11-11-2018, 05:26 PM
2020 25' Globetrotter
Los Gatos
Escaping the Malibu fire
New Sport 22 in the driveway and Highlander LTD AWD is tv. We are packed and will leave if fire gets closer but that does not look likely. If we do go it is downhill 3 min to Pacific Coast Highway. Two lanes but about 800 feet of it is 19% grade with hillside on right and deep canyon to left
Never have tried up or down this road and always come a long way around (usually this would be where fire is). My wife said she saw a pick up drive by heading down the steep road with AS. She said thought same as ours. I know the guy and they have F150
Planned getting a Grand Cherokee but now wondering about 150. Is it able to tow my AS down 800 feet of 19%?
11-11-2018, 05:42 PM
Normal
What a horrible, dreadful situation out there in that inferno.
Stay safe.
Maggie
11-11-2018, 06:06 PM
South East
, Michigan
I wouldn't hesitate with my 150. But really, any vehicle should be able to handle 800 feet. Start and stay slow. Put your vehicle in a low gear before you start down.
Good luck and best wishes to avoid the fires.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
11-11-2018, 06:25 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Yep start in low or first gear and manually use trailer brakes as much as needed
We were supposed to camp at pt mugu this weekend but it was inside the mandatory evac area.
Hope you fair well
11-11-2018, 06:27 PM
2014 27' FB Eddie Bauer
Mobile
, Alabama
Garfish,
Hope all is well with you and your family and your home and the Sport.
Heard on the nightly news that the city of Malibu has been evacuated.
What a horrible fire.
Wish I could send a little rain your way.
11-11-2018, 06:28 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Who in the heck built a road with a 19% grade! Isn't that a 38 degree angle down (and up). It would be like towing the trailer down a black diamond ski run.
There are road designs with "switchbacks" to avoid steep grades.
I rode my ATV down what I estimate as a 45 degree angle from a mountain top last summer. No room here for switchbacks. The surface was loose gravel and dirt. I was skidding. If I skidded off the trail, well it would be a long tumble down the mountain. White knuckles.
Maybe your Highlander has a 4wd Low setting (if ). That would help the brakes some. Newer pickups sometimes have a "hill decent" control that helps on steep downhills also.
I would be no faster than 5 mph in the lowest gear possible with 4 way flashers on.
God I hate wildfires. Stay safe.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
11-11-2018, 06:34 PM
Los Gatos
The road was built over landslide that happened in 1984 that took out the access to PCH. Fire in 93 burned all the homes here, 250 or more because fireman would not come down through the fire to save our homes. So after 20 years we got ok to build this road (our cost, 5.5 million) so we could get out in emergencies. The only other way is up where the fires always come from. It is gated and only for homeowners and emergency vehicles. No choice but steep
11-11-2018, 06:52 PM
2017 28' International
Jim Falls
, Wisconsin
Good that you have an AS. Not sure where everyone else will go. Just put in 4 wheel low if you have it and go slow and steady. Horrible situation.
11-11-2018, 06:59 PM
2013 20' Flying Cloud
Westerly
, Rhode Island
It's a bit less than 11 degrees. Pretty steep but 800 ft. should be no problem. Hopefully you won't need to find out! Good luck.
11-11-2018, 07:03 PM
2007 22' International CCD
Corona
Watching all the fire coverage from Corona, CA area. Do take care. It’s looking really bad on TV news.
The grade, in dry weather should not be a problem. 4WD, low range, and crawl down as slow as possible.
Recovery from this much fire is going to take a very long time...
11-11-2018, 07:10 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
I was a firefighter on the 1993 Malibu Fire, I was on the Bitterroot Hotshot Crew out of Darby, MT. It was on of the most horrific things I’ve ever seen. Every time I see the California fires on the news I remember those times. Will never forget. Good luck to you, stay safe.
11-11-2018, 08:03 PM
2019 30' Classic
Canfield
, Ohio
Low gear in your tow vehicle and use your brake controller. Pinch the brake controller and use your trailer brakes. UYou have four sets of brakes to stop you or ease you down the grade. 800 feet is not a mountain pass.
Low gear and use the trailer to stop you. It will keep you straight.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
11-11-2018, 08:04 PM
Corona
The dry brush around here can burn faster than a person can run. It’s super dry (10% RH or less).
Ted, thank you for coming all that way to help.
So far the woolsey fire is at 83,000 acres and 10% contained. Going to be a long, hard fight.
2019 30' Classic
Canfield
, Ohio
One more thing. Do you have a gopro? I gotta see this!
Tom & Doty
11-11-2018, 08:31 PM
Los Gatos
No go pro but will take video tomorrow with IPhone
11-11-2018, 10:37 PM
Corona
It’s been making the national news. The devastation is simply heartbreaking. So many houses totally gone
11-11-2018, 11:22 PM
1980 24' Caravelle
vallejo
hope you don'thave to evac. our daughter and son-inlaw live in the oraville area; they are still on standby notice to evacuate if needed. our prayers go out to all in the affected areas. kurt
11-12-2018, 05:28 AM
Sag Harbor
, New York
A proactive move ASAP may be advisable? A last-minute rush for the exit might be difficult IMO.
Best wishes.
Peter
PS — Your old thread with additional details about the road:
http://www.airforums.com/forums/f238...pe-171817.html
11-12-2018, 09:14 AM
1996 30' Limited
1990 34.5' Airstream 345
santa rosa
Get a 150 minimum. Jeep has a very short wheel base. Might get a little squirreling going down hills 2500 or full size suburban is better. Plus you can take your 7 new best friends and their dogs
11-12-2018, 09:59 AM
Silver Star
1970 23' Safari
Victoria
, British Columbia
What a scary fire .....we had the worse fire season in history here in BC this past summer.... luckily we have had a rainy fall and all is well now.
I use to live on a long 600ft very steep driveway (many friends where afraid to drive up it) and I brought a 16ft Boler up and down with 4wd.....as others have said .... Go slow ...low gear and use the brake controller and you'll be fine.
Have you considered moving the trailer out now to a safe spot... and then you could just drive to it if things get ugly?? It may be easier in evacuation traffic etc without the trailer?
Keeping our fingers crossed for you and your neighbours.
