05-28-2019, 12:22 PM
2018 28' Flying Cloud
Columbia
, Missouri
Ford aluminum pick ups
I currently tow a 2018 FC 28 foot (6600 pounds loaded) with my 2011 Ford F150, 5.0 liter engine and tow package. It does okay or better but I am looking to upgrade to a newer F150 but am a bit concerned about the overall lighter weight truck for towing. The aluminum bodies shave about 700 pounds dropping the tow vehicle weight to around 4900 pounds. My theory has always been that a heavier (and longer wheelbase) tow vehicle offers more stability and safety for towing.
Anyone have experience going with the newer F150 PU with the aluminum body verses the steel bodies? Thanks in advance for any comments.
05-28-2019, 12:56 PM
1994 30' Excella
Mississauga
, Ontario
One huge plus with the aluminum body is that it increases your payload by about that 700 lbs. all other things being equal.
Al
Al and Jean
TAC ON-3
05-28-2019, 01:54 PM
Silver Condo III
2015 30' International
Saskatoon
, Saskatchewan
Towed with Both
Hi there. First hand experience here. Towed our 30' International Serenity with a 2012 F-150 Lariat (Crew Cab 6 1/2' box 3.5 l ecoboost) which was a steel body. Then towed with a 2016 F-150 Lariat (Crew Cab 6 1/2' box 3.5 l ecoboost). Must say we didn't notice any difference in towing at all.
However there is a small difference just driving the vehicle as a daily driver. Living in Saskatchewan we have many gravel and/or bumpy roads. We found the 2016 bounced around a bit more on loose gravel or bumpy roads when the trailer wasn't with us.
The unfortunate thing was we didn't notice a significant difference in gas mileage between the two.
Malcolm & Randy
WBCCI # 12523
05-28-2019, 09:58 PM
Wise Elder
2010 30' Classic
South of the river
Not quite what you're asking for, but I have one of the first aluminum F-250s and have been happy with it. I got the extended cab and 8' bed, so it has the advantage of wheelbase.
05-28-2019, 10:53 PM
Alamo Heights
I think the switch (for the '17 model year) to dual-mode injection and the 10-speed transmission made more of an MPG difference than the steel-to-aluminum transition, at least for the Max Tow setup. It may be that a low-numeric ratio Gen1 Ecoboost in an aluminum truck would do noticeably better than the Gen1 Ecoboost in a steel one. The Gen2 10-speed averaging a bit over 11 mpg pulling a 26U at about 68 mph is a decent outcome for me.
— David
05-29-2019, 04:07 AM
2019 30' International
Pennsylvania
, Pennsylvania
I had a '15 F150 3.5 ecoboost, aluminum, and towed a 25 foot flying cloud.....no problems whatsoever. That 3.5 is a beast.
Now tow a 30 footer with a '17 F250 gasser and it's a real nice setup.....3,110 pounds payload!
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
05-29-2019, 04:33 AM
Lin
, Ne
Most of that 700# came from the cab and frame. Steel boxes are lighter than you think. Mine is around 300#.
05-29-2019, 09:07 AM
Columbia
, Missouri
To majorairhead Thanks for the reply.
Do you know the weight of your current tow vehicle and what sort of fuel mileage do you get with your current setup?
05-29-2019, 03:41 PM
2019 25' International
Washington
, Washington, D.C.
I drive 25’ Intl and according to truck’s program display, I’m getting 12.6 miles to gallon which makes having the 37-gallon gas tank a real blessing.
05-29-2019, 07:13 PM
Pennsylvania
, Pennsylvania
I don't know the weight of our truck off hand, but likely in the neighborhood of 6,500 pounds or so. It's a 2017 F250 crew cab, XLT, 6.2 gas.
Towing our 2019 International Serenity I get 9.5 mpg on average. Depending on terrain, some times 10, some times 9.
Not towing, winter gas gives me around 12.5 mpg. Summer gas gives me around 14.5 mpg.
Equalizer hitch set up, no issues at all, tows rock solid.
05-30-2019, 04:56 AM
2016 25' Flying Cloud
Stillwater
I drive a 2016 F-150 with the 3.5 liter Ecoboost and aluminum body, pulling a 25-foot AS, over 25,000 miles so far and no problems. Pulls rock solid, although both TV and trailer get pulled and push a little sometimes by 18 wheelers. I get on average about 11.5 mpg, depending on the terrain.
D & B
2016 F-150 3.5L Eco-Boost
05-30-2019, 05:57 AM
2018 27' Flying Cloud
Easton
, PA
Ford F150 switch
I used to pull our 2018 FC27 with a 2011 F150 V8. Recently made the switch to to 2018 F150 Powerstroke Diesel. All around better in every way. No issues with lighter aluminum weight.
Averaged 11-11.5 MPG with the old F150 -- the new F150 averaged 16 MPG on our recent 1800 mile outing a couple weeks ago.
