Old 03-22-2020, 07:35 PM   #1
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Fix Hyperflash in Ford Tow Vehicles when adding LEDs
You learn something new every day, if you try new things.
I wanted to upgrade my rear turn/stop lights to LEDs. I got some online that were supposed to be compatible with my 2014 F150 and not hyperflash, but they did. I did several searches that said you either had to do add resistors to the circuit or put in a flasher relay compatible with LEDs. No searches turned up where I could find the flasher relay under the dashboard, but they did turn up a thread on reprogramming your carsí computer which turns out to be the solution.
Turns out, many cars today (at least F150s from 2014 (maybe 2009) on use the onboard computer to control the flashing. If the computer detects a low draw on the signal circuit (like from an LED), it assumes that the signal bulb has burned out and tells you by hyperflashing. All you have to do is turn off that computer selection.
I bought a OHP Wifi FORScan OBD2 Adapter for Windows, Android & iOS, Ford Diagnostic Scan Tool, ELM327 Code Reader, MS-CAN / HS-CAN Switch from Amazon to connect to the trucks computer through the OBD2 port. I then used the program Forscan from the web https://forscan.org/download.html, to turn off the hyperflash. It works with Ford, Mazda, Lincoln and Mercury vehicles. It needs to be used in a laptop with Windows 10. It is a bit complicated to download the program, authenticate it and hook up the OBD2 adapter, but once you do, the hyperflash issue goes away very easily. Here is a link which describes some of what you have to do https://www.bing.com/search?q=forsca...=en-US&plvar=0. If you are interested in how to do it, send me a PM and I can give you more of the how-to.
Good luck!
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 04-01-2020, 07:00 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I am amazed that no one has asked me about how to do this given the number of threads I found when I was trying to figure this out my self!! Oh well...
DaveP
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
Fire danger in older Ford vehicles Aage Tow Vehicles 5 02-22-2010 09:39 AM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Tow/Haul feature on GM vehicles Silvertwinkie Our Community 2 08-06-2003 09:06 AM
tow vehicles paul k Tow Vehicles 96 01-19-2003 09:59 PM
