Old 04-23-2019, 12:35 PM   #81
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by Gallego View Post
It is not rattling, as a matter of fact i always use the tongue jack to verify that the coupler is holding the ball.
What I fell now is that on a fast start, like incorporating to the road with traffic and accelerating hard, the ball makes a "clong" noise and you fell a little hit back. The opposite happens in the event of a strong brake....
During the ride it fells normal, and if you are smooth operating as well...
For grins trailer unhitched but hitch installed in receiver. See if the stinger moves forward and back on the hitch pin.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Old 08-08-2020, 05:33 AM   #82
2020 22' Caravel
Boston , MA
Do you have advanced towing assist on your RR? If so, where do you place your tracking sticker given the constraints of the propane tank enclosure and electric hitch?
Miezi 2020 is offline   Reply With Quote
Old 08-09-2020, 09:13 AM   #83
Thomas
2018 23' International
Huntington Beach , California
We tow our 2018 23CB International Signature with our 2007 Range Rover HSE. We use a Centerline WD hitch and have had no sway or other issues as the RR is pre-aluminum heavy. Maneuverability is great due to the relatively short wheel base.
Thomashbp is offline   Reply With Quote
Old 09-29-2020, 06:09 PM   #84
OliveRivets
OliveRivets's Avatar
1968 26' Overlander
1976 31' Sovereign
Wake Forest , North Carolina
Images: 8
Ready for anything!
Adventure is out there!
OliveRivets is offline   Reply With Quote
Old 10-04-2020, 11:36 PM   #85
Member
DigitalNomad's Avatar
2017 23' International
Cerritos , California
I have the same questions Miezi 2020; perhaps we need to just remove the propane tank cover?
DigitalNomad is offline   Reply With Quote
Old 10-17-2020, 11:00 PM   #86
2015 23' FB Flying Cloud
BAINBRIDGE , Washington
2015 SC 23FB and 2016 LR4
Our 2015 Silver Cloud 23FB and 2016 LR4
ID:	381122   Click image for larger version
Fjb1098 is offline   Reply With Quote
Old 10-20-2020, 03:52 PM   #87
OliveRivets
1968 26' Overlander
1976 31' Sovereign
Images: 8
Beautiful! What a sight!
Old 12-24-2020, 02:49 PM   #88
OliveRivets
1968 26' Overlander
1976 31' Sovereign
Images: 8
Merry Christmas!
Old 12-24-2020, 02:56 PM   #89
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Hi....👍
Nuff said....
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 01-05-2021, 04:40 PM   #90
OliveRivets
1968 26' Overlander
1976 31' Sovereign
Images: 8
Any 2020 defenders pulling Airstreams?
Old 01-06-2021, 12:10 PM   #91
Member
Advanced Towing Assist
...I tried again to get that towing target to work with my 2017 Discovery TD6 but to no avail. I even completely removed both LPG tanks but I can't seem to convince the computer to accept the Towing Target. Any suggestions?
ID:	386352   Click image for larger version
Old 01-06-2021, 12:15 PM   #92
Try KISS. 😂
Tahawus
RLC
Old 01-07-2021, 11:26 PM   #93
Member
Rivet SOLVED: 2017 Int'l 23FB + 2017 Land Rover Discovery w/ Tow Assist
...so the root cause was the Discovery not detecting the trailer electrical connection because the trailer's LED lighting system draws less than 1.75 Amps of current. I found this discussion to be helpful.
To increase the current draw I installed a Sylvania LED Equalizer Kit (a pair of 50 Watt 6 Ohm resistors) inside the trailer's electrical bay (under the queen bed). One resistor is connected between each of the turn/stop signal wires (red and brown) coming from the 7-pin connector and the ground buss. Luckily, there is a junction box with screw terminals making the connections quick and simple once you have the Resistors mounted to the cooling fins. I used thermal compound under each resistor and added #10 ring terminals to the ends of each wire.
These resistors get incredibly hot during use so they are attached to some aluminum heat sinks that I scavenged from an old power supply circuit board; they warrant an even larger heat sink which I'll need to upgrade. I'll probably install a cooling fan, as well, connected to the Running Lights (Green) wire.
I had to remove the LPG Tank Shroud but I find the green target area very satisfying.
ID:	386458   Click image for larger version
ID:	386460   Click image for larger version
Old 01-09-2021, 01:49 AM   #94
Member
Rivet LED Equalizer Kit version 2.0
A thermal analysis of the LED Equalizer Kit installation suggested the heat sinks are woefully inadequate to dissipate 54 Watts (2× 27 Watts) of heat so I upgraded to a much larger heat sink and added a cooling fan.
The fan is powered via the running lights circuit from the trailer 7-way connector. I also didn't care for the spaghetti soup wiring job inside the electrical bay so I relocated the 7-way junction box, along with version 2.0 of the LED Equalizer Kit, to the panel adjacent to the external storage compartment. I cleaned up some of the other wiring and tightened down the inverter and relay (both were pretty loose).
Before and after pictures of the electrical bay are shown along with a close up of the junction box and LED Equalizer.
ID:	386532   Click image for larger version
ID:	386534   Click image for larger version
Old 01-09-2021, 06:01 AM   #95
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
My Land Rover days preceded my Airstream days. Here's my friend and I getting ready to drive to Alaska from NY State in my first Land Rover. This was 50 fears ago- 1971. The LR is a '67 Series IIA.
2019 Ford Expedition Platinum
Old 01-09-2021, 06:24 AM   #96
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
I’ve had a couple of 1st generation Discoveries, we loved them, but they’ve been passed along. But, I still have a couple of Series... both are 88”, the yellow ‘60 is a SII and the green ‘72 is a SIII...
ID:	386540   Click image for larger version
-Leslie
LNBright is offline   Reply With Quote
Old 01-09-2021, 06:45 AM   #97
Wayne&Sam's Avatar
Images: 21
Nice.
Old 01-10-2021, 03:01 PM   #98
OliveRivets
1968 26' Overlander
1976 31' Sovereign
Images: 8
Love it! So great to see these pictures!
Old 01-21-2021, 01:38 PM   #99
Portland , Oregon
This is great work, really well done. I had to add the same resistors to my 2018 16' Bambi to get my 2012 Range Rover Sport to recognize that the trailer is connected. I had the same concerns about heat and ended up mounting the resistors on a piece of angle aluminum bolted to the frame on the outside of the the trailer. It's worked out well and heat dissipation is not a problem there.
Zachary M. is offline   Reply With Quote
Old 03-31-2021, 07:26 PM   #100
OliveRivets
1968 26' Overlander
1976 31' Sovereign
Images: 8
Land Rover LR3 towing story reventlow Tow Vehicles 86 06-09-2015 01:28 AM
2006 airstream 19' safari bambi se, 75th anv ed, immac s1967 series ii land rover "1 eBay Watch Airstreams on eBay 0 06-14-2010 09:20 PM
Towing with a Land Rover dan_lemire Tow Vehicles 6 02-10-2006 12:20 PM
Trailer size for a 2003 Land Rover Discovery runyandm Tow Vehicles 5 10-30-2003 09:09 PM
Land Rover Discovery to tow Bambi '62 Rosemary Tow Vehicles 10 10-20-2003 08:33 PM
