View Poll Results: How concerned are you about payload?
I watch it very closely and never go over
34 |
31.19% |
I think about it and try to stay below
46 |
42.20% |
Never worry about it
29 |
26.61% |
03-27-2023, 05:00 PM
#201
2019 22' Sport
High River
, Alberta
Originally Posted by ROBERT CROSS
I'm really not concerned about how "Cloudsplitter" handles on a Gymkhana course at speed, as long as it doesn't sway on the interstate in heavy winds, rain & passing 18 wheelers. KISS.
"Worry... a brain exercise done when it really wants to sleep" RLC
Yes, that’s how most of us define stability. There’s more to the debate, but I don’t disagree with you.
03-27-2023, 05:01 PM
#202
2020 30' Classic
Frederick
, Maryland
Originally Posted by propchef
We have a BMW X5 with the tow package.
I’ve found several conflicting numbers for payload and tow weights, all for my specific vehicle. Outside of North America, those numbers are consistent across the entire G05 platform. N.A. BMWs come standard with run-flats which aren’t great for towing. Replacing them right away and getting the right wheels makes a huge difference.
I doubt that the numbers are "conflicting" so much as they are different for different models and set ups. There are numerous listings for towing capacity and payload for F150s, for instance. That isn't a "conflict". Go by the sticker on your door, not the internet.
03-27-2023, 05:03 PM
#203
2019 22' Sport
High River
, Alberta
How concerned are you about your trucks payload
Originally Posted by xpcdoojk
I don’t have a dog in this fight, but. What about fuel levels? IE a vehicle weighed with an almost empty gas tank is clearly going to weigh less than it will with a full tank. could that account for the difference between the numbers IE GVWR and Payload?
Curb weight includes full fuel and fluids, spare tire, etc. No passengers or cargo.
In my vehicles, the fuel only weighs about 125 lbs. Not enough to account for the difference.
03-27-2023, 05:07 PM
#204
2019 22' Sport
High River
, Alberta
That’s exactly what I do. Front and rear GAWRs, GVWR, and actual curb weight. My tow vehicle weighs 3800 lbs, but according to the internet it’s only 3527!
03-27-2023, 05:15 PM
#205
I think you missed the part where I said differences for my specific vehicle, not different models or specs.
If they aren’t the same payload and hitch numbers for the same vehicle I call that a conflict.
03-27-2023, 07:38 PM
#206
1994 28' Excella
Manhattan
, Kansas
Originally Posted by hikingcamera
Hmmm... can't exceed the curb weight... that seems problematic.
Tongue weight specs seem often overlooked. I've seen several confident 3/4 ton truck owners who claimed they were in spec even though the unloaded tongue weight of their trailer was exceeding the manufacturer's specs without a WDH.
Most 1500 I looked at had a tongue max weight of around 950 pounds and there was no mention of it with or without WD this sticker is on the door jam and not on the hitch. I downloaded the manual for 2022 and there wasn't any mention of without our with WD just don't exceed the limits.
Dennis & Ellie
1994 Excella Classic Unlimited 28 Foot
2017 RAM 2500 Gas 3170 Payload
and
2017 Newmar Ventana Class A DP 7224 Payload
03-27-2023, 08:10 PM
#207
2022 23' Flying Cloud
Seattle
Yeah today’s trucks are far more capable according to their manufacturers. I am not as familiar with GMC, but go back to 2016, and on paper an F-350 can’t tow a 25-foot Airstream without a WDH. I’m not professing to know whether that is actually true in practice, but if you are going by the letter of the specs, it’s there in their tow guide.
(Ref: 2016 Ford Towing Guide, page 37, https://www.fleet.ford.com/towing-guides/)
03-27-2023, 08:14 PM
#208
Oswego
My 2015 chevy 1500 says 1200# max tw on the receiver...but it is a maxtow. Payload = 2034.
Ltz double cab with a lot of whistles, but without the bells that weigh a lot.
-Rich-
03-27-2023, 08:24 PM
#209
1994 28' Excella
Manhattan
, Kansas
That was true in 2016 but in 2022 they have a rating called the Max tongue weight listed on the door jam that doesn't mention WD at all. In 2022 their ratings not only for Max Tongue Weight but Max Gooseneck Rating (5th wheel) which there wasn't in 2016.
