10-29-2020, 10:49 AM
2021 28' Flying Cloud
Upland
FC 28RB twin & F150 need advice
My husband and I have our first Airstream on order: a FC 28RB twin. We are excited, but now a bit stressed. I’ve been reading the boards for the last three years, and now that we finally found our Airstream, I need advice.
Our current tow vehicle is a 2018 Ford F150, Lariat, 4x4, Super Crew, equipped with the 3.5L V6 Ecoboost engine, 145’’ Wheelbase and Max tow package. (3.55 electronic-locking rear axle; 4 pin/7 pin wiring harness; Class IV trailer hitch receiver; Smart Trailer Tow controller; upgraded front stabilizer bar; upgraded rear bumper.) It does not have the payload package, and I think that’s my problem. From the stickers, GVWR 7000 lbs., cargo limit 1,635 lbs. (Front GAWR 3525 lbs/ Rear GAWR 4050 lbs.) This is my husband’s daily driver and he loves the truck. We never thought we would buy anything larger than a 25 foot camper, and I’ll admit that we didn’t understand payload at all. I believe my tow limit is about 10,700 or 10,200 lbs and the trailer GVWR is 7600 lbs, based on the online owner’s manual.
This truck is option heavy (moon roof seemed like a good idea at the time). We took it to the CAT scale, and with full gas tanks, and my husband and me in the cab, the truck came in at just under 6000 lbs. Hence my inquiry. The good news is that we are minimalist campers. There are two of us and a small dog. The only thing we may be putting in the bed of the truck is a small generator. We also don’t plan on putting much in the cab besides the dog’s bed and maybe a small ice chest. We also will not be loading down the Airstream...heaviest item will be my small Lodge dutch oven.
According to the brochure, the hitch weight of the FC 28RB is 899 lbs., and from reading these boards, I understand that it could be much higher? So, we are not looking so good with payload numbers, to say the least. I see us as having three options right now, and I’m seeking advice from you experienced experts.
Option 1: Do nothing except put new tires and a weight distribution hitch on the F150 until we take ownership of the Airstream in January. Hitch it up, take it to the scales, and see where we actually stand. May be able to reduce weight by about 50-60 lbs. by removing the rear seats. Move on to Option 2 if necessary.
Option 2: Besides new tires and WD hitch, put airbags and maybe another leaf on the truck before we get the trailer...suggestions needed. Hope to get 2-3 years of towing (no steep grades yet) before moving on to Option 3.
Option 3: Trade our truck in for a 250. We know ultimately that this is where we are headed, but I prefer not to have the extra expense right now. We are keenly aware that replacing the F150 will make towing easier and probably safer, but is this an immediate need? Whichever truck we have, it will continue to be my husband’s daily driver.
I welcome any comments and suggestions.
Caroline
10-29-2020, 11:06 AM
Alamo Heights
IMHO, do not install or really consider airbags or similar stuff. If the truck is within the numbers as you're really going to use it AND you're comfortable with the towing performance then decide between options 1 and 3 as meets your needs and comfort level. Airbags and helper-springs don't increase your axle rating, they just change the angle of the body under load.
— David
10-29-2020, 11:37 AM
Evergreen
I agree with David on airbags. I'm not a fan of airbags in towing applications, especially when combined with a weight distribution hitch. This combination can be dangerous if not setup properly.
You've got a difficult decision to make. Personally, I'm a conservative guy with respect to tow limits. I'd go with Option 3. That said, it may not be the best option for you. You might look at option 1, and at ways to optimize the towing experience with your existing truck before taking the plunge into an F250.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
10-29-2020, 12:36 PM
Upland
Thank you for your responses. I would love to stick with option 1 as much as possible! I did not know about the bad combo of WD hitch and airbags.
10-29-2020, 12:42 PM
Trilla the Traveling Tube
2018 22' Sport
Dayton
, Wyoming
Option 3. We are by no means experts, but our 2018 GMC 1500 is a perfect match for our 22FB Sport. The Sport (Bambi) has a lower tongue weight (appx 420-450) and our truck has the full tow package.
If we decide to go any bigger than the 22FB, then the TV will change as well.
10-29-2020, 01:04 PM
2023 27' Globetrotter
Winder
, Georgia
I'm in the same situation. Picking up our new Int. 25RB in a couple of weeks.
Agonized over a TV for a month. This forum will drive you nuts because for every vote for the 3/4 ton there is a vote for the 1/2 ton. I learned a tremendous amount on here though about payload which honestly was something I had never paid much attention too and I have owned 3/4 ton and 1/2 ton trucks and pulled boats, trailers, and campers all my adult life.
