Old 08-30-2020, 06:52 PM   #1
Windsor Locks , Connecticut
GMC Canyon 4x4 SB tow vehicle
I am considering the purchase of a 19 2016 Flying Cloud Bambi weighing approximately 3600 lbs, our first travel trailer.
My 2017 Canyon is rated for 7000 lbs with the 6 cylinder, 8 speed transmission.
The specs tell me I can tow it however my son and I have discussed the benefits of having a bit heavier truck such as a GMC 1500 or F 150 Ford or Ram 1500 eco diesel. Any of the larger trucks would reduce the strain of those uphill treks. I m asking for those of you with first hand experience.
I have towed boats up to 19 which is a bit different.
All opinions and recommendations are welcome!
Thank you,
Steve
SteveS52 is offline   Reply With Quote
Old 11-07-2020, 03:45 PM   #2
2017 20' Flying Cloud
Williamson County , Texas
It is a great combination, very stable, recommend weight distribution hitch. Our Canyon is an excellent and very capable, TV for our 20' FC. Watch your truck GW, we hit the max of 6,000 lbs with generator, camping gear, and tongue weight although your lighter tongue weight will help in that regard. Ready to travel we are at a total 11,000 lbs. I did install a supercharger strictly for high altitude in Colorado and that was a great mod. I have owned several Silverados and still have a K2500 for the heavy hauling, but the midsize Colorado and Canyon are much better daily drivers in every way unless you have "large" backseat passengers.
2018 GMC Canyon V6 Mallet Supercharger
SYC2Vette is offline   Reply With Quote
Old 11-07-2020, 04:02 PM   #3
2018 25' International
Slidell , Louisiana
^ I agree. Be aware your camping weights will be near 5,000 and a 700-750 lb tongue, both of which are Okay for the Canyon but close to the point you can start having stability issue in rare cases. The WD and sway control hitch will help with safety margin. The exact kind of hitch you get will depend on your driving style and tolerance for set up difficulties. Be aware some hitches are better for your situation than others. Add 5-7 psi more air to the rear tires than the loaded guidance as long as you stay below max listed sidewall pressure and take 2 psi out of the front. Bias the gear weight in the Canyon forward. Consider the larger vehicles if you want to haul more gear.
Old 11-07-2020, 04:33 PM   #4
Wrangler's Avatar
2019 19' Flying Cloud
Renville , Minnesota
Don't have a Canyon, but the tow capacity of my Nissan is around 6500 lbs. whenever the tongue weight Exceeds 600 Lbs, Nissan requires a load distribution hitch. I have an equalizer hitch, and in 15000 miles of towing, I have never had a stability issue. By the way my Nissan weighs about 4,000 lb empty.
I currently camp in a 19 Flying Cloud towed by a Nissan Frontier.
Wrangler is offline   Reply With Quote
Old 02-07-2021, 08:36 AM   #5
The Joymobile
2011 22' Sport
MERIDEN , CT
Nissan Frontier and a 22' Sport
My 22' Sport weighs about the same as your stated weight of the 19' flying cloud. As with Wrangler's experience, my frontier tows very well with a weight distribution hitch. I have not forded any mountains, but does handle 10%+ grades while maintaining modest highway speeds.
While I am generally satisfied for now, when I buy a new TV, I'm going up in truck.
JeffofCT is offline   Reply With Quote
Old 02-07-2021, 10:01 AM   #6
2016 23' International
Long Beach , California
We have a 2016 Duramax Colorado and it has been fantastic with our 23
Just passed 110,000 miles and going strong.
Happy campers
ID:	388262   Click image for larger version
Seanlb is offline   Reply With Quote
Old 02-09-2021, 04:37 PM   #7
Originally Posted by Seanlb View Post
We have a 2016 Duramax Colorado and it has been fantastic with our 23’
Happy campers
That is fantastic. I think you are at the upper limit as what most of us Colorado/Canyon owners would consider, but glad to hear it is working well. Out of curiosity what is your GCW and GVW including tongue weight? I am at 11,000 lbs out of 12,000 GCWR available ready to travel, and very close to my 6,000 lb vehicle GVWR limit.
Although our 20' tongue weight seems heavy at 680 lbs measured, I have noticed that with all liquid tanks full I do notice just a very slight "sway", (almost imperceptible, but there) so I think the relatively heavy tongue weight is a good thing.
Old 02-09-2021, 08:58 PM   #8
Our trailer is just over 5600lbs wet and loaded.
Tongue weight is about 780lbs with propane.
Truck is rated to tow up to a 7600lb trailer with 1000lb tongue weight.
We also added fox shocks and airbags for a level ride.
Have never experienced any sway or body roll at high speeds.
We don’t really load much into the bed of the truck, usually just a few chairs and our travel luggage.
Couldn’t be happier with this little truck (perhaps a bit more HP, but it is an oil burner so the torque compensates).
Mesquite - Palo Duro Canyon State Park Campground, Canyon, Texa pfcardwell On The Road... 21 04-11-2018 07:04 PM
Ford F250/F350 4x4 versus Toyota Tundra 4x4 Ray Eklund Tow Vehicles 96 01-22-2018 11:54 PM
Newbie debating between f150 Laramie 4x4 and Chevrolet ltz 4x4 cyclistream Towing, Tow Vehicles & Hitches 24 02-05-2017 09:52 AM
Stops between Grand Canyon and Carlsbad Canyon mpsgolf On The Road... 0 08-15-2016 09:24 PM
Chevy Colorado/GMC Canyon (Crew Cab only) Apache_Camp Tow Vehicles 8 02-01-2010 08:23 AM
