Old 10-20-2017, 06:24 PM   #41
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
If I remember right I think the 2013 25’ International weighed 66/6700 pounds wet and ready.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
Bigventure is offline   Reply With Quote
Old 10-20-2017, 07:10 PM   #42
2018 27' International
Southeastern MI , Michigan
Originally Posted by dbj216 View Post
Thanks bigventrue: Jeep says 30' trailer is the max. Your experience with a late model 25' builds confidence. My 1975 Overlander is 27' and 6200 lbs GVWR. I'll weigh it ready for travel, but I think I will be several hundred pounds less than that, unless the wife starts picking up big rocks to take home.
Maybe 27 feet is within reason with your experience with your 25' Airstream.
I was chuckling at the 1975 Airstream owner's manual showing all those pictures of big Oldsmobile (or similar) sedans towing 31' Sovereigns. 1975 was not a banner year for American automobiles. I personally wouldn't consider towing with a 1975 sedan. Gee, the distance from the rear axle to the bumper is what, 10 feet? Leaf spring suspension, 200 hp engines, 3 speed transmission, drum brakes, loose steering, and old fashioned break controllers. Wow. Makes the Grand Cherokee look very good indeed.
David
Maybe so, but we towed plenty with those big sedans and got along just fine. Run that Grand Cherokee into the back of my old Suburban at 5 mph and you will have a $3500 repair bill, and I might feel a slight nudge.
Countryboy59 is offline   Reply With Quote
Old 10-20-2017, 07:29 PM   #43
JYD
2016 30' Classic
Hideaway , Texas
I tow my 2016 Classic 30 with an Infinity QX56 equipped with Pro Pride hitch. Just go back from 1300 mile trip. Tows trailer great averaged 11.6 mpg. My greatest problem is keeping under 65. Cannot use cruise.
JYD is offline   Reply With Quote
Old 10-23-2017, 05:07 AM   #44
Libtech's Avatar
1968 26' Overlander
Driftwood , Texas
FYI to everyone saying the WK2 doesn't have a tow mode in the transmission, it does not. However, it does have a manual paddle shift mode. So you can pick what gear your in and not worry about shifting in and out of the ODs. 7th and 8th gears are both overdrives. Also as to running hot. while towing with mine EGTs never got above 1200, engine and trans stay between 200-210, and intake temps tend to be 10 degrees above ambient temps.
Libtech is offline   Reply With Quote
Old 10-23-2017, 06:09 PM   #45
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Very good information Libtech: It sounds like your experience is very favorable towing with the Grand Cherokee diesel. There is nothing alarming about the data you shared. There are similar numbers to my Super Duty diesel.
Manual control of the transmission can be a good thing. I have that feature in the Super Duty, but don't use it much as the "tow / haul" tune seems to work quite well for me. Shifting an automatic manually can get embarrassing at times. You don't want to hit the rev limiter, and you don't want to lug down going up steep hills. I manually shift our 06 Acura MDX to gain some engine braking down hills, and a bit more throttle response going up hills. Second gear selected manually holds second, meaning it leaves from a stop in second. Not good if you forget and try to accelerate up a steep hill. Real sluggish. But okay if starting out on an ice slick road. The MDX is tuned for economy only. It hardly ever gets over 2500 rpm in automatic mode.
I expect the Grand Cherokee to do better.
David
Old 10-25-2017, 07:01 AM   #46
Libtech's Avatar
1968 26' Overlander
Driftwood , Texas
I have a '16 superduty for a work truck. constantly haul a trailer that's over 20k. the exhaust brake and tow mode in that truck is amazing.
Old 10-25-2017, 08:18 AM   #47
Coopersburg , Pennsylvania
It actually depends on the year. My 2011 V8 has TOW/HAUL mode but no paddle shifters. WK2s have actually had a variety of transmissions over the years - see http://www.wk2jeeps.com/wk2_transm.htm for more details.
BillF95 is offline   Reply With Quote
Old 10-25-2017, 10:43 AM   #48
Libtech's Avatar
1968 26' Overlander
Driftwood , Texas
my bad. i thought all the wk2s used the 8spd.
Jeep Grand Cherokee Tow Vehicle Carmel-Jon Towing, Tow Vehicles & Hitches 95 08-30-2018 07:21 AM
Jeep Grand Cherokee Tow Capability gvsummer Tow Vehicles 16 09-11-2015 09:58 PM
2011 Jeep Grand Cherokee Overland w/Tow Pkg, Extended Warranty, Loaded KristinS Airstream Classifieds 0 09-06-2014 04:38 PM
Tow Rating for 2000 Jeep Grand Cherokee Laredo? haulinhp Tow Vehicles 16 09-16-2010 09:28 PM