Anyway, sold an older F250 that I had because it was time to upgrade to the 21st century, and after much debate decided on the F150 almost identical to the OP's. (2020 model) 1680 payload, max tow, 3.5 ECO etc, etc. For me it was 2 things: Daily Driver concerns and money(up front and maintenance, fuel mileage, etc) Even an F250 Gasser was a pretty big difference. I have lost sleep ever since wondering if I really screwed up and compromised safety and overall satisfaction over roughly $10,000 when I am about to drop $85k for a new trailer? Kinda stupid when you really think about it. There is no doubt that the ECO 3.5, Max tow, 10 speed transmission combo will 'pull' the trailer just fine.
Its that all important payload that is the issue. We too are minimial campers. Weekend trips and occasional week long. So maybe we will be ok.
We are picking up in Tampa Fla and driving back to GA so I will update after that although a flat interstate drive along I-75 should not be an issue.
Remember though, as I learned from this forum that a properly adjusted WD hitch will transfer a good bit of that hitch weight to the rear axles so that does factor into the payload consideration. That's why the proper hitch is so important. I agree with David and Dennis on the aftermarket suspension add-ons. Not a fan of those either. Only thing I might consider is the Roadmaster Active Suspension which has been tried and true proven but even still I will wait until I see how the rig performs stock before I go that route.
Good luck!
10-29-2020, 01:11 PM
2017 25' International
Kirkland
Option 1
Take Option 1.
I have the same 2018 F150 with a 2017 International 25FB. Its GVWR is 7300, and tongue weight is posted as 837. Not much less than what you're getting.
I mindful of what I load in the F150 so I've got cushion on payload there. As for what I load in the trailer I'm well within its GVWR.
You've got plenty of towing capacity so the main issue is truck payload.
Once you've got your new rig, load it and the TV as you plan, go to a scale and get the real numbers.
Skip Option 2 and if the numbers dictate it, go to Option 3.
10-29-2020, 01:18 PM
2018 25' International
Full-time
, Traveler
I went down a similar path, but with a 25FB.
I would go with option 1, see what the scales tell you, see how the truck feels, and then decide if you need to move to option 3.
For me, I tried for about six months to make the F-150 work (I think my payload was about 1,800 lbs). Hitch weight when loaded for camping was 1,050 on a sherline scale. I packed the truck like I would on a normal trip...a couple chairs, small grill, wife, dog...nothing major. I worked my setup as best as I could (using a ProPride hitch) and couldn’t get lighter than 3,600 on the rear axle, which was the limit for it. That was not horrible, but I also felt like the steering response was not so great. Maybe it was in my head since I was already concerned, but I decided I would prefer to not worry about it, so I bought an F-250.
There seems to be an ingoing debate over 1/2 vs 3/4 ton trucks. I’m not an engineer so I can’t offer any technical help, but I made the choice that was right for me.
10-29-2020, 01:30 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
I have a 25FB, F150 limited with a lower towing/payload than your Lariat. & Blue Ox hitch...Your only 490 lbs heavier than I am. Go with option 1!
10-29-2020, 01:55 PM
minneapolis
I just read Jeff7176 response, so figured I would add this as well. The dealer set my Blue Ox hitch at 7 links. After roughly 700 miles I decided to tighten it up another link making it 8. I used this setting for the next 1,300 miles though still noticed a little bit of a wag and light/loose front end. I decided to tighten up one more link making it 9 and the f1500 drove rock solid for the remaining 1,400 miles. Make sure the hitch is properly set... If its not set tight enough, in addition to wag...the steering will feel loose. FYI...My Blue Ox has 1,000 lb. bars...
10-29-2020, 02:29 PM
2020 30' Classic
Frederick
, Maryland
I think the key is that if you have a well-set WD hitch it will not be an emergency where you have to change trucks immediately. I had something similar and it was not as stable as I wanted but not bad. Get the AS (congratulations!), make sure the WD hitch is set up well, then take it to the scales. You may be overweight a bit but I doubt it will be by too much. Not good long term but if you pay attention to loading you should be able to get away with that set up for some time. I am not an official expert but is based on my experience with our 27FBT and a similarly equipped 2017 F150. We ultimately wanted more "headroom" so we upgrade to an F250 after two years.
Have fun!! Don't get too stressed; this will not be some unstable ride ready to shatter your axle on the next bump. Just pay attention to your loading and it should be fine for a bit.
10-29-2020, 02:46 PM
Upland
Again thanks for all the responses! I'm relaxing a bit more now, and it's good to know that I'm not alone. Bcc75, I'm interested to hear how it all turned out for you!
10-30-2020, 09:24 AM
Orlando
We have same truck (F150 Ecoboost 3.5), AS Globetrotter 30’ and a Hensley Hitch.
We just came back from our 2 months trip (~6000miles from Florida to Montana and back).
