Old 03-30-2018, 10:20 PM   #301
2007 27' International CCD FB
San Diego , California
Originally Posted by mikextr View Post
I Decide that I needed as much torque and horsepower as I could get. So I tow with a Porsche Cayenne Turbo S. 521HP 535lb-ft torque. It's a few years old now but it sure gets the job done. It can tow a 5000lb boat and trailer from 0-60 in 9 seconds. Will also pull an Airbus A380 without weight distribution or sway control!
That's cheating. You're playing with a nuclear reactor while the rest of us are just burning old dinosaurs.
pteck is offline   Reply With Quote
Old 03-31-2018, 08:54 AM   #302
sbowman's Avatar
1972 31' Excella 500
Grapeview , Washington
[QUOTE=DBinSD;2082536]
Is a gasser faster, YES!
What works less hard pulling load? Diesel
Which is better for passing? Gasser
Which is better for steep long grades? Diesel
Neither will be "better" for the other person as they chose what was the BEST FIT for their equipment!
Just me 2cents
Travel safe guys!
Concur w/your closing statement. However statements on comparing current gas vs. diesel. Not so sure gasser's are faster or pass better than today,s big diesels. Would agree looking 20 years back.
Driven many stout gasser's over the years. 1st diesel for us, continues to put BIG SMILE on my face w/what it does or can do towing or not towing.
Best regards and safe travels
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
sbowman is offline   Reply With Quote
Old 03-31-2018, 11:53 AM   #303
mikextr's Avatar
1967 26' Overlander
Bugtussle , Oklahoma
Lol! Just burning old dinosaurs like everyone else. Don't want the nuclear physicists in this forum getting worked up and derailing this thread.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 04-01-2018, 02:41 PM   #304
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Originally Posted by TexAirS View Post
I'm new to diesel and keep reading how expensive diesels are. Got a '16 Duramax and think operating a diesel is less expensive per mile. In central TX, regular is $2.19 and diesel is 2.59. That's 18% higher. And with 11 mpg(you) vs 15.6 mpg(me) towing, that's 42% better mileage. So, around 60k, my fuel costs are $4500 less?
What am I missing?
John
Are you really getting over 15 towing? I've spoken with a lot of people at various campgrounds throughout the country that don't break 12 or 13 with a modern diesel in a 3/4 to 1 ton.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 04-01-2018, 05:02 PM   #305
2016 28' International
Sioux Falls , SD
My 2005 Ram 2500 Diesel avg. towing was 14-16.
My 2017 Ram 2500 Diesel just towed 5180lbs for 1680 miles and avg. was 16.89 going through Idaho on way to South Dakota. Had several good climbs.
It has a 3.44 final drive ratio.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 04-01-2018, 05:11 PM   #306
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Please, if you're quoting a MPG figure, can you add if its hand calculated or computer readout display figures.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 04-01-2018, 05:22 PM   #307
Sioux Falls , SD
Pump to pump (by hand) using total miles driven / total gallons filled.
Old 04-01-2018, 06:10 PM   #308
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
What are you getting in mixed driving? Say a bit of towing and some around town stuff. With idling?
I'm pretty well pinned at 12-13 mpg.
Old 04-01-2018, 10:50 PM   #309
Sioux Falls , SD
What year is yours?
I have not had much mixed driving.
I really have not had much non towing freeway either.
My around town has been between 16-18. That is not much traffic lights and about 16-20 minutes each way drives.
I expect to get around 20-21 freeway non laden.
Old 04-02-2018, 02:19 AM   #310
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
What year is yours?
2017 f250 6.2L crew cab standard bed 4x4. I do have a cap with roof racks and about 300-400 lbs in the bed.
Old 04-02-2018, 07:15 AM   #311
Sioux Falls , SD
I will have my cap and a bedslide installed in May. However, I donít see that making much difference.
My F350 Powerstroke in 2002 got around 13-14 towing. It had just a cap.