05-30-2019, 06:22 AM
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
I could really get used to that. (I’m assuming that mpg is pulling your AS?) I’ll have to do a little calculation to see how many miles I’d have to drive to justify the cost of swapping vehicles. I doubt they’ll be taking $6,000 off of list price in Sept though.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
05-30-2019, 08:20 PM
2019 27' Globetrotter
Cypress
Our tow vehicle is a 2015 F-150 Lariat SuperCrew FX4 3.5 EcoBoost with 3.55 gears. Traveled just this weekend with a 6,300 pound 27' AirStream GT and 1,100 pounds of cargo split between the truck and trailer, from Cypress Texas to Arlington Texas. Total trip was 470 miles. On the way up had a 15 mph tailwind and averaged 14.5 mpg. On the way back had a 15 mph headwind and averaged 11.7. Total trip averaged 13.1 mpg. My speed was 60'ish roundtrip. Past trips have been around 12.5 mpg. I am very satisfied with these numbers.
05-31-2019, 05:32 AM
Easton
, PA
Yes, that was pulling the AS, on flat to small rolling hill terrain. Surprised to see that high of MPG, but that was what the trip data stated. I'll continue to monitor over next few trips to see if it changes. My original F150 was getting up there in mileage, and when I found a new 2018 still on the lot, I was able to get a decent deal on it. Never owned a diesel truck before but have to admit I am impressed by it. I know diesels are popular in F250s and above, but this smaller turbo diesel in the F150 pulls far better than my old 2011 V8 F150.
06-05-2019, 09:44 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
We've been pulling a 30' with an "aluminum" F-250 for a couple years now. No problems / complaints at all. If you want your "700 pounds" back, go with a diesel / 4WD version There are a lot of options that add weight to a truck.
06-05-2019, 10:48 AM
2016 27' International
Altadena
I recently switched
I recently switched from a 2014 Ram 1500 to a 2018 F150 4x4 with Max payload at Max towing packages. I’m towing a 2016 27fb International. I’ve got about 5000 miles with a trailer behind me and here’s my observations.
The Cat scales tell me that I’m right at the limit on my rear axle and within 100 pounds of limit on my front axle. That’s with the trailer loaded for a two week trip with four passengers and the generator plus inflatable kayak.
I average 11 miles per gallon at 75 miles an hour when it’s level but my gas mileage drops to 7 ish when I’m driving in the mountains. In California I’m only going 55-60 miles an hour and my gas mileage goes up to 12 1/2. With a 10 speed transmission, power is always where I need it. I’ve even done a 9% grade and had to let up. My last truck was better downhill, the Ford can’t hold me back. I’m always applying more break. I borrowed a friends 2018 Nissan Titan HD on a quick trip, it was more stable than the Ford. It was better downhill to but gas mileage was horrible it has a small tank and I hate getting gas with the trailer.
Hope that helps.
06-05-2019, 11:46 AM
2018 Basecamp
Beaverdam
, Virginia
Aluminum body Ford Pickups and towing
I have a 2015 Ford F-150 supercrew 2WD with the 2.7 L eco-boost engine. The truck is rated for 7000 pounds towing as I have it configured. I tow a small boat and a small airstream 2007 Basecamp. I get over 25 MPG daily and around 18 when towing. The 36 gallon gas tank gives me incredible range. The 3.5L eco-boost motor allows you to configure up to almost 14,000 pounds for towing with the max tow package.
I love this truck!
Bill
06-05-2019, 12:31 PM
2008 27' Classic FB
St. Louis
, Missouri
2018 F150 Lariat 4x4 6 cylinder is terrific
We bought the 2018 F150 Lariat with the full 2nd row and short bed. Full tow package. 4x4. 6 cyl turbocharged with 10 gears. Towing our 2008 27 FB Classic rated at 9,000 lb max gross. The truck is rated right at 18000 lb towing... I’m guessing our trailer loaded is 8,000. Towing performance is flawless. Tow mode features are great. Super ride... surprising. Highway mpg is about 18.5, drops to 9 or 10 towing. We god the 35 gal tank with the tow package which I think is mandatory.
06-05-2019, 01:40 PM
2014 27' Flying Cloud
Viera
I'm extremely happy with my 2018 F-150, 4x2, V8, 10-speed transmission. I had to order it to get this combination. Our 27' FB FC weighs in at 6,300 lbs loaded for months on the road. The truck's payload is a problem as it is with all 1/2 ton trucks, but I've never been over the GAWR or GVWR, close but not over. Our B-Pillar sticker says max payload is 1,710.
Uphill acceleration isn't as good as the V6 EcoBoost, but downhill braking is excellent. That's the reason for the V8 choice. I also didn't want all that rotating machinery that has to spin up to generate the power of the EcoBoost. The V8 is a naturally aspirated, fuel injection engine.
I also ordered the 36-gallon fuel tank. With that, I have an over 500-mile range when towing, here in the East. Fuel economy towing is right around 13 mpg, and not towing I get 20+.
There is a YouTube video from Fast Lane Truck where they compared two F-150s one with V8 and the other with V6 EcoBoost towing a 9,000 lb trailer over the Ike Gauntlet. The V8 beat the V6 in every category except for uphill acceleration. I can attest to that.
Randy
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
