Old 02-10-2018, 08:13 AM   #141
Cincinnati , Ohio
Iíve been following these boards for almost a year now as we contemplated our first AS purchase. I pitched the idea last summer to my wife who shook her head in disbelief. After six months of chewing on it, she opened up to the idea. Long story short - ordered a 30í FC. As I read the advice from so many of you, the stories of the TV came up time and time again. We have a Ď16 Suburban with the max tow package and in theory it can pull the load but not to the point where we could stop worrying about the load or knit picking about how much additional weight we could bring along. Decided to add a Ď18 K2500 Duramax as a tow vehicle for the long haul trip we have set for this summer and the comments here reinforced that decision.
jwpaquette is offline   Reply With Quote
Old 02-10-2018, 08:22 AM   #142
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Gas verses Diesel Tow Vehicle
I have a 2017 30í international pulled by a 2017 2500 duramax LP5. Youíll enjoy the combo and will tow with confidence. I moved to the duramax after towing extensively with a 2012 Infiniti QX and I prefer the duramax. There are pros and cons to both but overall the diesel with larger payload, engine brake, etc works better for our family.
ID:	303864   Click image for larger version
wulfraat is offline   Reply With Quote
Old 02-10-2018, 08:44 AM   #143
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
First off, welcome to the Forums. We're glad to have you with us. It sounds like you have everything all set to go. We also have a 2018 Silverado Duramax and a 2005 3/4 ton Suburban Quadrasteer. We still use the old Suburban to tow the Airstream in the Florida flatlands and when we need more passenger capacity.
Congratulations on your new Airstream towing combo. May you have safe travels and many great Airstream Adventures with them.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 02-10-2018, 11:24 AM   #144
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by lesbuford View Post
yes, please tell me about the recall on the brakes. I have hydraulic disc brakes on my 28foot Classic Limited. I have not yet tested the brakes properly. Also, can you recommend a good owners manual? I don't have any books at all on this. I am the third owner. Thanks for any help!
Check for a private message.
Manuals I think are available at airstream.com digital version.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 03-22-2018, 12:29 AM   #145
aa6rv's Avatar
Canyon Country , California
If you got the Duramax, you will have no issues towing an Airstream. Yes, you can pull it with a V8 gas engine. But gas engines are not specifically designed for towing like a Diesel. People can argue as much as they want. Diesels are built better, last long, have higher torque and run at lower compression ratings than gas. I can tow heavy loads at 1700 rpms, my poor gas truck is over 3800 rpms. There just isnít any comparisons. I go over that Southern CA grapevine and my GMC 3500, Duramax Denali laughs at that pass, my gas engine GMC tranny over heats and waves a white flag. If you are serious about pulling your trailer, only consider a Diesel. I spare the Dodge, Ford, GM fight for another time.
David
aa6rv is offline   Reply With Quote
Old 03-22-2018, 03:33 AM   #146
2012 19' International
Southeastern MI , Michigan
David
If your gas engine is running 3800 rpm for towing something is wrong. Mine runs 1800 to 2100 rpm and tows with no issues.
By the way, diesel compression ratios are much higher. Thatís how compression ignition works.
2018 International Serenity 27' FB
Michelin 16Ē tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
Countryboy59 is offline   Reply With Quote
Old 03-22-2018, 08:50 AM   #147
aa6rv's Avatar
You are absolutely right, higher compression with higher torque. Thatís what happens when I use my iPad and get distracted
Old 03-22-2018, 09:05 AM   #148
sbowman's Avatar
1972 31' Excella 500
Grapeview , Washington
David
I see no fight, all about the engine, Cummins hands down. It is hard for me to argue when Cummins 1st went into what I call a pick up truck and remains basically same today. Others have and continue to change who makes their engines. Not saying it is a bad thing, for me if not broken why change?
Best regards and safe travels
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
sbowman is offline   Reply With Quote
Old 03-22-2018, 09:10 AM   #149
sbowman's Avatar
My wife runs into same w/her iPad and getting distracted. Me I just have their stock and do not use their products. Better return w/less risk.
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
Old 03-22-2018, 09:20 AM   #150
aa6rv's Avatar
You got to support our Apple Stock....what do you think allows me to buy all my toys? I saw the vision when they first came out with iTunes at $7 a share. I'm retiring at 54. It's all good.....now I just have to pack up all my crap and get the hell out of California, so that I don't have to give them State income tax.
Old 03-22-2018, 10:55 AM   #151
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
I'm sorry to read that you had such a terrible gas-powered truck.
David
Old 03-23-2018, 08:58 AM   #152
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Works for me...you donít see any V8 diesels in the big trucks.....I like the cummins....and the ram...
Old 03-23-2018, 09:24 AM   #153
DKB_SATX's Avatar
Alamo Heights , Texas
"Don't see any" is ... misleading at best.
inline-6 is a great configuration and Cummins has for many years made some of the best of those, but I think Caterpillar still makes V8s and Detroit Diesel made V8 diesels for highway trucks for 50 years or so.
In a semi there are fewer space considerations, so a long/tall long-stroke I6 that's well-suited for low-rpm-high-torque operation will almost always fit and is an excellent choice, but not the only one.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 03-23-2018, 11:57 AM   #154
1986 31' Sovereign
Miami , Florida
My Nissan XD has a V8 Cummins diesel in it. Runs fine.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 03-23-2018, 02:45 PM   #155
jcl
Vancouver , British Columbia
Depends on your definition of big trucks.
Off highway trucks use 8, 12, 16, or 24 cylinder power. Even Kenworth, Peterbilt, Freightliner, and Mack highway trucks came with 8 and 12 cylinder power. Pacific trucks used up to 16 depending on the model. Caterpillar, Cummins, Detroit, and Mack all built V8s. More common in Australia than the US due to the higher loads permitted there. A 14 litre 6 cylinder can develop sufficient power for the loads allowed on US roads.
jcl is offline   Reply With Quote
Old 03-23-2018, 04:57 PM   #156
Cummins 385 hp. Power stroke 460 hp and almost 1000 torque. Your call.
Michelin 16Ē tires
Hensley Arrow hitch
Old 03-23-2018, 07:03 PM   #157
2017 30' Flying Cloud
Pleasant City , Ohio
Man, these things spiral into nonsense so very quickly. Instead of providing first hand advice based on our usage of a brand or engine type all people tend to do is try to prove people wrong at all cost.
KCCO is offline   Reply With Quote
Old 03-23-2018, 11:56 PM   #158
2016 28' International
Sioux Falls , SD
I have towed with both.
I much prefer diesel due to the torque. I like being able to go up a hill without heavy downshifting or significant rpm increase.
Torque is your pulling power not horse power.
We have a Ram Cummings
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 03-24-2018, 08:57 AM   #159
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
V8 Detroitís went away years ago....cat no longer makes on highway engines for trucks..quit in 2009.....
Old 03-24-2018, 09:10 AM   #160
sbowman's Avatar
Cummins. Lets see, Ford has changed design/suppliers how many times in the past 20 years? If it an't broken why change?
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
Single 15,000 btu verses dual A/c in FC 25' ljsigman Furnaces, Heaters, Fireplaces & Air Conditioning 16 02-01-2018 03:43 PM
FB verses RB Dwain 2005 and newer - Bambi all models 20 12-19-2017 06:19 PM
15 '' D rated verses 16'' E rated Tires hodges53 Tires 9 07-25-2014 07:16 PM
4 speed verses GV Chuckles Mechanics Corner - Engines, Transmission & More... 19 06-06-2010 10:19 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