Old 04-02-2018, 07:31 AM   #312
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
Several months ago, I traded in my 2015 Ram/Cummins 2500 for a 2018 Ram/Cummins 3500. The 2500 had 30K miles on it, probably over 95% towing my AS 27 at 60-65 mph. On the basis of gallons used, the 30K miles resulted in 13.5 mpg. I once took a trip from Seattle to Portland on the I-5 fwy at 65 mph unloaded and got 22 mpg. I have gotten over 16 mpg towing the AS, from Seattle to Salt Lake at 60-65 mph, but that was on flat freeways. Once I hit the mountains going from Provo to Pueblo over a 11K ft pass, my mpg dropped to 10.
Alta & Richard, Olympia, WA --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 04-02-2018, 07:49 AM   #313
Sioux Falls , SD
Seattle to Portland is down hill
If I can maintain speed right at 60mph my avg MPG is much better, obviously when compared to my need to go over 65.
Old 04-02-2018, 06:08 PM   #314
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Look at the weights of the trailer.....makes a difference...and the different gear ratios....my 07 was 3.73....16-17 mpg empty.....my 17 with 3.54ís gets 20 empty...both have 6.7 Cummins
Old 04-02-2018, 08:05 PM   #315
Sioux Falls , SD
The final drive ratios are what I feel is a huge difference.
Old 04-03-2018, 05:45 AM   #316
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Originally Posted by Troutboy View Post
I almost bought a 2018 Tundra, but the engine and drive train tech is very old. Gas mileage was 13 mpg. I use the truck as a daily commuter and couldnít bear that low number, when competitors are getting 22 or better.
Toyota guys told me they are losing sales because of this and waiting for the next gen to come out that will put the truck back on par with the others.
They sure are pretty though, and reliable. I went with the f150 EB, 2018. Maybe upgrade in three years to a larger truck, we will see....
I get 17-18 mpg with my Tundra 10-12 towing. Maybe you were comparing mpg of towing Tundra vs non-towing Ford? Iím not giving up the reliability for a couple of miles per gallon. But this is a gas v diesel debate. Very enjoyable by the way. I really think if I had a bigger trailer, and I full timed in it traveling all over the country, Iíd have a diesel.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 04-03-2018, 06:31 AM   #317
r carl's Avatar
Lin , Ne
They both have a mediocre 36k mile warranty. Who would buy a $40k truck with a warranty like that baffles me.
Old 04-03-2018, 10:48 AM   #318
2007 22' International CCD
Itís because the Toyota trucks have very few issues that might need a long warranty period....at least thatís my experience with all the Toyota Trucks in our extended family.
Sometimes when I get real cynical I suspect a super long warranty period for a vehicle is an indication of compensation for a real or perceived reliability issue...
Old 04-04-2018, 06:54 AM   #319
GettinAway's Avatar
Wildwood , Missouri
Who cares if you don’t need it. I always buy used. I bought my 2012 in 2014. Saved a lot of $$. I think it had a small warranty, but I never had a claim. I’ve put 44,000 miles on it, along with the 30,000 it already had.
I guess the whole, “warranty being high priority” factor goes away when it doesn’t get used.
I would guess any automaker factored in some cost to a vehicle for adding a very long term warranty. I could be wrong. I’d just as soon the automaker put that money into improved quality.
2020 25GT FBT
Old 04-04-2018, 07:05 AM   #320
r carl's Avatar
Lin , Ne
Who cares if you donít need it. I always buy used. I bought my 2012 in 2014. Saved a lot of $$. I think it had a small warranty, but I never had a claim. Iíve put 44,000 miles on it, along with the 30,000 it already had.
I guess the whole, ďwarranty being high priorityĒ factor goes away when it doesnít get used.
I would guess any automaker factored in some cost to a vehicle for adding a very long term warranty. I could be wrong. Iíd just as soon the automaker put that money into improved quality.
All the people that did need it! Don't you remember the longer warranties a few years back?
Single 15,000 btu verses dual A/c in FC 25' ljsigman Furnaces, Heaters, Fireplaces & Air Conditioning 16 02-01-2018 03:43 PM
FB verses RB Dwain 2005 and newer - Bambi all models 20 12-19-2017 06:19 PM
15 '' D rated verses 16'' E rated Tires hodges53 Tires 9 07-25-2014 07:16 PM
4 speed verses GV Chuckles Mechanics Corner - Engines, Transmission & More... 19 06-06-2010 10:19 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
