Old 05-30-2017, 04:55 AM   #1
Chalet
desautels54's Avatar
2017 27' International
Blainville , Quebec
Gmc 3500 dually
We just order international 27FB and we have a GMC duramax 3500 dually 2013,,,, on the hitch...tongue weight 2,000 and tow 23,000 do we will need to add weight distribution bar on it ???
Dezo
desautels54 is offline   Reply With Quote
Old 05-30-2017, 05:34 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I tow a 25FB with a 2011 Silverado 3500 Duramax, crew cab, long bed SRW. I use a weight distribution/sway control hitch system. Some may tell you that you don't need it. I prefer the safety factor.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 06-09-2017, 02:47 PM   #3
Chalet
Blainville , Quebec
Thank you for your advise ....
Merci beaucoup ...
Dezo
Old 06-09-2017, 03:04 PM   #4
2019 30' International
Pennsylvania , Pennsylvania
Wow, I'd like to hear what your dealer recommended.
Personally I'm not going to give a recommendation because I'm just not a trailer towing expert.
We had an airstream dealer pick up our 25 foot with a 3/4 ton, dropped the trailer hitch straight down on the ball, hooked up the chains and brake safety cable and headed out. The guy drivin' said he hauls airstreams on the ball on that 3/4 ton truck all the time and all over.
majorairhead is offline   Reply With Quote
Old 06-10-2017, 04:19 AM   #5
"Hey, I know you!"
Boog's Avatar
2012 23' Flying Cloud
Irmo , South Carolina
Exclamation
I have a 2001 Chevrolet 2500HD and have towed a 26 foot Airstream & Argosy right on the ball. When I measured my ride height at the wheel wells, the rear end would squat 1 3/4” and the front end would rise 3/8”
I also have an Alaskan truck camper. When I load it on my truck (without a trailer attached), the rear end squats 2” and the front end rises 3/8” - no weight distribution except by how things are loaded.
My truck specifications require weight distribution when towing greater than 7500 pounds and it's designed to carry a load. It only gets a little squirrely when driving unloaded, so in my case, taking weight off of the rear axle and putting back on the front axle doesn't make things better... your mileage may vary.
Boog is offline   Reply With Quote
Old 06-10-2017, 04:23 AM   #6
Dezo's Avatar
Blainville , Colorado
We will get back to you on that ,,,, we saw many contractor on the road with 3500 dually with big loader on a trailer direct on the ball no other equipment ..
Before ordering my 27FB we had a chalet truck Camper (3 slides) in the box plus we where pulling my 16' trailer with all the toys, Motorcycle, bicycles, Kayak, tools , etc.etc. only on the ball no problem... We prefer no bar but we want to play safe ...
Dezo is offline   Reply With Quote
Old 06-10-2017, 05:13 AM   #7
Gainesville , Florida
I would go with a double sway control. I use that and have no problems.
Old 06-10-2017, 06:42 PM   #8
Davey "Ham" KU9L
KU9L's Avatar
Winter Haven , Florida
Send a message via Skype™ to KU9L
Here is the issue as I see it. I have a 2012 F-350 DRW with 2012 Lance 1181 truck camper. We have airbags and overloads on the upper rear springs, but am not quite level as I would like to be. Two affects from that are: 1) The steering wonders more than we would like (transmutes to more driving fatigue on long trips) & 2) I have to put a strip of masking tape on the top of my headlights at night so folks do not continuously flash us for them thinking our bright lights are on.
Mind you our Lance gives the equivalent of 4000 pounds of tongue weight, but I am looking forward to having only to deal with just 1,200 pounds of tongue weight from our yet TBD AS which we are heavily researching. We also may downgrade to an F-250 SRW as my long bed dually is quite the challenge to park most every place we go. Then we will get Supersprings and a 4-pt friction hitch. ;-)
KU9L is offline   Reply With Quote
1998 Dodge Ram 3500 Dually babsjean Airstream Classifieds 0 04-07-2014 08:43 PM
Dodge sprinter 3500 dually chris97141 Tow Vehicles 3 09-09-2008 01:43 PM
Dually versus non-dually ShikariJones Tow Vehicles 29 08-27-2008 08:55 PM
