Old 12-25-2020, 04:46 PM   #21
2016 23' International
Santa Cruz , California
Thanks for all your input.
Merry Christmas to all of you.
Tim
Twinfins is offline   Reply With Quote
Old 12-27-2020, 06:57 PM   #22
2020 27' Globetrotter
STAMFORD , Connecticut
Zero regrets.
I did the lift and posted about it here:
https://www.airforums.com/forums/f43...ml#post2443593
Justinfinity is offline   Reply With Quote
Old 12-28-2020, 05:20 PM   #23
susans69's Avatar
1976 Argosy 26
Lake Wales , Florida
If you go over any bumps at an angle the wheels keep it from bottoming out.
susans69 is offline   Reply With Quote
Old 12-28-2020, 08:51 PM   #24
2016 30' International
redondo beach , California
Originally Posted by Gene View Post
If you lift the trailer, it will tow differently. More wind resistance, more fuel, maybe more chance for sway. It seems better to change the driveway if possible. Bigger tires will add some height and it may be just enough. If the spare tire carrier is a problem, put the tire in the truck bed and remove the tire carrier.
Wrong on almost every point.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 01-05-2021, 02:17 PM   #25
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Interestingly, some AS models came from the factory already lifted ... (although only slightly)
that was one of the considerations for our purchases.
Lifting an Airstream? Ground clearance? cmmorsey Jacks, Stabilizers, Lifting and Leveling 5 06-17-2014 01:49 PM
19' Bambi ground clearance/"lifting" Glenn Hansen General Repair Forum 13 09-16-2007 07:11 AM
What should the ground clearance be? 63air Towing, Tow Vehicles & Hitches 4 07-19-2006 01:01 PM
ground clearance/battery charge Kintscher Our Community 14 06-01-2005 03:36 PM
how much ground clearance? Chuck Plumbing - Systems & Fixtures 1 05-26-2004 10:10 AM