Dennis & Ellie
and
03-27-2023, 08:32 PM
#210
1994 28' Excella
Manhattan
, Kansas
Yes in 2015 It probably said that but now if you buy a 2022 or newer it is going to have a door tag (not on the hitch) that states Max Tongue Weight and doesn't anywhere on the tag or in the manual anything about with or without WD. Here is a door tag off of a 2022 GM 1500. This tag says 1911 payload but 950 Max Tongue Weight. See the image below...
Dennis & Ellie
and
03-27-2023, 09:03 PM
#211
Oswego
To be honest, and I have no definitive proof, just years as a rep...I don't think the max matters to the receiver. The dead weight torques one way....wd applies the torque the other way. I think the ratings were more applicable to how the forces effect the rear axle load.
-Rich-
03-27-2023, 09:12 PM
#212
2013 25' FB Flying Cloud
Longmont
Look closely at that GM sticker and you will see that it does NOT give the max tongue weight rating for the vehicle. Instead, it gives the max tongue weight for which the vehicle passed the SAE J2807 tests. The SAE tests are always run with a 10% tongue weight.
Suppose a vehicle has a 1000 pound receiver. But when they do the SAE "Davis Dam" hill climb test, it overheats at any trailer weight over 9000 pounds. Then the J2807 test result is 9000 pounds trailer weight, and 900 pounds tongue weight. GM will put those numbers on the door sticker, and there will be no way for us to know about the 1000 pound receiver.
In the case of the 2023 Chevy 1500 with 6.2L engine and Max trailering option, the GCWR goes up by 1300 pounds when you go from 18 inch wheels to 20 inch wheels (probably because it does better on the J2807 stability test). That increases the tow rating and tongue weight rating. Does anybody think changing wheel size improves receiver strength?
GM is providing incomplete information.
03-27-2023, 09:23 PM
#213
2019 28' Flying Cloud
Broward
The owner's manual does say that you need a WD hitch for trailers over 7000 lbs (6000 lbs for a diesel).
03-27-2023, 10:18 PM
#214
1994 28' Excella
Manhattan
, Kansas
Here is what it says in the manual of 2022 GM 1500.
Trailer Weight Ratings
When towing a trailer, the combined weight of the vehicle, vehicle contents, trailer, and trailer contents must be below all of the maximum weight ratings for the vehicle, including:
. Gross Combined Weight Rating (GCWR)
. Gross Vehicle Weight Rating (GVWR)
. Maximum Trailer Weight Rating
. Gross Axle Weight Rating-Rear (GAWR-RR)
. Maximum Trailer Tongue Weight Rating
The Maximum Trailer Tongue Weight Rating for a conventional trailer hitch or a fifth wheel/gooseneck hitch is shown on the Trailering Information Label.
https://www.gmc.com/bypass/pcf/gma-c...2022MAY_3P.pdf
Dennis & Ellie
and
03-27-2023, 10:56 PM
#215
Broward
It's on page 323.
03-28-2023, 07:06 AM
#216
2023 28' Pottery Barn
2019 23' International
Tomball
Here is the 2023 guide. W/D not required for Superduty. It is for the F150.
https://www.fleet.ford.com/content/d...uide_Nov22.pdf
03-28-2023, 07:17 AM
#217
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Curb weight + payload = max vehicle weight. Seems like they are doing a lot of very basic math for you and putting it on the sticker.
03-28-2023, 07:37 AM
#218
Seattle
Hi
But the sticker says you can’t exceeed any of those numbers. If you can’t exceed curb weight, you can’t add anything to your truck.
Yep, as I said, modern trucks are quite impressive.
03-28-2023, 10:36 AM
#219
2021 27' International
Camas
Load it, weigh it
Originally Posted by Castaway
I have spent the last month looking at ACTUAL PAYLOADS for a Ford F150 Lariat, the largest that I have found is around 1650 lbs.
I know that getting a 250 would solve my problem but we only tow 2 times a year and the truck is our daily driver.
Load it, weigh it with a properly setup WDH, no more worries.
when you live in the world of theory you will never know.
2021 International 27 FBT - 2019 F150 Harley Davidson
2017 FC 23 FB - 2002 Range Rover
03-28-2023, 11:56 AM
#220
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
"Required" and "recommended" are two different words, right? If a WDH with SC can help balance your load on your TV, to help improve weight distribution and handling, why wouldn't you want to use one? Arguments about "I have a 1T, or a dually" therefore I don't need a WDH, would seem to have merit with some model AS's for sure. It's all in what you feel you want to use to help control your rig when towing; or not use....your life your choice. I certainly would consider the value of any equipment that can improve my experience.
