. The seat belt electronics are easily sent out of whack installing the wired units too!
Save yourself a lot of headaches and expense and get a Bluetooth unit!
03-04-2020, 09:39 AM
SilverFire
2007 19' Bambi
EUGENE
, OR
Curt Echo Bluetooth brake controller for GLE
03-04-2020, 10:33 AM
2016 23' Flying Cloud
Portland
, Oregon
I'll second the Tekonsha wireless model. I used it on a '13 GL350 until I moved to a F150 this past fall.
The only issue was with the initial setup. Euro cars don't seem to send an initial setup signal well. Posts on the forum noted that you *may*need to use a US-made car for the initial connection between TV and the controller/receiver. I borrowed a friends truck and it worked easy. After the initial connection was made, the MB worked perfectly.
BTW, I have that wireless model that I don't need anymore. Since I already paired it, you may not need to. That could save some hassle. PM me if you're interested.
03-04-2020, 01:51 PM
2016 27' International
Sherwood Park
, Alberta
I also use the Tekonsha wireless model on my Cayenne and it works very well. It will certainly address your issue with knee airbags as it does not require mounting the control. Getting one that has already been paired is a bonus as it will work with your vehicle right out of the box. That said, pairing a new one with a domestic vehicle is easy too and them just move it over to your Mercedes.
03-04-2020, 01:56 PM
Sherwood Park
, Alberta
Originally Posted by SilverFire
Have you actually used one of these. I have not found anyone who has to determine how well they work.
03-04-2020, 04:44 PM
1964 26' Overlander
OlyPen
I took a look at that and am not loving using my cell phone for manual control.
03-04-2020, 09:57 PM
SilverFire
2007 19' Bambi
EUGENE
, OR
Curt Bluetooth controller
No problems to date. It holds the programmed settings, so no different than my wired unit in terms of function. The only real difference is you are programming it through your phone rather than on your hard-wired unit. Change is constant! Safe trailering and don't fly faster than your angels!
03-04-2020, 11:36 PM
Mountain View
I read about problems with pairing. And this one of the reasons why I kept it in the box for most than one year. However, I paired it without any issue with BMW X5.
03-05-2020, 07:41 AM
KW
, Ontario
Mine came wired for brake controller. I had MB fit it and later changed the controller to a different one (P3). Works great wired.
03-06-2020, 11:35 AM
2015 25' International
PARK CITY
, UT
We have a 2015 GL450 and had U-Haul install the trailer brake controller. I believe it was about $800 but has worked fine - can't recall the brand but can go look if interested.
03-07-2020, 05:43 AM
2015 19' International
Atlanta
, Georgia
I am also using the Curt as mentioned below with my BMW X5, you need to download the app onto your cell phone, as that becomes the controller. My initial setup was less than 5 minutes, it paired in seconds, been using for about one year with no problems.
03-07-2020, 07:30 AM
1967 26' Overlander
Bugtussle
, Oklahoma
I use the Prodigy RF with my Cayenne. I could not get it to pair at first. Had to put a piece of electrical tape over the pin in the 5 o'clock position where the trailer harness connects to the controller. Paired immediately after that. I then removed the tape and it's been working great ever since.
The Curt Echo may be a great solution but I chose the Prodigy because the 7 pin connection on my Cayenne is angled down toward the pavement. I did not think having my brake controller hanging down lower than my bumper was a good idea since I tow down some pretty rough dirt roads. I also like the fact that Prodigy has it's own controller and doesn't require a smart phone. It's a personal preference. I'm not knocking the Curt. Just stating the 2 main reasons I chose the Prodigy RF.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
03-08-2020, 07:13 AM
2012 25' FB Eddie Bauer
Southwestern Ontario
, Ontario Canada
Isn't the wiring for the brake controller in the same place in the driver's footwell, I thought I read that somewhere? My ML has driver knee airbags and the controller is mounted under the dash. I was concerned at first the realized the airbag deploys over top of it, so I didn't consider it a hazard IMO. I won't be picking up my GLS for another month but I will be evaluating that same location for my controller again. The very left side under the dash does not appear to have the airbag but the hood release is there and it is less convenient for emergency manual trailer braking. I am not as confident with RF over hard wire controllers but if I can't be sure of a safe mounting point for the hard wire P2 then I will go RF. Please post what you decide to do.
03-08-2020, 07:19 AM
, Ontario Canada
03-11-2020, 10:00 AM
1987 34' Excella
Asheboro
, North Carolina
Brake controller wiring
I have the Prodigy controller mounted under dash near the center console. The factory wiring is under the carpet and floor insulation near the base of the steering column for 2019 and previous. Assume same for 2020 if factory trailer package. I like the hard wiring if available.
03-12-2020, 07:30 AM
, Ontario Canada
Do you have a 2020 GLE?
