Old 02-05-2019, 06:01 PM   #1
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I want to tow four 34' Limited's at once
OMG! Is GM serious?
Why not just buy a locomotive.....
https://www.autoblog.com/2019/02/05/...-35500-pounds/
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 02-05-2019, 06:52 PM   #2
Dazed and Confused
Isuzusweet's Avatar
It's a cloudy day with a bit of drizzle as you climb to the summit of Slumgullion Pass in Colorado. It has been a long hard pull in your Cummins powered RAM 2500 pulling your 30' Classic up to the top, and you don't want to admit it to the DW, but you're a bit trepedious at the 9.4% grade that awaits you on the other side of the summit.
Just before the summit, you see in your side mirror what you have only read about, but never seen in person. It's a Flayco Saudi Supreme Special fifth wheel coming up behind you; at 50' long, it features, five 10,000 lb axles, a Polaris RZR XP Turbo S inside, stone fireplace's, stone countertops, ceramic tile on heated floors, full size Stainless steel Sub-Zero fridge, (and freezer); every convenience you could imagine, and more.
You also know its GVWR is 35,499 lbs......cause someone got to build a trailer that this GM can pull.. You also know that the GM heavy duty straining to pull this monster up the grade has 20" rims, just like you do, and rotors and callipers big enough to fit inside those 20" rims.
Question......do you pull over and let him go first? Or are you man enough to show him how its done?.....down that 9.4% grade.........cause they tell you how the frame has been beefed up, and the axles are stronger......but nothing about the brakes.
Cheers
Sidekick Tony
Old 02-05-2019, 07:02 PM   #3
2017 28' International
Jim Falls , Wisconsin
Move over.
Daquenzer is offline   Reply With Quote
Old 02-05-2019, 07:15 PM   #4
Tuco's Avatar
1988 32' Excella
Ojai , California
Only a Toyota Tundra can get that much weight up and down a grade like that! Both trucks should just pull over and let the REAL truck get the work done!
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 265k+ (The Beast)
Tuco is offline   Reply With Quote
Old 02-05-2019, 07:36 PM   #5
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Glad I got my Silverado while they were still good looking...
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 02-05-2019, 10:16 PM   #6
PKI
PKI's Avatar
Walnut Creek , California
There is a picture of the prototype train in the Airstream archeives. But a car/sedan was doing the towing, so GM was late to the party. Pat
Old 02-05-2019, 11:01 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, and also I saw a video of a new Ford Ranger towing something like 15 travel trailers.
Name:	Ranger towiny 15 trailers.png
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 02-06-2019, 05:17 PM   #8
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
And the last trailer in that string of caravans in an Airstream!
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-06-2019, 06:51 PM   #9
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
"Chevy says every component between the transmission and wheels have been upgraded to handle the increased towing load."
When I looked at mine, the brakes were in between the transmission and the wheels...
Best Tow Vehicle-Most likely Once Again srobison Tow Vehicles 93 11-20-2011 03:55 PM
Great Tow Across Country - Once Again... JFScheck On The Road... 7 10-13-2010 10:19 AM
I want new Fantastic Fans but I dont want to give up the lights. memgrove2000 Roof Vents, Skylights & Fans 4 03-10-2009 09:21 AM
Four Wheel Drive or Two Wheel Tow Vehicle? 1cericks1 Tow Vehicles 24 02-01-2009 02:22 PM
