Old 02-06-2009, 01:10 PM   #21
Augie R.
1960 22' Safari
carlsbad , California
Vin#220243D ok Now what?
augier is offline   Reply With Quote
Old 02-06-2009, 01:12 PM   #22
Augie R.
1960 22' Safari
thanks by the way
Old 02-06-2009, 01:59 PM   #23
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
220243D = Ohio built 22 foot Safari with Double bed floor plan. It may have been built late 59 or early 60. The dry weight would be around 3000 pounds.
Richard
azflycaster is online now   Reply With Quote
Old 02-06-2009, 02:24 PM   #24
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
If the Jeep has the tow package you will be just fine.
Take that money saved and purchase a good modern hitch (maybe used Hensley off of flea bay) and some McKesh tow mirrors. Bring the Jeep maintentance up to date - make sure the cooling system is flushed, thermostat is ok and change all fluids - differentials, transmission, transfercase - think about using synthetic fluids.
crispyboy is offline   Reply With Quote
Old 02-06-2009, 02:48 PM   #25
Invest in a transmission cooler as well. Many vehicles that come with a "tow package" will have the transmission cooler included, but if not, you can have a shop put one in for something like $100. It's great insurance now that could potentially save you thousands on a transmission rebuild later.
Old 02-06-2009, 03:38 PM   #26
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
It's a Ohio 1960 22 Safari double bed layout. The dry weight will be around 3200 to 3400lbs the tongue weight will be around 325 to 400lbs. When you pack up the trailer to move it home be careful of the weight distrbuton.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-06-2009, 04:19 PM   #27
Augie R.
1960 22' Safari
when I head home all there will be inside is the floor ...I'm building everyting else when I get home..
Well I got the truck it does have a tranny cooler & it has a factory tow package
I have my electric brake already all i have to do is install it.
I ws thinking of using my original hitch that I found in the trailer it has a weight dist.
but the way its welded on the trailer is kinda sketch here are some pics what do you guys think...
The gaps at the brackets welded on to the frame seem weird....
ID:	75140   Click image for larger version
ID:	75142   Click image for larger version
Old 02-06-2009, 04:27 PM   #28
2002 25' Safari
Dewey , Arizona
Images: 62
It looks like a Reese WD setup. The ball is for a friction sway control. Not the best you can buy, but it works and is what I use with my trailer. You should have some pretty light bars to go with it and the trunnion head to go into the receiver.
Here is a guide to get it setup correctly.
Richard
Old 02-06-2009, 04:59 PM   #29
Augie R.
1960 22' Safari
well the head was welded onto a bar .looking at what you just sent me i see this ting has been rigged. how does that ball welded on the side do anything ?
here is a few pics of what goes on the truck end
ID:	75145   Click image for larger version
ID:	75147   Click image for larger version
Old 02-06-2009, 05:52 PM   #30
1963 24' Tradewind
San Diego , California
Augier You are movin right along. The ball on the tongue, the one welded on is for a friction sway bar, it needs a ball also attached to the hitch next to the main tow ball. That way the sway bar will be connected to the tongue frame and the hitch. I don't see a place on the above pics to attach the 2nd small ball.
Also if you take your time and the fact that the AS is empty your 2nd choice for a TV should work. Good luck
Sixty3TW4US is offline   Reply With Quote
Found juel Fun & Games 2 06-08-2008 09:40 PM
Look what I found! Minnie's Mate Off Topic Forum 4 05-25-2007 05:24 PM
Found it bina Member Introductions 9 02-12-2007 02:22 PM
Found One- 1973 Ambassador! Rivetedude 1970 -1973 Ambassador 27 05-11-2005 04:11 PM
Need help? found A/S Airstreamlover Trailer Values 3 11-02-2003 07:15 AM