It towed well till we reached Wyoming, the truck struggled on the passes up or down. Started backfiring and overheating.
As soon as we came back from our trip, I ordered a new F250 gas V8 7.3l. Better be safe than sorry!
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
The only advice I will give you is do the math.. the following link is the journey we took in marrying our F-150 to our International 25CCD
how-to-determine-if-your-tow-vehicle-is-right-for-your-trailer/
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
10-30-2020, 09:30 AM
2019 27' International
Western NC
, North Carolina
You've gotten the answers you expected, if you're on the edge the other factor is intended use. Going cross country and more than local vacation trips would push towards option 3, lots of mountains would push towards 3 as well, touring the flatter lands maybe 1 will do the job. You need to balance that all out. enjoy the new airstream..
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
10-30-2020, 09:48 AM
2019 27' Globetrotter
Pleasanton
Seems many of us have the same struggle. I have almost the same truck as the OP, a GT27FBT with an Equalizer hitch. This setup works great and has handled "the Grapevine" in SoCal and other California mountains just fine. The deciding factor at the time for us was the amount of time we would be towing vs every day driving. The 150 is a nicer drive and easier to park so it makes the 90% of the time that we are *not* towing a better experience.
That said...retirement is coming and an F250 will be my retirement gift to myself.
bj
10-30-2020, 05:31 PM
2014 25' FB Eddie Bauer
Vero Beach
Caroline: First off... congrats on the new Airstream.
Second, congrats and “well done” on doing your homework! I’ve read 100 posts like yours here. Most say “my truck dealer gave me a brochure that says their V6 tows like a tug boat... I’m good to take a 30’ Classic over the Rockies, right?”. Your post stands out and shows the thought you’ve already put in.
For that reason, I’m going Obi-Wan Kenobi on you. I think you either already know or will soon know what’s right for you. Ultimately, your camping style and your sense of comfort will answer that question. Nobody else’s answer matters.
We’ve stuck with the 1/2 ton for our 25’. Ours is a Tundra, but the principles apply universally. At times we’ve exceeded payload and Gross Vehicle Weight Rating. We never exceed Gross Combined, tire ratings or either axle weight rating. Your truck has better towing specs than the Tundra.
So, for me, I’d try what you’ve got first. Weigh your rig loaded for camping... take some easier trips first... get acquainted... check in with yourself. Check in here with the brain trust... it sometimes helpful and always amusing. Based on the approach you are taking and the thought you’ve applied I’m confident that the right answer for you will reveal itself.
10-30-2020, 07:38 PM
2022 28' Flying Cloud
GAINESVILLE
, GA
If you are going with option 3, don’t choke. Go for the F-350. Few hundred bucks more and a good deal more payload.
Worth a look/see.
10-30-2020, 07:48 PM
McHenry
Congratulations!
Hi Caroline, what an exciting time! Congratulations on your new FC28RB Twin. Great advice by all so far. I’m in agreement with your Option 1. You may find with a good WD hitch that your current F150 does the job just fine.
We had a RAM 1500 with much less payload and towed our 27’ Globetrotter. The truck had plenty of power but after a trip to the CAT scales we discovered that we were within 100 lbs of being over the max rear axle rating. I can tell you “payload anxiety” can throw a wet blanket on your camping experience. Besides the numbers, I felt at times on the expressway that the trailer pushed the truck around.
We now have a RAM 2500 gas with 2940 lbs. of payload capacity and zero anxiety. The truck feels more planted (it should, weighing over 1000 lbs more than the 1500).
So, try what you have and see how it tows. You may find it does just fine. If not, no worries - move up a notch!
Enjoy your new Airstream and happy camping!
Jeff & Caryle
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
10-30-2020, 08:54 PM
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
Congrats!
Congrats on the new Airstream. We got our 28RBT (Flying Cloud) a year ago and love it. I think you will, too.
Your F150 has 1600+ lbs of payload. Not bad for a 1/2 ton. An F250 diesel will have payload in the 2200 lb neighborhood.
I measured the tongue weight on our 28 RBT and it came to about 900 lbs. when you hook up the weight distribution hitch, some of that 900 lbs will be transferred to the trailer wheels.... so not all of that 900 goes to the truck.
IF you don’t load the truck up with lots of stuff and set up the WD properly, you’ll most likely be fine.
I agree with the others that you should stand pat for now, get the truck, hitch and trailer set up and head for the CAT scales. Forget option #2.
We pull our AS with an F350 diesel. This is because we don’t travel light. Kayaks, e bikes, large cooler...maybe generator(s)...and the weight of a topper and cargo slide. But that’s us. Plus we’re retired and don’t use the F350 for daily commuting and would never consider taking it to downtown Atlanta.
Have fun, watch your speed and following distance!
